'58/'59 Beetle Discussion
Page: Previous  1, 2, 3 ... 147, 148, 149, 150, 151  Next
mabbo
mabbo is offline
PostPosted: Mon Oct 02, 2023 2:35 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Hi guys,
I have been trying to find out what the correct wipers are for my 58... Reading through this thread I can see that the 58 wipers have the separate base and fixed thin arms and blades, the same as ovals.
Apparently oval arms are not sided, but 58s are sided... which is what makes them one year only.
Is this right? My 58 (Nov 57 built) came with a pair of broken wipers. They have the separate base, with thin arms that look to be the same... but both blades have been broken off. So assume the only thing that can make them different to an oval is if one blade is longer than the other?
Thanks, Neil
Retro Restoration
West Midlands, UK
www.retro-resto.co.uk
See more of our work here:
www.instagram.com/retrorestoration
www.facebook.com/retrorestos
AlteWagen
Troll
AlteWagen is offline
PostPosted: Mon Oct 02, 2023 4:38 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
57 and earlier had the R vs L wipers as the passenger was at 45 degrees where the drivers was horizontal.
58 is a one year only wiper that fits both sides. As you mentioned its one piece arm and wiper with thin arm where in 59 the arm and wiper are two pieces up ti 64.
Official Dual Carb Thread
Darryldh
Darryldh is offline
PostPosted: Tue Oct 24, 2023 7:08 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
The blades/arms can be either L or R in '58... they are the same. Oval is different L to R.
The blade lengths are longer in '58 than oval blades. '58 blades are 450mm (9-5/8"). Both blades are the same length.
Both Oval and '58 arms are permanently attached to the blades with rivets, and both have "thin" arms (width 4mm), whereas '59 and later have 6mm wide arms.
Due to both having thin arms, '58 can use oval bases and vice versa.
In the photo below, the top one is an OG 1959 wiper, and the bottom two are NOS 1958 wipers.
kaieric Premium Member
kaieric is offline
PostPosted: Wed Oct 25, 2023 4:53 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
245mm to be exact.
56 cab, 58 cab rhd
TXHCBeetle
TXHCBeetle is offline
PostPosted: Mon Nov 27, 2023 9:16 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Does anyone know if the original screw terminal dimmer switch on an early 58 was branded Hella or VW?
In Progress:
1958 Beetle Sedan - L243 Diamond Gray
1967 Beetle Sedan - L456 Ruby Red
VWNate
VWNate is offline
PostPosted: Fri Dec 01, 2023 10:21 pm    Post subject: '58/'59 Beetle Discussion NO REPLIES Reply with quote
I'm re posting here as I stopped getting notifications and I want to read every one .
Is there a hyperlink or button I need to click ? .
TIA,
-Nate
One last Beetle : 1959 #113 DeLuxe survivor ~ 36HP & full synchro tranny, 6 volts etc.
PostPosted: Sat Dec 02, 2023 8:17 am    Post subject: Re: '58/'59 Beetle Discussion NO REPLIES Reply with quote
TIA,
Tip for anyone: You don't need to post to get notifications, click
Watch this topic for replies
at the bottom of the thread
(Or any thread you want to watch/get emails about)
VWNate
VWNate is offline
PostPosted: Sat Dec 02, 2023 5:46 pm    Post subject: Replies Reply with quote
Thanx but that sidesteps the question of why I stopped getting replies......
-Nate
PostPosted: Sat Dec 02, 2023 10:06 pm    Post subject: Re: Replies Reply with quote
Does it say "Watch Topic for replies" at the bottom?
If it's doesn't, you are not subscribed.
Otherwise, your email probably either failed or blocked it or it went to spam and you missed the notification.
I literally get 100s of emails rejects/day from members kicked back from their email providers... all of them, but some are worse than others.
VWNate
VWNate is offline
PostPosted: Sun Dec 03, 2023 8:29 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Yet again you help me out and I thank you .
I try to check my spam file every day .
At least I'm getting the notifications now .
Thank you Everett .
-Nate
jbannon
jbannon is offline
PostPosted: Sun Dec 31, 2023 2:10 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
I was wondering if anyone had a sample or picture of V52 Blue, which was the color used for the ragtop material in 1958 Glacier Blue cars. I also believe 1959 Fjord Blue Cars used the same color for their ragtop material.
Also on the topic of colors, I found somewhere on the Samba that L471 Stone Beige was used for the steering wheel / seat frames / shifter / e-brake / etc. However this is a euro ragtop car and I have never seen that color used here before (Silver beige seems to be main color used in the interior in Europe). Unfortunately the PO painted everything black in the interior as well as swapped out the original seats, steering wheel, shifter, etc, so I have no reference material to choose from. Is Stone Beige and Silver Beige the same or similar colors? Can anyone confirm which color is correct for the interior?
Any help is appreciated.
sunroof
sunroof is offline
PostPosted: Fri Apr 26, 2024 9:23 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
This thread has fallen too far down the list so: Bump
https://www.facebook.com/DonHuebert/videos/10203369041204132
Don
Better and better mistakes!
bnam
bnam is offline
PostPosted: Tue Apr 30, 2024 7:54 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Apologies if what I am about to post has already been covered in the 147 prior pages. I've only had a chance to read thru about 20-30.
