31swford Samba Member
Posted: Tue Mar 19, 2013 8:49 pm Post subject: |
What is the current best available match for early westy laminates? Castle Oak by Wilsonart? |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Wed Mar 20, 2013 7:49 am Post subject: |
So what glue are you folks using? I see notchbay uses the 3M spray, I used it too and it is awesome. I also have this Dan Tack spray, it is very good glue, fast and strong. I fixed curled corners of a westy cabinet and it worked great. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Wed Mar 20, 2013 8:24 am Post subject: |
I used the roll on kind but I like the 3m Super. There are several places in my 77 that need to be redone. Due to my inexperience using the roll stuff id guess. To much-to little, didnt let it cure....
For me 3m fixes that. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2946 Location: East Northport, NY
Posted: Thu Mar 21, 2013 1:51 pm Post subject: |
This thread is awesome, I'm preparing to embark on the re-laminate project! Thanks for the read! _________________ Mike
1964 Beetle
2001 Eurovan Camper |
Ernie Punkin Samba Member
Joined: August 31, 2014 Posts: 84 Location: Hawaii/B.C. Canada/Seattle
Posted: Thu Jan 08, 2015 5:02 pm Post subject: |
Anyone have experience with these products? It's not too hard to get things shipped from UK so these are an interesting option.
http://nlavw.com/gb/interior/198-westfalia-interior-panel-for-berlin-7-piece-set.html
"Identical reproduction Westfalia interior panels for Berlin 7 piece set.
it is made of 3mm plywood with Westfalia late bay laminate." _________________ 1977 Westfalia "Happy"
Bye Bye 1979 Westfalia ERNIE the REI Bus
Ion Pod Trailer |
PITApan Samba Member
Joined: November 09, 2014 Posts: 1058 Location: Northern Colorado
Posted: Fri Jan 09, 2015 2:31 am Post subject: Re: I wanna be laminated - Best Cabinet Laminate |
BUSBOSS wrote: |
I'm wondering if anyone who has relaminated their cabinets can tell me how many 4X8 sheets I will need to do all of the cabinets and the closet in a 76 Westy. I do not need to include the wall, hatch or door panels in this estimate.
I searched unsuccessfully for the answer.
Thanks in advance! |
two random thots:
WilsonArt is cheaper than Formica (both brands) but slightly lower quality (IMNSHO).
You can get good deals on damaged sheets at big box places. Typically a broken corner or edge. No choices in colors of course but it you want to stretch the regular stuff you are building and would like a white or black table top... |
Posted: Fri Jan 09, 2015 2:35 am Post subject: |
Red Fau Veh wrote: |
So what glue are you folks using? I see notchbay uses the 3M spray, I used it too and it is awesome. I also have this Dan Tack spray, it is very good glue, fast and strong. I fixed curled corners of a westy cabinet and it worked great. |
Weldwood contact cement, rolled on. The solvent based is faster and works better when it's cool out. The water based is nicer to work with and you can clean and re-use your rollers. Buy in gallons. Well sealed both have excellent shelf life. The water based cannot be allowed to freeze. |
eche_bus Samba Member
Posted: Fri Jan 09, 2015 9:26 pm Post subject: |
I'm the other guy here that's installed NLAVW's panels. If you start here http://www.thesamba.com/vw/forum/viewtopic.php?p=7274484#7274484 and skim forward, you'll see them getting installed as different parts of our '76 get overhauled.
I second the comments about Weldwood. It's all I've used on the cabinetry to re-install OG laminate. You'll find quite a bit of detail using it in my build thread. |
DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Mon Jan 11, 2016 9:48 am Post subject: Re: I wanna be laminated - Best Cabinet Laminate |
Hey all,
Quick question...for those redoing cabinets with readily available laminates like Glamour Cherry, are you using standard (thick) sheets or the thinner "vertical grade" stuff? I just did a test over the weekend with 1/8" thick backing and a vertical grade laminate and yielded a few panels with nearly the same thickness as my stock panel (so slotting the new panel at the top on the slider door was easy).
Anyway, just wondering...thanks!
- Doug _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
Busdepot Samba Member
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Fri Apr 29, 2016 8:08 am Post subject: Re: I wanna be laminated - Best Cabinet Laminate |
I believe I already know the answer but, someone will eventually ask you. Are these the ones from NLAVW? _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Fri Apr 29, 2016 8:10 am Post subject: Re: I wanna be laminated - Best Cabinet Laminate |
Good to hear. Now maybe more people will do their buses back to a stock look. What about the driver wall for 74-75? _________________
t3kg wrote: |
1964 1500 S
Posted: Fri Apr 29, 2016 8:28 am Post subject: Re: I wanna be laminated - Best Cabinet Laminate |
Quote: |
I believe I already know the answer but, someone will eventually ask you. Are these the ones from NLAVW? |
Yes, same product.
