Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Jun 20, 2017 12:48 pm Post subject: Re: Bigger brake booster, improved brakes. |
ALIKA T3 wrote: |
Pcforno wrote: |
90 - one other thing I'd recommend - when you change the booster the entire pedal assembly will be pulled up out of the dash and free - get the GW parts to replace the clutch pedal. I did it the "other way" below the dash and it's damn near impossible, only to find out later that it would have been easy to do with the booster job through the top of the dash |
Yup, just squeeze the pedals together with one hand while pulling from the top: easy breezy |
What?! You can change the booster and pedal cluster through the instrument binnacle hole without removing the dash?!?
Really? _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Pcforno Samba Member
Joined: October 14, 2014 Posts: 575 Location: Santa Fe, nm
Posted: Tue Jun 20, 2017 2:38 pm Post subject: Re: Bigger brake booster, improved brakes. |
Yup - I've mentioned it a couple times now and posted it in the "30 minute clutch replacement thread" - to beware that it's not 30 minutes below the dash and if you happen to be doing the booster it's best done through the top |
90weekender Samba Member
Posted: Tue Jun 20, 2017 4:16 pm Post subject: Re: Bigger brake booster, improved brakes. |
Hi guys,
In preparation for this surgery, I just finished installing the drilled and tapped Clovis onto my BMW booster. After adjusting the clevis hole center to booster face depth to 111.5mm there are no threads left on the booster shaft for a lock not to secure the clevis.
Am I doing something wrong?
Check my photo:
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6351 Location: Honolulu,Hawaii and France
Posted: Tue Jun 20, 2017 6:37 pm Post subject: Re: Bigger brake booster, improved brakes. |
Jake de Villiers wrote: |
ALIKA T3 wrote: |
Pcforno wrote: |
Really? |
I didn't mean with the dashboard installed, sorry for the confusion, as I have never tried that method, too much of a pita to me when it takes me 20 min to drop the dash off _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Wed Jun 21, 2017 8:28 am Post subject: Re: Bigger brake booster, improved brakes. |
ALIKA T3 wrote: |
I didn't mean with the dashboard installed, sorry for the confusion, as I have never tried that method, too much of a pita to me when it takes me 20 min to drop the dash off |
Ha! Apparently you've had a LOT more practise than I have!!
I'm just a little concerned about how much the Behr Indash AC is going to complicate the dash removal. _________________ '84 Vanagon GL 1.9 WBX
Posted: Wed Jun 21, 2017 12:00 pm Post subject: Re: Bigger brake booster, improved brakes. |
ALIKA T3 wrote: |
I'm just a little concerned about how much the Behr Indash AC is going to complicate the dash removal. |
It should be the same,I've never done it, but looking at pics, just unplug the vent hoses on all. The tricky one is the stereo vent, I posted how to remove that vent recently on the behr custom stereo thread that's floating around. I did it to replace the cigarette lighter thingy. Was not fun _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
bajaleo Samba Member
Joined: March 21, 2009 Posts: 211 Location: San Juan Capistrano, CA
Posted: Thu Jun 22, 2017 8:00 am Post subject: Re: Bigger brake booster, improved brakes. |
ALIKA T3 wrote: |
Pcforno wrote: |
Really? |
Apparently so. I've never done it, but this guy did.
bajaleo wrote: |
I hope the video is still available on Youtube. Watch this guy swap out the brake booster on a Vanagon
squarevan wrote: |
Don't know if this is posted already but it might be easier don't have to take the dash off and go upside down. Note in this video there is not a clutch pedal but it makes it a lot easier to remove the clutch pedal but being able to see the clip and pull out the pin. As others have mention hand size and body type might not work with the orginal post.
you can search on youtube for:
How to replace the Dual Diaphragm Brake Booster Volkswagen T3
https://www.youtube.com%2Fwatch%3Fv%3DzuhLBdvFK-8&...bs.1,d.amc
good luck |
_________________ Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered. |
Posted: Thu Jun 22, 2017 8:01 am Post subject: Re: Bigger brake booster, improved brakes. |
ALIKA T3 wrote: |
ALIKA T3 wrote: |
It should be the same,I've never done it, but looking at pics, just unplug the vent hoses on all. The tricky one is the stereo vent, I posted how to remove that vent recently on the behr custom stereo thread that's floating around. I did it to replace the cigarette lighter thingy. Was not fun |
Right on. I'm sure I'm just inventing possible difficulties... _________________ '84 Vanagon GL 1.9 WBX
Posted: Mon Jul 10, 2017 1:37 pm Post subject: Re: Bigger brake booster, improved brakes. |
Any ideas? Anyone one have the same issue?...anyone...anyone...Buhler?
