theadventureneverends Samba Member
Joined: December 24, 2009 Posts: 585 Location: Gig Harbor WA
Posted: Fri Feb 19, 2010 2:11 pm Post subject: Westfalia front table where do you stow it? |
Aloha
It looks like our first overnight surf trip. I have not found an ideal place to store the front table.
I tried the cushion above the engine compartment one more thing to move. I tried behind the drivers seat one sharp turn and it slid out and nailed my wife's knee in the cargo area. As of now I have it wedged in between the cushions up top.
It seems the Germans would have had the ideal place to stow it?
Where do you keep yours?
Thank you
John |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Fri Feb 19, 2010 2:21 pm Post subject: |
I keep mine under the cushion in back.
I am interested in a better spot too... _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
r39o Samba Polizei
Posted: Fri Feb 19, 2010 2:22 pm Post subject: |
On top or below the engine cover cushion. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Vanagonner Samba Member
Joined: September 15, 2009 Posts: 506 Location: Broomfield Colorado
Posted: Fri Feb 19, 2010 2:23 pm Post subject: |
Behind the driver's seat, and there is no way it can slide out on a turn.
I store it with the top's long edge down on the seat pedestal, the top's surface against the back of the driver's seat. The table base points to the rear of van. The table pipe or stem is also between the driver's seat back and the end of the kitchen cabinet, located in it's normal table making spot, just inserted so that the stem goes behind the driver's seat. The stem prevents the table from moving, because the protruding base of the tabletop is caught between the mounting stem and the kitchen cabinet. You have to pull out the table base pipe and assemble the two pieces that way for transport, but it is no big deal. _________________ Sage
'82 Westy 1.6 D
the mighty n/a
madspaniard Samba Member
Posted: Fri Feb 19, 2010 2:24 pm Post subject: |
Ben the canadian came up with a good system to keep the table up against the ceiling over the rear bench/cargo area _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Fri Feb 19, 2010 2:25 pm Post subject: |
Vanagonner wrote: |
I store it with the top's long edge down on the seat pedestal, the top's surface against the back of the driver's seat. The table base points to the rear of van. The table pipe or stem is also between the driver's seat back and the end of the kitchen cabinet. The stem prevents the table from moving, because the protruding base of the tabletop is caught between the mounting stem and the kitchen cabinet. You have to pull out the table base pipe and assemble the two pieces that way for transport, but it is no big deal. |
That's what I do as well. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
winstonrodney Samba Member
Joined: February 17, 2010 Posts: 25 Location: Wheat Ridge, CO
Posted: Fri Feb 19, 2010 2:33 pm Post subject: |
We keep ours in the storage bay under the rear bench. Word of warning though, if it's off-kilter it can jam against the release mechanism. And I can tell you from personal experience, that's a PITA to open up when jammed.
I just make sure it's nice and snug off to the side of the mechanism and that it can't slide over. |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Fri Feb 19, 2010 3:03 pm Post subject: |
Unless it is secured securely (double something) it or anything up there can become a projectile. I keep mine on the passenger seat and sorta have a desk there. It works for me because I'm only me and I've got my seat! Mine was behind the driver's seat but right now I have my winter fluids, eqpt there.
Now that I can swivel the passengers seat I could most likely leave it set up as a side table when moored. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Fri Feb 19, 2010 3:12 pm Post subject: |
We gave up using two tables a long time ago. I wonder how many others have made this choice? |
pighamling Samba Member
Joined: November 30, 2007 Posts: 67 Location: Southern NM
Posted: Fri Feb 19, 2010 3:16 pm Post subject: My carport |
I don't bring that one with me to camp. |
Californio Samba Member
Posted: Fri Feb 19, 2010 3:43 pm Post subject: |
I keep mine in the garage. Put that table in, with the jump seat, no place to move. |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Fri Feb 19, 2010 3:56 pm Post subject: |
The bungee cord clips on the back of the cabinet and holds the table nice and snug. The arm rests on top holding the table top down with a bit of pressure. _________________ -- 1987 Westfalia automatic (Captain Vino) |
chimivee Samba Member
Joined: September 23, 2009 Posts: 741 Location: Orange, CA
Posted: Fri Feb 19, 2010 3:58 pm Post subject: |
Front table mounted in back; Back table left at home. _________________ -James
86 Syncro Westy, etc |
Posted: Fri Feb 19, 2010 4:05 pm Post subject: |
Perales wrote: |
The bungee cord clips on the back of the cabinet and holds the table nice and snug. The arm rests on top holding the table top down with a bit of pressure. |
Aloha
That's how mine was until it came flying out. Bungee cord perfect solution.
Thank you
John |
whynotvw Samba Member
Posted: Fri Feb 19, 2010 4:42 pm Post subject: |
in garage or storage, lol |
danfromsyr Samba Member
Posted: Fri Feb 19, 2010 4:49 pm Post subject: |
mounted to the pass seat pedestal, and stowed insitu behind it..
can also squeeze just between the seats from there. or stowed under the back bench.
Mom's 86 came with a mount similiar to Ben's overhead out back.. but i'm leary of overhead objects. _________________
Abscate wrote: |
sc-surfer Samba Member
Joined: May 16, 2005 Posts: 865 Location: Santa Cruz, CA
r39o Samba Polizei
Posted: Fri Feb 19, 2010 5:55 pm Post subject: |
FYI: Please remember the early ones have a tube on the bottom. Later, after 84, is flat. I am happy my early 85 has flat on the bottom. So some solutions will not work for everybody. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
DAIZEE Samba Member
Posted: Fri Feb 19, 2010 5:59 pm Post subject: |
main table is the one that gets in my way all the time and I just can't tighten it so it doesn't move. Think I'll take it out and either stow it or take it right out. I've taken my upper berth cushions out as I wouldn't use them anyway and this way they stay in shape. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
Posted: Fri Feb 19, 2010 6:05 pm Post subject: |
Simba'sWestyWings wrote: |
...I just can't tighten it so it doesn't move. .... |
I added a small catch I found at West Marine to hold it back against the wall. Saved my table from the trash heap as I couldn't stand it swinging back and forth. Not sure of the part number, but I could find it. Works great. _________________ '89 Syncro Westy
Catalog of Vans at SDM 2010
Westfalia, Syncro & Tristar Reproduction decals here.
* * * Coming Soon: Washable seat covers for westy bench seat...keep the pets off the upholstery! * * * |
