Gauche1968 Samba Member
Posted: Mon Feb 22, 2010 4:57 pm Post subject: |
Nice wheels, steelhead. Where did you score those? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
ANGOVAY Samba Member
Posted: Tue Feb 23, 2010 9:59 am Post subject: |
I put on the Yoko Geolandar ATS 215/65/16 becasue of the 98 load rating.. I had the Hydros 215/60/16 and my GPS reported the mph almost perfect (1-2mph off). I wasn't worried about the rotation and mph difference just wanted a better snow and light offroad tire. I now rub the front tires if I come up to hard or fast on a curb. I'll be looking at some springs soon. I also put on new shocks at the same time.
I really like them, they are quiet, and have a more agressive tire pattern then the Hydos and I can cross rotate them.
This may be dumb question I'm pretty sure my spare is still 14" ( l know I need to check) -- Can I use it in an emergency for a short distance? _________________ Mark
90 Westy 1.8T Sold
2016 Sprinter Field Van |
Jon_slider Samba Member
Posted: Tue Feb 23, 2010 10:16 am Post subject: |
> hankook ventus v4 es. I have a 225/55/16 load rating of 99.
do you have a link? I cant find that size. The one I found is DIRECTIONAL though. Dont any of you worry about having a working spare in rotation?
I would never run a 14" spare with 3 other 16" wheels, but thats just me. Im kind of particular about tire rotation, including the spare, its a Syncro thing.
It is clear to me, that people using directional tires, dont rotate their spare.. Probably fine for all the posters in this thread, who seem to be 2WD van drivers
I would use AAA Premier instead, 4 tows a year, up to 100 miles each... |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Tue Feb 23, 2010 10:51 am Post subject: |
ANGOVAY- I'm going with my 14 as spare for 2wd. From my research, it wouldn't cause problems with the spider gears for shortish distances, though I wouldn't want to go hundreds of miles. No matter which tire went flat, I would probably try moving the spare to one of the front tires and seeing how that drove/handled.
Gauche1968- Thanks, found those rims on craigslist for $200. Called "swings" and they were put Audi A4s and some VW passats. Took the usually modification to make them fit, but I like. _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
j_dirge Samba Member
Joined: August 08, 2007 Posts: 4641 Location: Twain Harte, CA
Posted: Tue Feb 23, 2010 12:16 pm Post subject: |
Jon_slider wrote: |
Its all kinda relative..
I have 4 14" tires now.. so I can use them as disposables if need be. Kinda like those silly space saver spares standard issue on so many cars.
But running a 25" spare with 3 29 tires would not only look absurd, it would make for some slow going. Right now my 29" spare rides inside the van.
I have been advised that my directional tires can be run backwards.. BFGs RLTs are inside/out directional.
and have been advised that many directionals can be run backwards as a spare for lots of miles without dangerous wear or risk of failure.
I am not advising anyone to do that (for obvious reasons).. just that I think some of this directional stuff is a bit overblown. YMMV.
We have much much more room to play in 2WD land.
But if I had a syncro I'd be planning a decoupler install. _________________ -89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote: |
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Gorge Runner Samba Member
Joined: February 24, 2008 Posts: 199 Location: Portland, OR
Posted: Tue Feb 23, 2010 12:48 pm Post subject: |
j_dirge wrote: |
I don't worry about too much either. After all, you could just have a spare of similar diameter and width that wasn't a directional tire and use it until the flat could be repaired.
Marc _________________ 91 Carat
EJ205 WRX |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Thu Feb 25, 2010 4:42 am Post subject: |
Okay, I may have found something here,
The Falken 912s in the 215/60-16 size ARE XL rated, so that 99 load index does not need to be downrated.