90weekender wrote: |
Hi guys,
Check my photo:
Posted: Mon Jul 10, 2017 4:50 pm Post subject: Re: Bigger brake booster, improved brakes. |
It's all good man, just mount it with red loctite, well tight.
I actually use the BMW clevis now, slight grinding of the VW pedal to install 2 super fine teflon washers for friction on either side to it won't rub hard metal to metal onto the BMW clevis. Redrill the pedal. Done. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
gchristensen Samba Member
Joined: October 09, 2012 Posts: 84 Location: Sacramento Ca.
Posted: Mon Sep 04, 2017 5:42 pm Post subject: Re: Bigger brake booster, improved brakes. |
Does anybody know if this is doable to an earlier van like an 82? If yes where is the vacuume line attach and I assume you can use any vacuume line brought up from the engine bay?
Thanks _________________ Joining now is our new 1982 diesel. This is an ongoing project under construction. |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1490 Location: Victoria,B.C.Canada
Posted: Tue Sep 05, 2017 6:12 am Post subject: Re: Bigger brake booster, improved brakes. |
Hi guys,
Check my photo:
The GoWesty replacement clevis has a longer threaded portion. I had to cut a bit off the replacement clevis to make the adjustment. |
monkslayer Samba Member
Posted: Mon Oct 16, 2017 6:14 pm Post subject: Re: Bigger brake booster, improved brakes. |
Awesome write up. Finally managed to do the booster upgrade and it makes a world of difference. Combined with the rear disc conversion, this finally makes the brakes feel really different, it's like they came alive after a long slumber.
Only problem after VW long slumbers is there is always a catch, my calipers are now sticking after the car has run for a bit. Yesterday night , they completely locked up and I had to cool them off a bit with some water(they were smoking) and wait for them to cool down before I could drive off again. Seems when cool, they work just fine but after a few cycles of braking(they get hot) they start to stick. I'll disassemble the caliper tomorrow, I suspect a rebuild is calling. Any other ideas would be welcome too! |
Posted: Tue Oct 17, 2017 8:17 am Post subject: Re: Bigger brake booster, improved brakes. |
Other possibilities - check and adjust parking brake or upgrade cables, check and lube caliper slider pins, check rear brake pistons are screwed back all the way in and set right with the parking brake. |
Posted: Tue Oct 17, 2017 8:36 am Post subject: Re: Bigger brake booster, improved brakes. |
finally sorted it out. Seemed i needed to further adjust the clevis pin since it was slightly engaging the MC causing brake drag and the sticking. Adjusted, went for a long-ish hard drive and so far so good. Will keep an eye out on it but so far it is the best braking on the Van since i got it. Cheers for the replies |
Rydersonthestorm Samba Member
Posted: Mon Jun 11, 2018 3:56 am Post subject: Re: Bigger brake booster, improved brakes. |
Just though I’d let people know (since there was discussion on part #s that work) that I did a successful (although haven’t driven it much yet) conversion using the 34-33 1154 262 booster. Only thing that differed from the instructions is I had to shorten the threaded rod 8mm (5/16?) as it would have protruded into the clevis and I wasn’t sure the actual area within the clevis that the pedal pivoted (so decided it was safest to shorten).
I haven’t seen the other boosters people are using but they look similar to the one I used based on pictures. |
bubba Samba Member
Posted: Mon Nov 05, 2018 8:48 am Post subject: Re: Bigger brake booster, improved brakes. |
Rydersonthestorm wrote: |
Will the Booster part number 3433-1157911 work? _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
Posted: Mon Nov 05, 2018 9:36 am Post subject: Re: Bigger brake booster, improved brakes. |
bubba wrote: |
Will the Booster part number 3433-1157911 work? |
It should - according to my notes that's one of the three part numbers I was hunting. I ended up with a 34331157-984 _________________ '84 Vanagon GL 1.9 WBX
beach_creature Samba Member
Posted: Tue Mar 05, 2019 3:57 pm Post subject: Re: Bigger brake booster, improved brakes. |
Joining the club. Picked this up today.
_________________ 84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD |
