I wanna be laminated - Best Cabinet Laminate FAQ
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
kruton
kruton is offline
PostPosted: Wed Jul 06, 2011 9:37 pm    Post subject: Reply with quote
That's one nice lookin interior!
http://www.thesamba.com/vw/forum/viewtopic.php?t=460364
Florida Licensed Solar Contractor
NABCEP Certified Solar PV Installer
curtis4085
curtis4085 is offline
PostPosted: Sat Aug 13, 2011 12:37 am    Post subject: Reply with quote
I found Glamour Cherry from formica it in a Artisian finish or semigloss. My local lumber yard hooked it up.. Its suppose to be close to the colonial cherry. If anybody needs help getting it let me know. My peeps a straight
notchboy
notchboy is offline
PostPosted: Sat Apr 28, 2012 4:36 pm    Post subject: Reply with quote
I wanted to bump this up so 1-people could see cabinets getting refinished & 2 Ill be looking for some Nevamar product here in Seattle to finish my between the seats box, front table and behind the pass seat box.
I did find one palce to get the sheet goods but Im not going to call until Monday.
Anyone else been re-laminating?
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
notchboy
notchboy is offline
PostPosted: Sat Feb 16, 2013 9:37 am    Post subject: Reply with quote
Im needing a piece of late laminate to do a repair on a 76-79 table leaf, just the leaf, so thats like a 2ft by 8in piece?
Anyone out there still have some saved pieces or maybe a piece of orginal cabinet I can remove it from?
Thanks!
1964 1500 S
curtis4085
PostPosted: Sun Feb 17, 2013 2:03 am    Post subject: Reply with quote
Thanks!
Remind me tomorrow and I will look threw my stash. I do have new laminate. Its close but not the real deal.
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
notchboy
notchboy is offline
PostPosted: Sun Feb 17, 2013 6:58 pm    Post subject: Reply with quote
Thanks!
It has to be the real deal brother Cool
1964 1500 S
curtis4085
PostPosted: Sun Feb 17, 2013 8:06 pm    Post subject: Reply with quote
notchboy wrote:
Thanks!
The day got away from me. Will check tomorrow. Small chance I may have large enough section.
Special Thanks to:
BUSBOSS
BUSBOSS is offline
PostPosted: Sun Feb 17, 2013 9:54 pm    Post subject: Reply with quote
I think I have some Nevamar pieces left in the attic. Sounds like you are looking for the og stuff though.
All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
notchboy
notchboy is offline
PostPosted: Sun Feb 17, 2013 10:04 pm    Post subject: Reply with quote
Yes real deal og stuff. Nevamar? Nevermind Wink It needs to be the real deal.
Got table?
1964 1500 S
notchboy
notchboy is offline
PostPosted: Fri Mar 08, 2013 5:37 pm    Post subject: Reply with quote
So I was able to get a panel in good shape and the right size to be able to do a correct restoration to this table.
I took it all apart, stripped the old cracked laminate off, sanded the board all up, filled two voids with bondo, sanded again, took the laminate strip off the doner board, sanded the back of it, coated the laminate and board with 3m spray glue, mated them together, let bond over night, routed the edge next day, cleaned all hardware, put the outside black bumper strip back on with heat gun, put all the hardware back in place....clean with WD-40 and enjoy Cool
Restored.
1964 1500 S
eche_bus
eche_bus is offline
PostPosted: Fri Mar 08, 2013 10:48 pm    Post subject: Reply with quote
Looks VERY good. I'm about to embark on mine that has the same kind of damage but bought a whole new table section piece with perfect laminate to replace it. I didn't have any scrap sections to use for repair like you did, but buying this small table leaf leaves me able to use my old one for small corner repairs elsewhere.
I saw you sanding the underside of the large table section and the underside now looks very good. Did you use anything else to remove the stains from the underside? Mine is pretty badly stained and I was planning to try mineral spirits and have looked into wood bleach, but am worried about harming the laminate accidentally in the process.
notchboy
notchboy is offline
PostPosted: Sat Mar 09, 2013 10:27 am    Post subject: Reply with quote
I sanded it to remove the years of smutz and palm butter - yuck! But it didnt take all of it out and it is "stained" to a certain degree still. No treatment after ward as Westfalia didnt, and if they did it was some kind of oil I bet. Be careful when sanding. You can not go nuts as the ply layers are not all that thick and you can burn through it and expose a lower layer messing it all up.
1964 1500 S
curtis4085
PostPosted: Sat Mar 09, 2013 10:37 am    Post subject: Reply with quote
Super nice job! I need to replate or refresh my hardware and metal table base somehow. Yours lOoks sweet
Special Thanks to:
notchboy
notchboy is offline
PostPosted: Sat Mar 09, 2013 12:11 pm    Post subject: Reply with quote
I think OG is zinc and galvy. I just did a light wire wheel on them to knock the paint and grime off - making sure not to remove the OG coating.
1964 1500 S
Bala
Bala is offline
PostPosted: Mon Mar 11, 2013 11:23 am    Post subject: Reply with quote
Table looks good dude!
1976 Westy
1966 Beetle
Hot Rod Harp
Hot Rod Harp is offline
PostPosted: Mon Mar 11, 2013 12:32 pm    Post subject: Reply with quote
I went a different way...stripped the Formica and am replacing with wood veneer. Classic not plastic. I chose Red Oak and I'm going to stain with Golden Oak. It is on 2'x8' rolls and cuts easy & clean, great stuff.
http://www.rockler.com/product.cfm?page=2213&site=ROCKLER
Also ordered 3/4" black T-moulding 12' for about $18.00.
notchboy
notchboy is offline
PostPosted: Mon Mar 11, 2013 3:35 pm    Post subject: Reply with quote
pics?
1964 1500 S
Hot Rod Harp
PostPosted: Tue Mar 12, 2013 6:36 am    Post subject: Reply with quote
Relaminated Westy cabinets with pressure senstive wood veneer from Rockler.com. I have two days into this project, once the cabinets are covered, I'll stain.
BUSBOSS
BUSBOSS is offline
PostPosted: Tue Mar 12, 2013 4:09 pm    Post subject: Reply with quote
How expensive is that Rockler stuff?
I saw it once and did not like the "compterized pattern) of the wood grain.
1976 Westfalia
notchboy
notchboy is offline
PostPosted: Tue Mar 12, 2013 4:53 pm    Post subject: Reply with quote
Pricey, but nice.
If I were doing a full resto to the 77 then vainer would be the only option. I love how nice you can make that stuff. Looks like Mr. Monopoly's bus for sure.
But alas I took the Plastic-Fantastic route from the 70's. That ways I wont be heart broken when the kids start to booger it up.
Keep us posted!
1964 1500 S
Page 5 of 7
