Dropped Part in Conyers, GA
Morris_82
Morris_82 is offline
PostPosted: Tue Feb 23, 2010 12:04 pm    Post subject: Dropped Part in Conyers, GA Reply with quote
Finally towed the van from my Father-in-law's house to mine. Unfortunately, I was a bit overzealous. I already had the engine removed, so I just stuck it in the passenger area. I also removed the torque converter. I supported the transmission with some rope (redneck, yes I know) and took off. Everything seemed very stable and all was good.
Until, that is, I stop to reassess the situation and find a questionable shaft missing from the tranny. Bentley says it's the "pump shaft" for the A/T. About 21 inches long.
SO:
1. If you see this part on Hwy 138/I-20 near Conyers, GA, give me a holler.
2. Since I don't expect to ever see it again, where is a good place to find another? (GoWesty, BusDepot, OEVeeDub, and theSamba classifieds turn up zilch)
I hope this is the last screw up I make during restoration...yeah, right.
On a better note, I have a phone consultation scheduled with Mr. Raby tomorrow night to talk about a Camper Special kit. Very excited![/img]
MarkWard
MarkWard is offline
PostPosted: Tue Feb 23, 2010 1:46 pm    Post subject: Reply with quote
Did you flat tow it and were the CV's connected? If so, most likely the transmission is destroyed. Hopefully I am wrong. Can't tell you where to find the rod other than here and the vendors you mention.
1982 Vanagon Camper with ALH TDI conversion.
1990 Vanagon Camper Syncro conversion.
Morris_82
PostPosted: Tue Feb 23, 2010 3:45 pm    Post subject: Reply with quote
I did flat tow it...on a trailer. I was barely intelligent enough to read that here and in the Bentley beforehand. Unfortunately, my tranny is having problems for other reasons.
motelvw
motelvw is offline
PostPosted: Tue Feb 23, 2010 4:05 pm    Post subject: Reply with quote
My buddy did that a few years ago. Didn't realize it til we put the motor in and the bus didn't go. Pulled the motor, found a shop with a spare shaft and got the bus going late afternoon. And this is all on a Saturday at a Buses By The Beach campout!
Peace out, sauerkraut.
Roger
'89 Westy "The Moose Lounge"
'03 New Beetle
www.busesbythebeach.org
www.greenwood-studio.com
MarkWard
MarkWard is offline
PostPosted: Wed Feb 24, 2010 7:37 am    Post subject: Reply with quote
Good thing. Without the transmission pump running, you can burn up a VW/Audi automatic pretty quickly towing it on the ground.
Wildthings
Wildthings is offline
PostPosted: Wed Feb 24, 2010 9:53 am    Post subject: Reply with quote
I think there are a couple of different length shafts depending on application, they all appear very similar. Make sure you get the correct length.
