19typethree67 Samba Member
Joined: April 18, 2007 Posts: 351 Location: Grand Rapids, MI
Posted: Thu Feb 18, 2010 1:34 pm Post subject: Engine Lid Insulation |
Any recommendations for the insulation on the engine lid? I saw this on Secondskin's website, looks pretty slick but it's 3/8" thick, the open cell foam motormat is 1/2" thick. Will this be too much? I took a measurement and it appears that there is about 1/4" to work with, wondering if this foam will compress enough when I put the clips in.
Bobnotch Samba Member
Posted: Thu Feb 18, 2010 7:23 pm Post subject: |
Are you looking at using that on the bottom side of the lid or the top? If the top, I don't see a problem. On the bottom, I'm not too sure I'd use it, due to it being a rubber based foam. The original material was a fiberglas batting like material, that is basically fire resistant, covered in thick aluminum foil. Right now, there are several people looking for a replacement for the foil, as that's what normally goes first. If anybody has a good solution, I'd like to hear it, as my own car could use a replacement foil section. I have thought about that insulated fiberboard stuff, but there's no way I'd use up a 4 by 8 foot sheet. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
pedro sainz Samba Member
Posted: Thu Feb 18, 2010 7:38 pm Post subject: |
i got this IDEA from Lee Hedges
Home Depot sells wrap around insulation for Water heaters _________________ 68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There |
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4030 Location: Deep In My Own Psyche
Posted: Thu Feb 18, 2010 7:49 pm Post subject: |
home depot
insulation s
that looks like bubble wrap with aluminum foil
get some aluminum tape and it will work fine _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
Posted: Thu Feb 18, 2010 8:09 pm Post subject: |
sharkskinman wrote: |
home depot
insulation s
that looks like bubble wrap with aluminum foil |
I AGREE
but there's nothing else for NOW
is a MUST have item because there is SO much HEAT
you can tell when you place anything over the lid _________________ 68 T34 1600 Automatic
N.O.N.A member #3
Posted: Thu Feb 18, 2010 8:14 pm Post subject: |
and it will work fine |
I'm using tape now
to hold the old one
together for now. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
reay Samba Member
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Posted: Thu Feb 18, 2010 11:08 pm Post subject: Re: Engine Lid Insulation |
19typethree67 wrote: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=375631&highlight=engine+lid _________________ 68 T34 1600 Automatic
N.O.N.A member #3
Posted: Fri Feb 19, 2010 10:47 am Post subject: Re: Engine Lid Insulation |
pedro sainz wrote: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=375631&highlight=engine+lid |
Yeah, I saw that thread I just wanted to know more about this particular heat shield. Probably should have had a more specific title .
Skinman - nice job on yours, I liked the Home Depot approach!
The one I have in the pic is a "Motor Mat" from Second Skin Audio and designed to withstand 500F plus quite a bit of sound deadening, I was talking about the inside portion (directly on top of the motor). But now I'm thinking that maybe that's a little overkill, especially if I plan to put a little sound dampener on the interior portion of the lid/truck area. I think I will take a trip to the Depot this afternoon
Thanks fellas |
Ottonotch Samba Member
Joined: February 14, 2008 Posts: 102 Location: Chicago
Posted: Fri Feb 19, 2010 12:22 pm Post subject: |
O.K. mine has nothing on it at all,maybe removed by p.o.? its clean and just painted black. Wasnt sure if its really needed,but sounds like its a must.Home Depot variety looks good to me. _________________ '63 gulfblue notch
'67 13 window deluxe |
reay Samba Member
Posted: Fri Feb 19, 2010 12:49 pm Post subject: |
I was a little skeptical of water heater insulation, just because of the temp rating - maybe 140 degrees? _________________ Tom Reay
Da weiss man, was man hat!
68 Karmann Ghia Sunroof / auto T345
66 Standard Microbus T221
66 1200a Standard 115 with factory ragtop |
MOCHABILL Samba Member
Joined: June 12, 2008 Posts: 584 Location: BY THE BAY
Posted: Fri Feb 19, 2010 3:03 pm Post subject: |
Under my engine cover all the fiberglass had fallen into the engine,it was every where! I just applied the Dyna-mat plus to the under side.
The topside is still the OG cardboard,just cleaned off all the greasy buildup and sprayed on clear coat Krylon,looks like new,almost!
Bill _________________ '71 Squareback FI
'07 Passat wagon 2.0
'03 Ranger 4door 4.0 |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Sat Feb 20, 2010 11:22 am Post subject: |
Ok, that's what I used under my pressboard on the floor of my 71 Notch, and under the carpet (in the rear) of my 65 Notch. I was just wondering if anyone had found a thick foil to use as a replacement for the old stuff. My insulation is still really nice and in good shape, but the foil has seen better days. I might have too use some of that 22 gauge aluminum I have here, and fake it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Feb 20, 2010 2:32 pm Post subject: |
http://www.mcmaster.com/#thermal-insulation/=5wk25w
One option Bob; alum foil backed insulation half way down. .033" thick. _________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
nodrenim Samba Member
Joined: October 06, 2006 Posts: 843 Location: Dobson, North Carolina
Posted: Sat Feb 20, 2010 4:53 pm Post subject: |
I made a new cover for the insulation on my sqb from aluminum flashing used by roofers and contractors. It comes raw or painted, true you may need to flatten it as it comes in a roll, but golly-gee whiz it sure does work good and will not bankrupt anyone. Just my 2 pennies! Good luck! |
Lee Hedges Samba Member
Joined: November 09, 2000 Posts: 811 Location: San Diego
Posted: Fri Mar 05, 2010 8:36 pm Post subject: |
Here's the engine lid restoration for a 1963 T34 Coupe that I did for about $25 via the Home Depot aluminum insulated roll. The roll did two engine lids and doesn't look at all like bubble wrap. The only difference from original is this pattern is a square while the original is a diamond. Spray glue over the edge for the 1963-64 models and tucked inside the lip for 1965-69 models. Silver/aluminum spray paint for the handles & clips gives the "new look" again and is very easy to do. The whole process took less than two hours.
Posted: Sun Jul 04, 2010 7:10 pm Post subject: |
Finally got mine done a few weeks ago. Checked out the stuff from Home Depot and I was a bit disappointed. Mostly because it was like 20 or 30 feet long and since I only had to do the one lid, it seemed like a bit of a waste.
Decided on this stuff from Second Skin. Two layers of foil w/ the insulation/sound deadener in the middle.
Really like it so far, I think it quieted the engine noise a little from the inside.
