insipid Samba Member
Posted: Sat Jan 30, 2010 8:45 am Post subject: headlight issue |
About 2 days ago my headlights worked fine, then they started to dim adn flicker, now they only come on when you hit the brakes. All the other lights remain fine. Any suggestions n this? _________________ ____________________________
73' Fasty
"When I die, I want to die like my grandfather --who died peacefully in his sleep. Not screaming like all the passengers in his car" |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sat Jan 30, 2010 8:47 am Post subject: Re: headlight issue |
insipid wrote: |
About 2 days ago my headlights worked fine, then they started to dim adn flicker, now they only come on when you hit the brakes. All the other lights remain fine. Any suggestions n this? |
sounds like a short in the wiring; start at the headlights and work your way back, checking/cleaning all your connections... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Jan 30, 2010 10:41 am Post subject: |
Check for corroded fuses. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
68notch Samba Member
Joined: August 16, 2007 Posts: 544 Location: Perth, Western Australia.
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Sat Jan 30, 2010 9:23 pm Post subject: Re: headlight issue |
insipid wrote: |
About 2 days ago my headlights worked fine, then they started to dim adn flicker, now they only come on when you hit the brakes. |
Check grounds front and rear, this part is bizarre. |
