doubledoor64 Samba Member
Joined: September 23, 2003 Posts: 1073 Location: Ideeho
Posted: Fri Feb 19, 2010 7:43 am Post subject: Chainsaws |
Getting a new house (mine finally sold). It's got some trees I need to cut down, as well as 2 fireplaces (one wood burning insert) that I will use to help heat the main level. So I will be cutting my own firewood. Does anyone have any recomendations on a saw? Brand? bar size? right now I am looking at a Stihl 18" 45cc and a 18" 38cc Husky. I want to buy one saw and have it last, post your thoughts, recomendations, and stories |
kaiser Samba Member
Posted: Fri Feb 19, 2010 7:51 am Post subject: |
from what i have seen and heard husky's last longer. |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Fri Feb 19, 2010 8:22 am Post subject: |
Ive got two Huskys.....a 55 rancher and an older 60cc model 55 has an 18 inch bar and the 60 has a 16. The 60 I have had for about 22 years....the 55 about 6. I will take the 60 anyday over the newer 55. much more power....that thing eats through trees, although there is really nothing wrong with the 55 if it was your only saw. very happy with them. _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Fri Feb 19, 2010 8:43 am Post subject: |
I've had a 55 rancher with an 18" bar for about 5 years now and put it through hell. Before that I purchased a cahin saw from sears and managed to burn it up in a couple of days cutting mesquite.
Only problems with the Husky were of my own making by hitting the dirt, replaced two chains. The forest service uses Stihls and I've heard from a friend that they are just as good. Either way you can't go wrong. |
seanboy69 Samba Member
Joined: October 22, 2008 Posts: 1107 Location: Templeton PA
Posted: Fri Feb 19, 2010 9:36 am Post subject: chainsaws |
Hey I have been cutting wood for years. I have a large woodburner as our only source of heat. And here in PA it gets cold!!!! I have had many different saws in the past. BUT the best one is a Stihl farm boss. It has a 20 inch bar. I had a Huskey an HATED it. Trust me you will never cut as much wood as I have.....lol _________________ In a sea of american muscle there is alittle bug hiding in the corner...
Oh, and I am 39 years old.....I am supposed to know better......ha!!!
1956 oval ragtop
1962 baha
2276 in progress |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Fri Feb 19, 2010 9:44 am Post subject: |
Both are good running long lasting saws...
Husky:plastic body and components,has to be handled like a sports car
Stihl : hardcore body rugged saw...pickup truck style
Huskys are lighter than Stihls,which makes a difference on along day and if your mindful of your equipment it will standup in the woods...if yer a tool thrower,buy a stihl... |
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1561 Location: stoughton, WI
Posted: Fri Feb 19, 2010 9:55 am Post subject: |
FWIW up in Canada at the cabin its a Stihl, leave it up there and only use it for a week or two a year, always starts, always runs great.
At the rental center I used to own we bought a bunch of Husqvarna, and for rental they were junk. we switched over to Stihl, no problems. _________________ Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com |
Vanhag Samba Mortician
Joined: June 29, 2003 Posts: 2606 Location: Desert Coast
Posted: Fri Feb 19, 2010 10:01 am Post subject: |
I worked in the Forest Service for a couple of years. Stihl and Husqvarna were the 2 brands used. On my patrol rig I had a Husky. It rocked. Always started, ran strong. On the engine we had some Stihls and some Huskys.
If I was to buy another saw it would be a Stihl 044 with a 24" blade (i think they call it a 441 nowadays). The 044 (about 70cc) seems the right amount of power to cut through 2 and 3 foot logs but yet light enough to carry around for 8 hours a day. If I was just doing a couple of cords of wood a year and trimming trees then I may go with a smaller saw like a 300 series.
What you don't want is an underpowered saw. You also don't want a saw that is too big and heavy. And underpowered saw will tired you out because you'll have to sit and grind away at things for a long time, not enough power to cut through the big logs. But get a saw too big and you'll have an unweildly machine with a huge head that will tire out your arms. I loved our 066 that we used for cutting down big arse trees, but it was heavy, not good for brush work or cutting line. Don't get me started on the 088, it'd cut through china but was heavier than an elephant.
