sepulvedac Samba Member
Joined: December 10, 2005 Posts: 145 Location: San Antonio, TX
Posted: Mon Feb 22, 2010 1:56 pm Post subject: kadrons and 010 dizzy |
I have a set of Kadrons that I am installing on my 1600cc on it. This is not your run off the mill 1600cc. It has 69mm dpr counterweight crank, drd 043 heads with hi-rev single springs, bugpack 4061 cam, 13# flywheel with kennedy stage 1 plate and cushlock disc, Bosch alternator, Full flowed with filter, Bosch 010 dizzy.
How would the Kadrons work using the 010? What would be the best timing for it?
Any and all opinions are welcome. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4538 Location: Arizona Highways
Posted: Mon Feb 22, 2010 2:21 pm Post subject: |
roll it.
mine likes 30deg all in. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Mon Feb 22, 2010 2:47 pm Post subject: |
Do it... 28-32 is the range.
My 2180 is set at 30 degrees. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Feb 22, 2010 6:15 pm Post subject: |
alrighty then, I will do it.
Thanks to both of you.
So Glenn, I guess Kadrons does not need the SVDA like a lot of people mention. I hope mileage does not go down the drain. |
Glenn Mr. 010
Posted: Mon Feb 22, 2010 6:18 pm Post subject: |
I usually suggest a 019 with Kads on a mostly stock engine, but with your setup.. the 010 will be fine.
The only carb I prefer the SVDA with is the 34PICT-3 _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Feb 22, 2010 7:21 pm Post subject: |
thanks again for your input.
I'll let you know how it goes when I clean the carbs and install them. Even thou I probably will have to buy some parts for the linkage. I am going to use the Gene Berg linkage and shorter intakes, I was told by GBE that I will probably had to order extensions since the manifold is 1 1/4" sorter than the regular one which is what they used as a model for rhe linkage. We'll see.
Anyhow, I'll post the results of performance and mileage as soon as I finish with everything. |
Posted: Wed Feb 01, 2012 4:54 pm Post subject: |
After this post I had to leave to go to Puerto Rico. Still looking for ways to go back to TX and finish installing and setting the carbs. The sooner is going to be august this year GRRRRRRRRRRRR, but such is life. |
Posted: Mon Apr 23, 2012 7:07 am Post subject: |
just got back from TX, left the car there for now but the engine is sweeeeeeet. Ran it, after break in, for a week and a full tank (15gals) it gave me 33 MPG. Plenty of power at the punch of the gas!
thanks again for your suggestions. It is at 32 degrees and runs perfect. Between the adjustment of the kads a la AJ Sims and the tip from Glenn, I got all the power I want and then some. Can't wait to bring it to Puerto Rico next year. |