Specifically, the DT website shows the tire size as
215 - 60R - 16 99H XL B
Unless I'm missing something, these meet the requirements, right?? _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
klucz Samba Member
Joined: February 14, 2006 Posts: 1062 Location: Chicago, IL
Posted: Sun Mar 28, 2010 5:26 pm Post subject: |
Quote: |
>(nokian WRG2) 225/60R 16 XL 102V. The diameter is around 26.5" (780 rev/mi),
which is 5% taller than stock. And these tires are directional, meaning you cant cross rotate, and that also means you need 2 spares (or might have to run the spare backwards.. forget about 5 tire rotations, you cant with directional tires) |
WR G2s are non-directional and can be cross-rotated. The older generation WRs were directional though. _________________ 84 Westy 4spd sold |
Vanagonner Samba Member
Joined: September 15, 2009 Posts: 506 Location: Broomfield Colorado
Posted: Sun Mar 28, 2010 8:44 pm Post subject: |
225/75-16's are the standard commercial truck (Ford E350) tire size. They are available in high weight ratings. 215/75-16's are not made in as high a weight rating IIRC.
Example-
B.F. Goodrich Commercial T/AŽ All Season
LT225/75R16/E 115/112Q BSW 67515 6 - 7 8.8 ON 6 Dia-29.4 revs/mi-707 max. load 2680@80psi _________________ Sage
'82 Westy 1.6 D
the mighty n/a |
Zero419 Samba Member
hiram6 Samba Member
Posted: Mon Mar 29, 2010 6:27 am Post subject: |
hiram6 wrote: |
Unless I'm missing something, these meet the requirements, right?? |
Hey, I'm quoting myself!!
I now have these Falkens mounted on a set of the Mercedes CLK wheels. I give them a hearty endorsement! No noticeable road noise, nice solid ride without being harsh. No noticeable sidewall flex, they seem to be perfectly happy with the weight of my 2WD Westy.
BTW, they are indeed XL rated. The tire decal clearly identifies them as 99T load rated, and XL rated for Extra Load. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
Masta Shake Samba Member
Joined: October 29, 2010 Posts: 198 Location: San Diego, CA
Posted: Sun Jul 03, 2011 9:05 pm Post subject: |
Love my General Grabber AT2 (215/70R16) on the Syncro Westy. Quiet, great grip in snow. 99 load rating. On CLK wheels I powdercoated black. Cheaper than the BFGs also!
_________________ As a good friend told me when I got the Syncro: "Welcome to the an intense love/hate relationship".
insyncro Banned
Posted: Mon Jul 04, 2011 7:30 am Post subject: |
syncrodoka wrote: |
Quote: |
What abut the Michelin Hydro Edge ? |
Those are the tires that GoWesty sells with their rim/tire package that the OP wanted to avoid. |
Thumbs down on that tire as the OP has already stated.
POS |
thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Mon Jul 04, 2011 9:10 am Post subject: |
I am broke--I'm mounting the tires from my lhs sedan on my 16 ronals--goodyears-they have a shorter sidewall and stand 25.5" tall--same as oe vanagon--having to spend over 100.00 for a tire is retarded.
one of the vanagon flaws-- jag brakes inside-- 16s will be the new standard for those tired of the sidewall games. |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Mon Jul 04, 2011 10:35 am Post subject: General Grabber AT2 |
Do the General Grabber AT2 rub at all? How much room do you have? |
Posted: Wed Jul 06, 2011 4:01 pm Post subject: Re: General Grabber AT2 |
rmcd wrote: |
I edited the size. They are 215/70R16.