Either Husqvarna or Stihl will work. Both are great saws. Keep it lubricated, keep it clean, and keep it sharp. Take time to learn how to hand sharpen a chain. A sharp chain will increase your cutting power 10X. Even the best saw with a dull chain can't cut worth crap. _________________ CU05 w/HBB
HOODRIDANCE |
Posted: Fri Feb 19, 2010 10:38 am Post subject: |
Buy a spare chain too.. Oregon is a good one...and dont forget to turn your bar over once in a while.. |
Madtat Samba Member
Posted: Fri Feb 19, 2010 11:13 am Post subject: |
For a "SERIOUS" investment you can' go wrong with ECHO. Theese chainsaws are certified to the highest level (Professional Use and not occasional use) I suggest the CS 330 MX4 - 32.6cc's!!! 14 inch bar, now around $350.00
Like a hot knife through butter.......or anything else. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Feb 19, 2010 11:15 am Post subject: |
Madtat wrote: |
Were they tested by Jason? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Madtat Samba Member
Posted: Fri Feb 19, 2010 11:19 am Post subject: |
Russ Wolfe wrote: |
Madtat wrote: |
Were they tested by Jason? |
LOL....one never knows does one? |
Bart Samba Member
Joined: March 18, 2002 Posts: 2516 Location: Chapel Hill, TN
Posted: Fri Feb 19, 2010 1:54 pm Post subject: |
Stihl and a sharp chain. A shitty saw with a sharp chain is going to cut better than a high dollar saw with a dull chain. _________________ http://www.sundial-camper.com |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Fri Feb 19, 2010 2:34 pm Post subject: |
ECHO
Don't get a small bar. Those tiny chainsaws are really dangerous.
Make sure you use some safety equipment. A shield for your face, ear plugs and some Kevlar chaps are a good idea. _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Fri Feb 19, 2010 3:35 pm Post subject: |
I've used a Husqvarna 257 for the last 15 years or so, before that I had a Sachs Dolmar (sp?) for about 10 years.
I cut a bunch of wood every year..........
Thats over 20 cord ^^^^^ _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
TimGud Samba Member
Posted: Fri Feb 19, 2010 4:11 pm Post subject: |
crukab wrote: |
Thats over 20 cord ^^^^^ |
You either have a log splitter or are one bad ass mofo. |
Posted: Fri Feb 19, 2010 4:26 pm Post subject: |
TimGud wrote: |
crukab wrote: |
now that's funny |
Faustuss Samba Member
Joined: September 23, 2008 Posts: 206 Location: California
Posted: Fri Feb 19, 2010 5:11 pm Post subject: |
The newer Husqvarna's are much lower quality than their aged predecessors. A company training rep told me early last year that it was a price point, that they were being made cheaper and sold cheaper to be a midway between the echo's and stihl's, and the products in the Craftsman/Homelite category. That being said if you can get an old used Husqvarna then go for it, those ones are great. Also bear in mind that Poulon is owned by Husqvarna, and the two saw types are fast becoming indistinguishable. They even share parts these days. Poulon by the way is the only (current) source of Craftsman branded saw's, so you can see where Husqvarna is headed.
Stay away from the Craftsman stuff, their current commercial offering (the only worthwhile one) is being discontinued I've been told, though judging by how few of them I have had to repair it must be a decent saw. Don't get any saw made by MTD. Ever. The company is not afraid to discontinue parts despite the law that that says they need to keep making parts for at least 7 years.
Homelite is another middle quality brand, I don't have any major problems with them, they are just more along the lines of Poulon in quality, though getting parts for em can be a pain in the butt.
Stihl and Echo are the better saw's on the market, they haven't had to compromise their quality yet.
As far a saw maintenance is concerned, always always always sharpen your chain. Never run a saw with an even remotely dull chain. A dull chain is probably the second most retarded thing that my customer's send their saw in for, not because they want it sharpened but because they don't know why their saw won't cut.
The single stupidest thing my customers do is use stale fuel. 2 stroke mixed fuel will start to degrade in about a month. It can begin in as little as 2 weeks in some cases. Bad fuel can rot your fuel lines and carburetor, leading to costly repairs and bad words spewed at your local repairman. Stale fuel even if it isn't rotting your fuel line will cause the unit to smoke, or run poorly. You can tell your fuel is bad if it smells like syrup, rotten apples, turpentine or anything other than the gasoline in the fuel tank of your regularly driven automobile. Oh and dump your gas out of the saw when you are done with it. That storage time is when most of the damage occurs. Don't leave it in the sunlight either, especially if it has a clear fuel tank. Sunlight kills gasoline.
Despite having fixed somewhere in the range of 5000+ chainsaw's I haven't seriously cut wood with one since I was a kid so I can't really offer any bar length tips. I think having several sharp chains with you would be a good idea, then you can swap em out easy before the saw has a chance to vapor lock on you. You can sharpen em when you get home. _________________ What was done to me created me. It is a basic principle of the universe.
1967 type 1 |
faster Samba Member
Posted: Fri Feb 19, 2010 8:05 pm Post subject: |
I have a old poulon 18" thats still running strong after 15 years only replaced the rope once and this year bought a new bar. I think if you take care of it and now how to use it even a cheap saw will last for someone cutting three or four big trees a year. As far as keeping the chain sharp I keep a file with me and touch it up in the field when needed. One more thing to remember is Never loan your saw to a neighboror anyone else. _________________ My 59 panel plus 36hp valve covers http://s122.photobucket.com/albums/o265/faster50/59%20panel/ |
crukab Samba Chef
Posted: Fri Feb 19, 2010 9:08 pm Post subject: |
TimGud wrote: |
crukab wrote: |
Oh Fuk no, I have a splitter for sure
Plus :
I buy log length _________________ Tom
My Pops:
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'11 Jetta Wagon |
