Bosch SR0408X/409X vs HiTorqueIMI-101 gear reduction starter
Page: Previous  1, 2
wcdennis
wcdennis is offline
PostPosted: Sat Aug 21, 2010 6:46 pm    Post subject: Reply with quote
Here is a follow-up on the WPS starter that I installed in my Subaru conversion.
Initially I was very impressed and totally happy with the performance. It spun the engine so fast that starting was instantaneous and no more sluggish starts when the engine was hot. BUT--last week we took a trip to the beach and after a couple of days camping, we decided to drive to town to have lunch. When I turned the key nothing happened. My first thought was; did I run the battery down? No wait something is running. I realize the starter is whirring away but not engaged with the flywheel. As quickly as possible, I get the battery disconnected. After it cooled down, I pulled the starter and cracked it open. This is what I found:
The plastic collar that connects the lever to the solenoid plunger was melted.
What caused this, I'm not sure, but now we were stranded. Fortunately, I was able to make a temporary fix with a zip tie:
This actually got us home. I bought a rebuilt Bosch starter from NAPA. It was expensive, but hopefully more reliable.
syncrodoka
syncrodoka is offline
PostPosted: Sat Aug 21, 2010 9:34 pm    Post subject: Reply with quote
You have got way more macgyver in you that I do, nice temp fix.
11CAB
11CAB is offline
PostPosted: Fri Feb 25, 2011 4:16 am    Post subject: Reply with quote
You can always use a Subaru reduction starter with this kit
www.crankykits.com.au
boulderdrop
boulderdrop is offline
PostPosted: Fri Feb 25, 2011 10:05 am    Post subject: Re: Bosch SR0408X/409X vs HiTorqueIMI-101 gear reduction sta Reply with quote
tclark wrote:
So looks like my Bosch starter solenoid is on the way out after only 5 years
So when i bought this a back then I found out that http://www.hitorque.com
built a gear reduction starter for amout us$185
and I also see a few co doing rebuild imi-101
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320466104212
any feeds back from any one who bought either of these starter motors ?
particularly the rebuild units ??
I put the HiTorque GVW-IMI-104 in my 84-westy a few years ago when GoWesty still sold them. I've heard that previous models of the HT worked well, but this one did not. It died in about 3 years. When looking for a replacement, I discovered some stuff on GW website and here on the lousy build quality. Last year, I replaced it with a standard OEM Bosch unit and haven't had any troubles. I've still got the HT in my shop and would like to rebuild it to understand the mechanics better of a starter, there's several rebuild threads here (including this one); maybe it's something simple!
== My Rides ==
1984 Westy, Bostig, 3rd:1.14, Locker-LSD, Newly Painted
1980 24' J-Boat
1979 Sears Freespirit Moped
1996 Chev S10 4x4 ZR2
2012 Toyota Camry Hybrid (Wife's)
== How I Pay the Bills ==
Windows FTP Server at http://www.bpftpserver.com (PM for a FREE one)
wbx
wbx is offline
PostPosted: Fri Feb 25, 2011 10:29 am    Post subject: Re: Bosch SR0408X/409X vs HiTorqueIMI-101 gear reduction sta Reply with quote
boulderdrop wrote:
I put the HiTorque GVW-IMI-104 in my 84-westy a few years ago when GoWesty still sold them. I've heard that previous models of the HT worked well, but this one did not. It died in about 3 years. When looking for a replacement...maybe it's something simple!
http://www.thesamba.com/vw/forum/viewtopic.php?t=384710
Here is my rebuild that i did for the IMI-104 in my '84. It would be cool if you cracked it open and saw if it were a similar problem... My starter has been working 100% since the rebuild.
'84 Westy (first owner).......but my daily driver has pedals
My "perspective" mantra:
A Volkswagen Vanagon is just a material thing,
As such, it is of the earth,
And if i need to, I can let my Van go.
dkonzy
dkonzy is offline
PostPosted: Wed Jun 05, 2013 1:31 pm    Post subject: Starter Reply with quote
I finally found a core to use to upgrade my starter to the TDI SR0408X with the Westy Ventures adaptor.
Wondering if there is a reliable source. What I DONT want is to go through all this trouble to end up with a poorly reman unit... Is there any way to tell what is Bosch reman vs any others?
Also, looks like the 409 has .2kw more power. Is that the case?
Thanks!
tclark wrote:
wcdennis wrote:
Here are some photos of the eBay WPS SR0408X starter and WestyVentures adapter:
Just FYI that is not a SR0408X
http://search.waiglobal.com/partsearch/partsearch.aspx?part=SR0408X&Submit=Go
its a SR0409X 2Kw
http://search.waiglobal.com/partsearch/partnum.aspx?part=2-1974-BO
the SR0408X is this one 1.8Kw
http://search.waiglobal.com/partsearch/partnum.aspx?part=2-1890-BO
and FYI again buffbuh bought the 2-1890-BO
might not make a diff in build quality but he did not buy the exact same unit
1987 Syncro
Page: Previous  1, 2
Page 2 of 2