No body rubbing whatsoever but I do have a 2" GW lift. The point where there would be a problem is on the trailing arm and I have about 3/4" clearance there. The offset on the wheels is what makes it all work. It is an ET37 wheel (CLK alloy). _________________ As a good friend told me when I got the Syncro: "Welcome to the an intense love/hate relationship". |
epaddler Samba Member
Joined: July 18, 2010 Posts: 222 Location: Slippery Rock
Posted: Sun Sep 25, 2011 6:25 am Post subject: |
Masta Shake wrote: |
I'm in search of some CLKs and narrowing down my tire choices. I am leaning toward the Grabbers, so I'd like to know your opinion about the power loss going with the 215/70/16s (28.1 inches, 742 revs per mile), vs. dropping down to a 215/65/16 (27 inches, 772 revs per mile). Opinions really seem to vary on this point. Some suggest that it's actually better to make a more radical change to essentially change your gearing to a three speed with an overdrive, rather than going with a smaller change, which steals power without enough of a gearing change to change how you drive. I'm driving a syncro Westy as well, powered by a 2.1 wbx, for now. I'll be dropping either a Subie 2.5 in or a Tencent 2.1 within the next 18 months, which should give me adequate power for the larger tires, but I don't want to hamstring the van too badly until then. I'm living at only about 1,300 feet of elevation, but head to the high places each summer.
Not sure about your engine Masta Shake, but are you happy with that size tire, or if you had to do it over, would you have dropped down a size? _________________ 1989 Syncro Westy
My build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=450246 |
Posted: Sun Sep 25, 2011 9:35 am Post subject: |
the "three speeds plus overdrive" theory is new to me. IMHO, where the tall tires have the biggest negative impact is off the line. Cruising, mtns, etc...all fine. The more "radical" change to really tall will be felt at every stoplight. Like molasses in winter... _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
Posted: Sun Sep 25, 2011 10:39 am Post subject: |
Steelhead wrote: |
the "three speeds plus overdrive" theory is new to me. IMHO, where the tall tires have the biggest negative impact is off the line. Cruising, mtns, etc...all fine. The more "radical" change to really tall will be felt at every stoplight. Like molasses in winter... |
From another 16-inch tire thread:http://www.thesamba.com/vw/forum/viewtopic.php?t=233666&postdays=0&postorder=asc&start=100
Loogy wrote: |
. . . a couple of months ago we took a trip and had the van pretty darn loaded up. The van was loaded with two adults, four teenage kids, three dogs, three bikes and roof rack/interior loaded with enough supplies and gear for a week for all of us. I experienced no issues whatsoever. Were we a little slower than usual? Of course, but being able to have the RPMs up a little, driving in third gear at a constant 60 mph up the hills and not having to drop my speed to 45-50mph and shift from fourth to third (as I would have had to do with the stock diameter tires) on those hills was really nice. And that's with the tall roof-top carrier and three bikes up there.
In other words, the increased diameter of the tires shifted the usable RPM range of third gear (specifically) to a point that it is much more usable on the freeway. Fourth gear becomes much more like an overdrive type thing. The gear change split (actually more like the usable RPM/shift point change) around town is also very welcome. Like J_dirge said, the only thing that would make it nicer would be a lower first gear, but I think I have that covered...when I find the time.
Like I said, I'm not trying to convince anyone that this is the right way to go for them, but for me, it works perfectly and I love it. |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sun Sep 25, 2011 2:44 pm Post subject: |
Here's my take on it, and just my opinion! Different strokes for different folks and all that.
I have 27 1/2", a little bit smaller than your targeted size.
This puts me @ 6.77% taller than the stock tire size.
I also have an ej22, which may have just a little more power than a 10c motor.
The "slow as molasses" from a stop does not apply at all with my van, which by the way is a loaded and very heavy high-top westy. A tin-top would sail.
Around town in flat-land Vegas I really like the increased range of each gear now. That's the huge plus. I also (surprisingly) get slightly better gas mileage now, according to g.p.s. readings, in-town. I expected better hi-way mpg, but had expected worse in-town numbers.
The drawback comes with any climbing I do.
Acceleration suffers greatly.
Rpm falls off fast and I have to use 3rd.
For ME, this is fine, since 98% of my driving is flat-land style.
In fact, when these tires are done, I'm planning to go with larger ones.
All depends on where your priorities lie I 'spose. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
