Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Fri Jan 29, 2010 12:12 pm Post subject: Type 3 full flow... |
OK, I think I had too much coffee yesterday, or something, and was thinking about this way too much. But, I am just not sure if I really missed something huge. Or not...
I'm really kinda embarrassed to ask this. But, did I miss a step in my full flow?
My motor is set up just like this one:
So, between the two fittings, is a plug. On my oil pump and case, I didn't plug the two as done typically on a Type 1.
Like this:
and this:
So, did I do my full-flow correct? Or did I make a big mistake???
I'm so confused today... All the codeine in my cough syrup has me in a stupor... _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Jan 29, 2010 12:17 pm Post subject: |
WRONG, WRONG, WRONG.
The way your case is tapped for the fitting, with a plug between them, you do not want to plug the pump, or the plug in the case at the pump.
You just use an standard pump. The oil goes up through the normal passage, to the first fitting, through the filter, and back from the filter to the second fitting.
The only time you plug the pump and case like yours, is fi you have a Berg style pump, with the fitting in the cover. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Fri Jan 29, 2010 12:25 pm Post subject: |
OK, I thought I understood everything, and did it correctly.
I'm using a regular pump with the normal passages. Whew... I was seriously thinking I lost my mind.
Thanks Russ!! _________________ Phillip Bradfield
Oregon VW Forum -- http://www.oregonvw.org |
pow_rider17 Samba Member
Joined: October 13, 2006 Posts: 509 Location: Burque, NM
Posted: Fri Jan 29, 2010 12:27 pm Post subject: Re: Type 3 full flow... |
Notched wrote: |
Like this:
and this:
I'm so confused today... All the codeine in my cough syrup has me in a stupor... |
I think he is saying that he did not plug the pump and case.
In which case it is correct. |
Posted: Fri Jan 29, 2010 12:28 pm Post subject: |
Exactly. I should highlight that. _________________ Phillip Bradfield
vwfye Samba Member
Posted: Sat Jan 30, 2010 11:22 pm Post subject: |
it should say, "Not like this or this" _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Houstonr Samba Member
Joined: February 01, 2009 Posts: 399 Location: Frisco Texas
Posted: Sat Jul 31, 2010 9:09 am Post subject: |
Russ Wolfe wrote: |
The only time you plug the pump and case like yours, is fi you have a Berg style pump, with the fitting in the cover. |
Is this the proper berg cover for the T3 that will squeeze under the fan?
Posted: Sat Jul 31, 2010 9:15 am Post subject: |
nevermind found it... 241A |
jim altemus Samba Member
Joined: September 22, 2002 Posts: 366 Location: New Milford CT
Posted: Sat Jul 31, 2010 10:06 am Post subject: |
Houstonr wrote: |
Russ Wolfe wrote: |
This is what I used on my motor. My builder then used some brass fittings that I replaced with A/N fittings when I got the motor back. You will have to do some minor grinding on the back of the fan housing but nothing drastic.
Jim _________________ aka Jimal
Currently sans Volkswagen |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