Quote: |
What about the driver wall for 74-75? |
Not at this time. I could look into it on a special order basis but the lead time would be long (at least 8 weeks). _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
WildIdea Samba Member
Joined: September 17, 2016 Posts: 928 Location: Black Hills, South Dakota
Posted: Wed Dec 14, 2016 3:04 pm Post subject: Re: I wanna be laminated - Best Cabinet Laminate FAQ |
Great thread!
I'm going through my cabinetry myself as my garage isn't heated and it's single digits outside. Everything but the sink is in my house and I'm going through each piece getting it tightened up.
My sage green 1977 bus has all the pieces accept the large table. I may try to find an original but I'm thinking I'll make something custom, may be more fun...
So I'm calling this laminate "sprung" on the corners and I'm basically glueing them back down and repairing chips instead of replacing the entire sections. God bless the folks doing this, it's huge amount of work. For me I'd rather stick with original lam with blemishes instead of perfect lam that is not. Thankfully my bus wasn't too far gone and I'm happy living with its "honest" wear..
Mostly I wanted to share, without sharing picture, which I will try soon, I'm using a high quality super glue made for prepping fossils and glueing rock together. A lot of tape and camps. The smaller pieces that are missing get built up with another fossil prep putty and painted with acrylic artist paint to match the wood grain. You guesses it, the same as fossil prep....I'm clashing my fossil guys into my motor head guys and they're pleased to watch me geak out on the details, but I see by this thread I'm not alone. lol:
I'm preparing to attempt dash crack repairs too, accept with texture transfer molds for the filler. |
Posted: Wed Dec 14, 2016 9:37 pm Post subject: Re: I wanna be laminated - Best Cabinet Laminate FAQ |
I too gained some knowledge from this thread. It gave me the initial info to get started. Without it I wouldn't of thought to relam myself. Now I don't think twice about it and think it no big deal.
Ive recently finished the panels. When I did my first big push to get the cabinets done, I lived in San Antonio and was a week away from moving back to Seattle. So the panels were just stained real quick. This last summer - what 5 years later I got around to the panels But I also finished the westy box and the dash table
Looking good and finished now.
t3kg wrote: |
1964 1500 S
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Thu Dec 15, 2016 8:19 am Post subject: Re: I wanna be laminated - Best Cabinet Laminate FAQ |
Looking good! _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
cv66seabear Samba Member
Joined: February 18, 2017 Posts: 105 Location: Wisconsin
Posted: Thu Nov 09, 2017 6:46 pm Post subject: Re: I wanna be laminated - Best Cabinet Laminate FAQ |
Yes I know this is an old thread - I'm looking at buying veneer from Oakwood Veneer as the cabinets in my 79 Westy are peeling like bananas! (Arizona heat - PO). So I'm wondering if I buy the 22 mil veneer, is that comparable to the old veneer (laminate)? Also:
II'm looking for 2 threads:
the first was step by step how to remove the cabinets and in what order; and the second was a lot about removing laminate (which I thought was this thread)
Does anyone know where these threads are? (I have the worst luck searching for threads.)
Thanks,
Kent _________________ "Not all who wander are lost." JRR Tolkien
1979 Campmobile - "Pancho Verde"
Old Friends - gone now:
1964 Beetle "Liebchen"
Mark 3 Jetta "Liebchen Zwei"
Passat Wagon "Wolf"
2015 Passat Sedan "Rudy" |
Ives676 Samba Member
Joined: June 20, 2013 Posts: 274 Location: Rogers, AR
Posted: Mon Nov 13, 2017 11:48 am Post subject: Re: I wanna be laminated - Best Cabinet Laminate FAQ |
This post has some good info about cabinet repairs and laminate removal:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=260
And this one is good for cabinet removal:
https://www.thesamba.com/vw/forum/viewtopic.php?t=291736
A good tip for searching is use google. If you type site:thesamba.com and then what you are looking for google will only search thesamba.com for relevant info. Much easier than built in search feature of this site. You can also just use key words in the search on google.
Ex: site:thesamba.com bay window cabinet removal
Also if you add bay window, beetle, split window, vanagon, etc. for a keyword you can further narrow down the search within thesamba.com. Hope that helps for the future. _________________ 1974 Riviera - Subaru EJ22
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=630031 |