I have been asked by a local club member if a 1959 came with a sway bar. In the first 20-30 posts I saw a few who said 1959s did and some who have them on their 58s.
I looked up 3-4 references books I have - COTC, Progressive Refinements, 1960 Parts Manual, and 1972 parts manual.
Both COTC and PR list Aug 6, 1960 as the introduction of sway bar - and only on the deluxe beetles. The parts manuals do not make that distinction and list the sway bar as "up to 115 999 000".
So, could it be that they were introduced in Aug 59 (MY60), but were available (recommended?) for retrofit on earlier models?
Thanks,
Byas
Click to view image
1952 Citroen TA 11BL
stale air
stale air is offline
PostPosted: Thu May 02, 2024 5:53 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Thanks,
Byas
Earlier in this thread we came to the same sorta conclusion as you did. Even though they didnt get factory sway bars til Aug of 60, there are a bunch of original unmolested cars bult pre Aug of 60 that have them, my 58 included. My thoughts are that there may have been some sort of TSB issued from VWOA where they were retrofitted with them due to wandering, shimmying, etc. That said, we have yet to find any proof unfortunately.
sunroof
sunroof is offline
PostPosted: Thu May 02, 2024 9:06 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
In 1989 I bought a 1959 deluxe in capri blue from the original owner for $50. He had bought it in Germany in 1959 when he was there doing his PHD in physiology. It had a front sway bar. When I sold that car I kept the sway bar and it was in 4 cars all together. When I sold my last '59
in 2019 I left the sway bar in it and am now really regretting that. I would love to be able to put one in this car
Don
bwaz
bwaz is offline
PostPosted: Sun Jun 30, 2024 7:55 am    Post subject: Reply with quote
I found that page in question about fuel pump changes.
henry roberts wrote:
i'm not sure if i'm posting this in the right thread but here is some fuel pump info i hadn't seen before.
mods, if you know a better thread for this to be in, please move it.
from the 1958 workshop manual sect K - 3 page 6 (update 2.62)
1 - fuel pump with strainer:
from chassis 2 193 349
from engine number 2675068
...aka in early december 1958 they started fitting fuel pumps with strainers...
2 - fuel delivery
from chassis no. 1 976 996 the capacity of the fuel pump has been increased.
the increase... has been obtained by the means of an airpocket in the delivery passage. for this reason, the distance from the middle of the mounting flange to the upper edge of the delivery passage has been increased from 91 mm to 97 mm.
...aka early june 1958 they changed from the late ribbed fuel pump top with no filter and a short output, to the version with the tall output...
sorry no pics/scans of the page at the moment.
VWNate
VWNate is offline
PostPosted: Sun Jun 30, 2024 8:28 am    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
You neglected to mention the 14MM A.T.F. tube typ wrench in the tool kit to service that screen with......
-Nate
pdxeuro
pdxeuro is offline
PostPosted: Thu Jul 04, 2024 12:04 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Hi all - I have May 1959 Bug that was coming along nicely until the new Klassic Fab rear fenders were bolted on and did not align. A few questions:
1) anyone else had this issue with Klassic Fab rear fenders for our years? Looks like they stopped selling them on their site (I got them about 2 years ago. If you had them, what was your solution (add in metal to lengthen them a bit?)
2) Since OG rear fenders are as rare as rocking horse poo, what other sources have you found? I see Wolfsburg West now sells $1000 (each!) rear fenders for our year. Do they fit perfect? Is it worth it? Any other sources? I see Kafer Nostalgie has front but no rears.
3) I know you will say/ask - what do you plan to do with the car? I do want it to be OG stock, however will someone stick their head in the wheel well at a show and say the car is shi*t because of this one detail? I will however always know and second guess it.
Love to hear your thoughts on this topic! Thanks in advance
Portland, Oregon
1991 Westy MV
1959 Bug
1977 Westy Bus - sold
1968 Bug - sold
2002 Eurovan - sold
sunroof
sunroof is offline
PostPosted: Thu Jul 04, 2024 12:53 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
First of all good luck with your car, 1959 is the best year ever for beetles.
I have welded 3 cars together now and Klassicfab def has some fitment issues. However! Apart from Wolfparts they are the best in terms of fit, some of the others are truly awful. You might be able to find better fitting fenders but you may not, it's a bit of a crap shoot. My advice about your fenders is to make the necessary adjustments and do the welding to get them to mate up properly.
Don
Busstom
Busstom is offline
PostPosted: Thu Jul 04, 2024 2:59 pm    Post subject: Re: '58/'59 Beetle Discussion Reply with quote
Man those are pretty far off, moreso than I would've expected for his fenders. Bummer. But from what I've read, the metal thickness is correct on those, and that's pretty important. I would echo sunroof's comment and make the necessary adjustments.
If you're not aware, KlassicFab is no longer making VW parts, Gerson had transitioned to vintage Japanese car panels.
Page 148 of 151
