Jack Frisch Samba Member
Posted: Sat Jan 30, 2010 3:50 pm Post subject: 67 Bus Engine Tin Questions |
Can anyone here possibly take a photo of the individual engine tin pieces needed for a stock 67 Bus?
I'm having a 67 stock motor, originally out of a beetle put in my bus and
I dont know what tin I should be looking at or looking for
Any help appreciated
Jack _________________ 1958 Beetle orig. 6 volt 36 hp engine, body & pan, Black w/red/off white inter., Orig. VW wood roof rack and orig. rear luggage rack.
1967 13 Window Walk-thru Deluxe Bus, stock 1500 engine, Titan Red/Grey, Platinum Mesh interior, orig. & stock
1966 GT350H Shelby Orig. low mileage car
2002 PT Cruiser Limited Edition, stock, auto, loaded |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Clara Samba Member
Posted: Sat Jan 30, 2010 7:14 pm Post subject: |
this picture does NOT show the late 66-67 breast tin
rear engine tin comparison:
top: '67 beetle with 38mm pre-heat holes both sides for dual 1" pre-heat hoses
middle: 1500 pre 1966 bus, with pre-heat hole on left (as seen in driving direction)
(40hp fresh air rear tin looks very similar, but the heat riser spacing is about 1/2 inch narrower)
There is a 66 ish bus version with pre-heat hole on right
There is also a late 66 - 67 bus version with no pre-heat hole, as the heat is picked up from the right heater box.
bottom: 1600 bug/bus has larger pre-heat hole, on right, for 2" pre-heat hose
The shape where it fits to the under pulley tin is also different.
^^^^^^^^^different varieties of deflector tin for fresh air 40hp and 1500/1600 motors.
There are left and right with no oval holes (top) 67 bus came with the ones with no hole.
Then left and right with oval holes for the pre-heat pick up pipe that attaches at the muffler at the head, under a nut.
Shown are a left and a right 67 & earlier pre-heat pick up pipe.
Bottom right is the 68& later/1600 right deflector with gap for large pick up pipe (68& later 1500/1600) and gap for bent oil breather pipe.
To use the earlier versions of the right side deflector, you must have a straight oil breather tube.
Hope that helps.
This really only applies if you want to do an anal retentive correct for 67 engine.
Then you want the front tin with pre-heat hole on right, and the right heater box with the spout.
These were pieces of tin missing from my Mom's 67 beetle motor. It was more complete than some:
post a picture of your '67 beetle motor'. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/
Posted: Sat Jan 30, 2010 9:19 pm Post subject: |
Clara
WOW!!!
This is one hell of a reply!!!!
Wow!!
Thanks
A huuuuuge help, for me and for the entire membership here for sure.
Thanks!!!!!
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Sun Jan 31, 2010 1:00 am Post subject: |
67 bus set-up
The 1600 set up above (2" preheat) would be useless unless you had a baywindow 68-71 aircleaner. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
jeremy57ride Samba Member
Posted: Mon May 02, 2011 12:27 pm Post subject: |
I'm trying to get the preheat correct on my 67. Crofty, or someone could you comment on the routing of the preheat tube? I think I have all the tin questions answered, this thread has been helpful.
I'm still not clear on were the pre heat tube is routed on the 67. I must have the wrong tin, 2 holes as well as holes on both sides of the connecting tins. Seems like it was a 67 beetle tin.
Anyone have a detailed original 67 engine bay that shows the routing of these tubes in detail? Thanks fo any help, suggestions. |
Posted: Mon May 02, 2011 12:35 pm Post subject: |
See my pic above. The pre-heat tube connects to the heater box (pass side) then goes threough the large hole in the tin (pic above) straight to the air cleaner.
The pic with the 3 rear tin pieces does NOT include a '67 bus version. It would have no preheat hole. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Mon May 02, 2011 12:36 pm Post subject: |
Clara wrote: |
on a 67 bus, the pre heat hose goes forwards through a hole in the front tin and fits onto a spout on the heater box. This improved system actually force feeds heat to the air cleaner.
You may, or may not, have the original heater box, and tin for that set up. |
Ok, I'm finding my own answers here! Looks like it simply goes forward through the front tin down to the heater box. Something tells me my heater box doesn't have the correct port...
Anyone modify their heater bx to work? I'm sure its been done |
Posted: Tue May 03, 2011 5:57 am Post subject: |
Thanks Crofty. I have the pre-heat straight, now I need to get the correct tins. My breastplate and small tins are all 67 beetle with holes in everything.
It should be easy enough to modify the front tin, not sure about the non-port heater box. Anyone with experience on where that port goes? (after it enters the box)
I'm curious if I just drill that area and weld a pipe there if that's going to work. |
Posted: Tue May 03, 2011 7:44 am Post subject: |
I'm not using the ones in my pic. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Tue May 03, 2011 8:09 am Post subject: |
PM sent. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Thu May 05, 2011 6:59 am Post subject: |
crofty wrote: |
67 bus set-up |
A perfect picture, Crofty.
