kidosteele Mr. Butthurt
Joined: July 14, 2004 Posts: 116 Location: Saint Petersburg, FL
Posted: Wed Feb 24, 2010 10:38 pm Post subject: What did I do wrong with my swing-axle conversion? |
ok i just did a swing axel conversion and belived to be 2 clicks up on the spring plates... but the bus looks higher then when it still had RGB's?
what could be wrong here?
will post pics in the moring...
any help is great thanks |
zao Samba Member
Joined: December 29, 2004 Posts: 281 Location: Yucaipa/Calimesa
Posted: Wed Feb 24, 2010 11:12 pm Post subject: |
Did you index them the correct way? Sounds like you need to go the opposite way you did. Or you need to index the inner splines, too.
Hard to say without a whole lot of information to go on. _________________ -Kevin |
Busryder Samba SuperHero
Joined: September 17, 2007 Posts: 1663 Location: In Your Face...
Posted: Thu Feb 25, 2010 12:52 am Post subject: |
zao wrote: |
Hard to say without a whole lot of information to go on. |
I think that your first guess, as that is what it is, is the most likely circumstance. _________________
Lind wrote: |
Apparently I was just the lucky asshole that showed up at the right time. |
I am a Dick, hear me roar-
Me, an OVP Lifer... |
Posted: Thu Feb 25, 2010 8:31 am Post subject: |
i moved the spring plate up.. it sits about a half inch above the bottom of the torsion bar mount..
how would i index?
thanks |
Posted: Thu Feb 25, 2010 9:55 am Post subject: |
Still waiting on those pix...
But without them, the question "is the rear under load when you make the height judgement?" comes to mind, (i.e., with the motor in).
And I am curious as to which end of the torsion bar did you "click" up two splines.
Still, it's rather difficult to nail down your problem without them pictures Kid-o-Steel .
(Shift key + letter key= Capital letters; these are most often found at the beginning of each sentence and also grace the first letters of Proper Nouns. TheSamba has a grammar tutor somewhere on here .) _________________
Lind wrote: |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Feb 25, 2010 10:06 am Post subject: |
Is the motor installed?
Have you driven it around to let the suspension settle? |
Posted: Thu Feb 25, 2010 3:07 pm Post subject: |
ok here is what is looked like atfer 2 clicks up on the outters..
and yes it has motor, full camping interior, and about 8gals on gas
sorry dont have any pics of it on the ground..
Posted: Thu Feb 25, 2010 3:09 pm Post subject: |
this it now after messing around all day..
i guess the PO adjusted the torsion also..
this is it now
roberto Samba Member
Joined: December 10, 2002 Posts: 833 Location: West Central Ohio
Posted: Thu Feb 25, 2010 3:47 pm Post subject: |
In my experience, a good place to start is indexing the spring plate to 6 degrees. like in this pic, using an angle finder located on the og uncut portion of the spring plate. Ofcourse the bus needs to be level from start. this will give you a real close balance to 3 1/2" dropped spindles. If you are adjusting your beam lower, you would need less angle.
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
looks about right. _________________ once you realize im not impressed we will get along just fine |
Soul Built Pimpin' Aint Easy
Posted: Thu Feb 25, 2010 4:03 pm Post subject: |
Sometimes it takes a bit for them to settle after you make adjustments. I usually drive around the block before I decide whether it is low enough |
Posted: Fri Feb 26, 2010 7:18 pm Post subject: |
ok i have one more question for you guys...
on the brakes i used 68 beetle brakes and i was wondering if i can use thing drums... so i dont have to use the 4 to 5 adapters?
thanks |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Fri Feb 26, 2010 7:26 pm Post subject: |
kidosteele wrote: |
thanks |
Yes, but the adapters are probably cheaper. _________________ nothing |
hudman Samba Member
Joined: December 13, 2004 Posts: 137 Location: San Diego
Posted: Fri Feb 26, 2010 8:01 pm Post subject: |
Thing drums, you need the better stopping power than bug pads. _________________ WWW.SV2s.com |
Posted: Fri Feb 26, 2010 8:04 pm Post subject: |
It is my understanding that thing drums do not use wider shoes, only that the drums are wider. Therefore, no added stopping advantage. If you want better stopping power, install a late (68& up) front wheel cylinder in there, or use type 4 drums and adapters. _________________ nothing |
zao Samba Member
Posted: Fri Feb 26, 2010 8:44 pm Post subject: |
I am running Thing drums in the rear and also later cylinders and super beetle shoes. I believe they are super beetle anyways. Really no huge difference in the shoe sizes. Most of the stopping power is in the front anyways. _________________ -Kevin |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Sat Feb 27, 2010 12:37 am Post subject: What did I do wrong with my swing-axle conversion? |
The Thing drums are about 1/4" wider than 4 lug bug drums and the wide 5 adapters, so make sure you have enough room. I just put a set on my 65 Micro, yes shoes and wheel cylinders are the same size as the 68 up bug. I ended up putting super front wheel cyls (23mm instead of 17mm)same as type 3 also, on and brakes are much better now. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Sat Feb 27, 2010 12:40 am Post subject: |
I have seen some different thicknesses in the 4-5 lug adapters, too. Either 3/8" or 1/2". That will make a difference.
In the first lowered bus I built I did not know about the need to use late beetle front wheel cylinders. The brakes sucked. A friend enlightened me, and what a big difference it made. _________________ nothing |
Posted: Sat Feb 27, 2010 8:50 am Post subject: |
thanks everyone..
cdennisg wrote: |
Yes, but the adapters are probably cheaper. |
price im not worried about i have a set of thing drums...
Teeroy wrote: |
The Thing drums are about 1/4" wider than 4 lug bug drums and the wide 5 adapters, so make sure you have enough room. I just put a set on my 65 Micro, yes shoes and wheel cylinders are the same size as the 68 up bug. I ended up putting super front wheel cyls (23mm instead of 17mm)same as type 3 also, on and brakes are much better now. |
so the thing drums are even wider then the set up ihave now... thats what i want to get away from...
also my wheels cyls are 19mm which one are then? |
