Notablecarrot3 Samba Member
Joined: January 22, 2008 Posts: 461 Location: Sunny South Of France
Posted: Tue Feb 23, 2010 2:44 am Post subject: Unknown engine troubles |
Hi guys
I've had some trouble with my beetle recently, it was getting very jerky at low speeds, anyway I took it to a vw meet about 80 miles away and drove it quite fast down the motorway, averaging about 65-70 mph on the whole trip, and I also took it up to 80mph just to see if it'd make it with my stock 1300 dual port.
Anyway, disaster! swapped drivers just after coming off the motorway, and up the first hill my beetle started making a ticking noise sort of like an air leak or something blowing, and it struggled really bad in hills, no torque whatsoever . We ran out of petrol 10 miles later because my fuel gauge is dodgy but luckily I'd put a can of petrol under the bonnet so we just about made it home at 2am.
My beetle averaged 18.9 mpg that evening.
What do you guys think the problem could be?
Thanks
Tom _________________
EverettB wrote: |
Your Donkey has a large head. I like your donkey. |
EverettB wrote: |
Is it wrong to be jealous of their facial hair abilities? |
the-jerm Samba Member
Joined: March 14, 2007 Posts: 1169 Location: Sarasota, Fl
Posted: Tue Feb 23, 2010 7:17 am Post subject: |
Nothing wrong stands out visually on the engine? Loose wires, missing spark plugs, etc. You have me stumped |
Posted: Tue Feb 23, 2010 7:21 am Post subject: |
the-jerm wrote: |
Checked all wires, checked the spark plugs, they all spark ok. However testing the car just letting it idle, first time it was running fine, sounded just as before, then stopped the engine, started again, only fired on 3 cylinders, 5 minutes later it was back on 4 I was wondering faulty ht leads, but they look brand new it's got quite a few new parts, new dizzy (009 with electronic ignition) new airfilter, the carb is only 1 and a 1/2 years old...
Anybody else? _________________
EverettB wrote: |
EverettB wrote: |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Tue Feb 23, 2010 9:04 am Post subject: |
A ticking noise like an air leak....
Sounds like you may have a loose head. Maybe pulled a case stud.
You have probably already done a lot of damage by continuing to drive it. That will torch the head and the cylinder.
Time to pull it and tear it down and see what you have. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Wed Feb 24, 2010 8:32 am Post subject: |
nobody else? _________________
EverettB wrote: |
EverettB wrote: |
66 Bugman Samba Member
Joined: March 17, 2009 Posts: 722 Location: Ithaca, NY/Halifax, NS
Posted: Wed Feb 24, 2010 8:39 am Post subject: |
Notablecarrot3 wrote: |
nobody else? |
Did you, or were you able to check to see if the heads are correctly tightened? My friend had something like this happen to him, and it turned out to be that his exhaust to heater box connection was bad and it was leaking which caused him to lose power and make a ticking sound. |
Posted: Wed Feb 24, 2010 8:41 am Post subject: |
66 Bugman wrote: |
nobody else? |
Really?
My exhaust was missing a bolt to the heater box, if it's something that simple that'd be great! _________________
EverettB wrote: |
EverettB wrote: |
