insipid Samba Member
Posted: Wed Feb 03, 2010 2:34 pm Post subject: Distributor swap |
I am about to swap out my tired 009 for a 019, does it directly drop in the same as 009 spot and position? _________________ ____________________________
73' Fasty
"When I die, I want to die like my grandfather --who died peacefully in his sleep. Not screaming like all the passengers in his car" |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Wed Feb 03, 2010 2:59 pm Post subject: |
Pretty much... just set the engine up on TDC on #1 to make thing easier. Then install the 019, rotate the body so the rotor points to the #1 mark and put the wires on 1-4-3-2 clockwise. Connect your timing light and set the timing to 30 BTDC @ 3500rpm. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Feb 03, 2010 3:11 pm Post subject: |
Issue i am having is i have removed the old one and the clamp however even with out the clamp attached it wont go in past half of the ring in the middle of the dizzy shaft _________________ ____________________________
73' Fasty
mygreenbus Samba Member
Joined: February 14, 2007 Posts: 1154 Location: Palm Coast, FL
Posted: Wed Feb 03, 2010 3:42 pm Post subject: |
insipid wrote: |
Issue i am having is i have removed the old one and the clamp however even with out the clamp attached it wont go in past half of the ring in the middle of the dizzy shaft |
If I understand, the new distributor won't slide but about halfway in?
Try this, assembly lube on the shaft around the o-ring gasket. If that doesn't work, you can sand a bit of the thickness off the new o-ring gasket. Do that carefully and it only take a little. Use 400 grit sandpaper.
The new o-ring is thick compared to the old compressed one. You can reuse the old o-ring on the new dizzy. _________________ '72 Bus |
Posted: Wed Feb 03, 2010 4:19 pm Post subject: |
ok grease did the trick. Anyone have a pic of it installed on their type 3? _________________ ____________________________
73' Fasty
Glenn Mr. 010
Posted: Wed Feb 03, 2010 5:30 pm Post subject: |
insipid wrote: |
ok grease did the trick. Anyone have a pic of it installed on their type 3? |
Member #1009
#BlueSquare |
57baja Samba Member
Joined: April 15, 2008 Posts: 1166 Location: Kaddie Shack Temple City
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Wed Feb 03, 2010 8:08 pm Post subject: |
57baja wrote: |
That's a funky looking installation of ICT linkage. Aren't those carbs on backwards? If not, mine are. Was that done to clear the alternator or something? |
No, that's just how Dave (Blankmange) has them set up on his Square. Mine face the otherway too (like yours). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Glenn Mr. 010
Posted: Wed Feb 03, 2010 8:11 pm Post subject: |
Bobnotch wrote: |
57baja wrote: |
No, that's just how Dave (Blankmange) has them set up on his Square. Mine face the otherway too (like yours). |
If I remember correctly that engine was built by Russ Wolfe. _________________ Glenn
Member #1009
#BlueSquare |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed Feb 03, 2010 8:25 pm Post subject: |
Glenn wrote: |
Bobnotch wrote: |
57baja wrote: |
If I remember correctly that engine was built by Russ Wolfe. |
That was before I got it.
They are turned the other way around now. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Wed Feb 03, 2010 8:39 pm Post subject: |
Before:
After:
Glenn Mr. 010
Posted: Wed Feb 03, 2010 8:40 pm Post subject: |
Russ Wolfe wrote: |
Glenn wrote: |
Bobnotch wrote: |
57baja wrote: |
They are turned the other way around now. |
Okee Dokey. _________________ Glenn
Member #1009
#BlueSquare |
Doctor Samba Member
Joined: November 16, 2009 Posts: 95 Location: Oz Baby!
Posted: Wed Feb 03, 2010 11:16 pm Post subject: |
Whats the benefit of the 019 over the 009? _________________ www.brassmunkymedia.com.au |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Thu Feb 04, 2010 3:45 am Post subject: |
Doctor wrote: |
Whats the benefit of the 019 over the 009? |
better curve than the oo9, plus no more flat spot... swapping out a oo9 for a 019 made a world of difference in a tired 1600 in my square...
oo9 is a quick-fix for a distributor -- they were not meant to be in a daily-driven car; they are fine if you are at WOT all the time, but who is?
plus, I have both of my 019 Screamer's autographed:
_________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Thu Feb 04, 2010 6:35 am Post subject: |
Who is the autograph from? _________________ '72 Bus |
Posted: Thu Feb 04, 2010 7:14 am Post subject: |
GR, (Glenn Ring). The guru of 019 and 010 distributors. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Glenn Mr. 010
Posted: Thu Feb 04, 2010 7:37 am Post subject: |
Russ Wolfe wrote: |
GR, (Glenn Ring). The guru of 019 and 010 distributors. |
I know that guy... he's a jerk. Just ask anyone _________________ Glenn
Member #1009
#BlueSquare |
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Thu Feb 04, 2010 8:25 am Post subject: |
Glenn rebuilt an 019 for me and installed a set of Pertronix electronic points. It made a big difference over the 009 in my 1968cc motor.
_________________ Justin |
cccfabioccc Samba Member
Posted: Tue Mar 09, 2010 4:32 pm Post subject: |
so the 019 is the right distributor for a daily driver? I had to put the 009 back in my car after it caught on fire but the flat spots are killing me. |
Posted: Tue Mar 09, 2010 5:31 pm Post subject: |
cccfabioccc wrote: |
usually, yes -- depending upon what engine you are using in your daily driver... _________________ póg mo thóin