I have the front tin with the only hole on the driver side near the fuel line hole. Any idea what year that is for: '68 up? I can't find it mentioned in the http://oacdp.org/ but it shows the '67 front tin starting with the 12 volt engine. I've also found heater boxes with the preheat on drive and passenger sides. Also the preheat hose fits the heat-exchanger preheat pipe sloppy; is that correct? |
Posted: Wed May 11, 2011 2:16 pm Post subject: |
BarryL wrote: |
crofty wrote: |
67 bus set-up |
That tin you have is 40hp bus. I seem to remember seeing that on a stale air set-up. pre dec 62
found it! _________________ Your Vanagon sucks, Stop waving at me.
BarryL Samba Member
Posted: Wed May 11, 2011 3:06 pm Post subject: |
Ok, thanks, I guess that solves that. On the stale air 40 horse what did it connect to?
What about this:
BarryL wrote: |
Anyone tried putting preheat hose on the heater outlet pipe? |
Posted: Wed May 11, 2011 3:41 pm Post subject: |
BarryL wrote: |
What about this:
BarryL wrote: |
it connects to the stale air heater box
not sure about how snug it fits though _________________ Your Vanagon sucks, Stop waving at me.
bcampagnolo Samba Member
Joined: August 29, 2011 Posts: 165 Location: United States
Posted: Thu Dec 29, 2011 3:37 pm Post subject: |
OK, I have read this particular post about 12 times.
I have a '67 bus, but the tin is not correct, it has the pre-heat tube in the 68+ location. I am also missing a couple of pieces (not including the flaps and thermostat).
Also, my heater box does not have the pre-heat pipe on it. I have not checked the tin at the front of the engine yet.
I am OK with the 1" pre-heat pipe being in the 68 (passenger) side. I'm OK with the non '67 heater box.
What I need is help identifying the names of the tin so I can search and purchase the missing parts I have.
I know the thermostat is missing and the fan shroud needs to be fixed to allow the flaps to be installed. That's another weekend or another project.
Way up in the thread, Clara has some awesome photos with parts her mom was missing.
I am curious about the deflector tin (is that what I call it?) I seem to have one on the left side with a hole in it. There's also a threaded hole in the head just behind that oval hole in the tin.
Should I get the tin with no hole and 'move' that to the right? (get the proper one with a hole on the right)?
I'm OK with the pre-heat being on the right.
I'm also missing the tin on the bottom of the passenger / right side and the pre-heat pick up.
Not sure if my oil breather is considered straight? It looks like it has a curve in it, but I'm sure I'm looking at the wrong place.
Also, will that cool tin that goes in back (front is front) of the crank fit on mine? It's the one that looks like it floats in the opening in the rear tin behind the main pulley.
I wondered what that lonely little tin screw was supposed to be connected to!
so:
Deflector tin, right side? (hole no hole?) (fix left side?)
Pre-heat pick up tube tin?
Crank Pulley rear tin?
Bottom (sled?) tin passenger side rear?
Thanks for all the help so far in this thread. _________________ Paul
67 Walkthrough 13 Window |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Thu Dec 29, 2011 7:04 pm Post subject: |
Kind of depends on what you are trying to do with the engine. Just get it running for daily driving or correct restoration???
Down draft tube should be straight down. Plus right side cylinder deflector looks like it is not fitting correctly on the right side of it.
Bus parts manuals are great for both exploded diagrams and numbers/names of parts!
http://oacdp.org/ _________________ In Stereo, Where Available! |
Posted: Thu Dec 29, 2011 7:54 pm Post subject: |
More daily driver and cooling properly. With my carb and svda and pre heat tube set up the stock natzies have already cried foul!
Thanks for the right side deflector heads up; I fixed that and it's snug.
I will check out the link for docs. I have had a major headache getting a 67 Bentley manual in stock from anywhere.
Downdraft tube? Is that a part I am missing? Sorry for the un-informed questions.
I think I need to get 68 style tin and pre heat pickup tube?
I just found awesome powdercoat video series on tin. Maybe that will give me the vocab I am missing _________________ Paul
Posted: Thu Dec 29, 2011 8:25 pm Post subject: |
Down draft tube is the bent tube coming down from the oil filler.
Are you using the stock bus oil bath air cleaner? _________________ In Stereo, Where Available! |
Posted: Thu Dec 29, 2011 9:27 pm Post subject: |
Yes I am. It has the little flap at the very end and the pre-heat tube attaches there. I recently learned to prop that open in the summer and let it flap in the winter (San Diego 'winter')
The oil bath is on the right side on my bus. _________________ Paul
