FreightShaker Samba Member
Joined: November 20, 2007 Posts: 192 Location: Sherman, Texas
Posted: Mon Feb 08, 2010 10:04 am Post subject: Engine pics |
Hey guys I'm getting ready to do some powder coating on my engine.... I searched for engine pics but didn't find to many..... Can I get some pics of everyones engines so I can get some ideas... _________________ 68 Type 3 Square project (needs alot)
69 Clod Hopper glass buggy
01 Dodge Dakota (daily driver)
99 Larson Ski Boat finished project |
Glasser Samba Member
Joined: September 18, 2007 Posts: 1640 Location: Calgary Alberta Canada
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 916 Location: Midlife Crisis, Midwest
Posted: Mon Feb 08, 2010 11:10 am Post subject: |
Nothing special here but knew you were looking for ideas, I used hammered gold rattlecan paint for the tin, black for the rest. No Saints color scheme represented here, just a coincidence. PO drilled so many holes in the shroud I was worried about it's ability to cool the engine, had to do something. Yep, that's one of those transparent distributor caps, hadn't gotten that replace when the picture was taken. I'd advise against using that, not only a poor part but pretty cheesy IMHO. _________________ Gary
Being a cheap old fart is just a front for my actual lack of money. |
Posted: Mon Feb 08, 2010 11:29 am Post subject: |
gr8cobbler wrote: |
Nothing special here but knew you were looking for ideas, I used hammered gold rattlecan paint for the tin, black for the rest. No Saints color scheme represented here, just a coincidence. PO drilled so many holes in the shroud I was worried about it's ability to cool the engine, had to do something. Yep, that's one of those transparent distributor caps, hadn't gotten that replace when the picture was taken. I'd advise against using that, not only a poor part but pretty cheesy IMHO. |
That is exactly the kind of pic I'm looking for.. Nothing fancy on my buggy( to lazy to keep chrome clean) Mine will be like that but yellow and black. I am trying to talk my wife into an exhaust like that.. _________________ 68 Type 3 Square project (needs alot)
laug6615 Samba Member
Joined: November 07, 2007 Posts: 552 Location: Greer, South Carolina
Posted: Mon Feb 08, 2010 11:32 am Post subject: |
Here's the one in my 69 bug and then the one in my Allison Daytona. The 69 is mostly painted and the Allison is all "Bling".
______________________________
Allison Daytona DuneBuggy |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Feb 08, 2010 11:52 am Post subject: |
Actually guy/gals, I hate to burst your bling bubble, but tests have been run, and chrome tins actually make the engine run about 20 degrees hotter.
The chrome reflects the heat back onto the engine, instead of letting it pass through.
The factory chose the right color for their engines. Semi-gloss black is the best for heat dissipation.
VW tried on their first engines with a gray color, but that did not last long. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Mon Feb 08, 2010 11:59 am Post subject: |
Hey Russ what if I powder coat the inside black, and the outside yellow....Any ill effects?? _________________ 68 Type 3 Square project (needs alot)
Posted: Mon Feb 08, 2010 12:01 pm Post subject: |
Russ Wolfe wrote: |
VW tried on their first engines with a gray color, but that did not last long. |
I heard about that. To try and combat against it I painted the underside with a thick layer of flat back to stop the reflection.
So far no heat issues at all. _________________ Brent
My build up http://www.thesamba.com/vw/forum/viewtopic.php?t=265364&postdays=0&postorder=asc&start=0
Project#2. Neighbors build up. http://www.thesamba.com/vw/forum/viewtopic.php?t=327008 |
Posted: Mon Feb 08, 2010 12:13 pm Post subject: |
FreightShaker wrote: |
Hey Russ what if I powder coat the inside black, and the outside yellow....Any ill effects?? |
I would recommend a flat black. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Mon Feb 08, 2010 12:27 pm Post subject: |
Yea I know about the heat issues. Thats why you need to do something to the underside where you can, painted mine flat black and haven't had any issues at all. _________________ Gary
jspbtown Samba Member
Posted: Mon Feb 08, 2010 12:35 pm Post subject: |
FreightShaker, this for a buggy?
If so, go for what you like. They are so open that overheating is really minimized, with a properly tuned engine.
The red engine drove from MA to NC with no overheating issues. The blue engine runs like a top in IL, and the chrome one is happy in Canada. |
Yellermanx Samba Member
Joined: November 04, 2004 Posts: 1242 Location: Florida
Posted: Mon Feb 08, 2010 12:42 pm Post subject: |
Not mine, but an idea!
Posted: Mon Feb 08, 2010 12:49 pm Post subject: |
Holy Crap! _________________ Gary
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76901 Location: Sneaking up behind you
Posted: Mon Feb 08, 2010 12:57 pm Post subject: |
Love it! Your only limit is your imagination! To me thats the epitome of building this type of car.....no limits! |
manxmark Samba Member
Joined: February 24, 2007 Posts: 224 Location: Western Australia
Posted: Mon Feb 08, 2010 3:34 pm Post subject: |
Here's mine. I would agree that the chrome tin makes it run hotter but if you have your fuel mixture and the timing right it doesn't get too hot.
Dinubadave Samba Member
Joined: February 18, 2009 Posts: 490 Location: Dinuba, CA
Posted: Mon Feb 08, 2010 3:46 pm Post subject: |
Here's a couple of my engine, I stayed away from the chrome and used powder coating, actually if it stays fairly clean, I'm happy!
63Fiberbuggy Samba Member
Posted: Mon Feb 08, 2010 3:58 pm Post subject: |
not everyone will agree....my 2-cents, "like the chrome look"....mine doesn't run hot, even in the deep south summers...
jbreddawg Samba Member
Joined: August 31, 2006 Posts: 1242 Location: Raleigh NC
Posted: Mon Feb 08, 2010 6:12 pm Post subject: |
Does this count ?
_________________ The wheel may be turning but the hamster's dead !
fred69vert wrote: |
Enough torque to pull the panties off a nun. |
RCros wrote: |
Sometimes I have more balls than talent. |
chris_parks Samba Member
Posted: Tue Feb 09, 2010 10:49 am Post subject: |
I don't get it. My engine is chromed out to some extent and I daily driver it in the heat in SoCal. No problems overheating.
I sense that it is more important to dissipating heat on larger engines or modded engines. Mine is a 1600DP with dual 44 Webers for a little pick me up. She runs like a champ.
