Hot water heaters--anybody done it?
Californio
Californio is offline
PostPosted: Tue Mar 02, 2010 9:51 am    Post subject: Hot water heaters--anybody done it? Reply with quote
I've seen hot water heaters made by coiling copper tubing for coolant through a tank of water, then attaching a pump to the faucet, etc. However, I don't like the idea of that coolant flowing through a coil in my drinking water...what if years down the road it develops a leak and isn't noticed?
You can see these done quite nicely on syncro.org and other places. It does work, no question.
What about the reverse--having drinking water flow through a copper tube that's wrapped around a coolant hose (or even header pipe)? Then if the copper leaks, you lose your drinking water but don't end up with contaminated water.
If anybody's done this, do you need a pump or would gravity do the work?
Seems like a nice mod, what a luxury!
Another idea, wrap the flue for the fridge in copper coils for a heat exchanger, then you'd have hot water anytime the fridge is on...
Alaric.H
Alaric.H is offline
PostPosted: Tue Mar 02, 2010 10:04 am    Post subject: Reply with quote
I have seen something like this done.
http://www.goenergystead.com/URLrewrite.asp?404;ht...directed=Y
danfromsyr
danfromsyr is offline
PostPosted: Tue Mar 02, 2010 10:12 am    Post subject: Reply with quote
copper tube will last a LONG TIME in a vehicle heat applicaiton, and as long as your fittings are outside the holding tank there's very little chance of any failure & contamination.
the problem I can see is the engine coolant is regularly above boiling point and can conceivably raise the holding tank water temps to boiling.(add in elevations?) and you'll get steam and a BIG HEAT SINK inside all day/night.. might be nice for winter camping use, but for summer the added heat wouldn't be welcomed.
I have seen a custom DIY insulated water tank under the back seat that had coolant piping thru it, and some temp regulator to maintain it's temp @ a desired & safe lvl.
Abscate wrote:
purplepeopleeater
purplepeopleeater is offline
PostPosted: Tue Mar 02, 2010 10:22 am    Post subject: Reply with quote
That thing is awesome, I think $120 is a great deal too...If you could set that up somewhere clean it would make a great outside shower
Jon_slider
Jon_slider is offline
PostPosted: Tue Mar 02, 2010 10:34 am    Post subject: Reply with quote
keep in mind that heater requires an external water supply
here is one installed in the back closet of a westy, plumbed to the drinking water tank
http://www.thesamba.com/vw/forum/viewtopic.php?p=4057487&highlight=shower#4057487
climberjohn
climberjohn is offline
PostPosted: Tue Mar 02, 2010 10:35 am    Post subject: Reply with quote
Methinks that one looks extremely cool . . er, hot.
I think I saw that unit installed inside the rear driver side cabinet in Wild Bill's syncro at Mogfest NW last year. Open the hatch, grab the shower head, instant hot water shower.
(I prefer the low tech and free method of a few holes drilled into the lid of a pop bottle and then filling the bottle with stove heated water for doing dishes and shower, but that's just me.)
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
J Charlton Premium Member
J Charlton is offline
PostPosted: Tue Mar 02, 2010 11:22 am    Post subject: hot h2O Reply with quote
I kind of like this one - if I wanted one at all that is - I like that it doesn't need "city water pressure" to operate. Easy enough to hook it up to your "propane tree" and run it off a 20lb tank.
having said that however, I really don't want to carry more "stuff" - I'm happy heating wash up water on the stove and as for showers - well some campgrounds have them, other times there's a lake - whatever..
http://www.walmart.com/ip/Hot-Water-on-Demand-Port...ku=8187723
NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024
1621
1621 is offline
PostPosted: Tue Mar 02, 2010 11:28 am    Post subject: Reply with quote
Check out spitsnrovers site for some DIY ingenuity. He uses both thermostatically controlled engine heat while underway and residual heat from the Dometic while camped. Pretty clever I think - and he includes a parts list. Hopefully he'll chime in later, but check out his site for detailed info.
See the 'Hot Shower' and 'Fridge Water Heater' links.
http://www.griffco.ca/interest/vw/vwmods.htm
'85 Westy
Californio
PostPosted: Tue Mar 02, 2010 12:25 pm    Post subject: Reply with quote
Already some good posts on the subject. It looks like the easy way to go is with the propane on-demand units, though they aren't made to be permanently installed and of course use propane.
I'm thinking for a heat-transfer type installation, the way to go would be to wrap the dometic flue with copper tubing, etc. This would not only provide hot water but decrease the amount of heat behind the fridge, especially if you were to wrap the flue/tubing in insulation (like exhaust wrap for example.) That evil heat behind the fridge would transfer to the water and to the outside. And you'd have hot water all the time, maybe not enough to shower with but for the dishes anyway.
The other problem with the shower is getting the GF to use it...maybe just stick to the washing dishes idea...
PDXWesty
PDXWesty is offline
PostPosted: Tue Mar 02, 2010 1:08 pm    Post subject: Reply with quote
There's no way copper tubing on the flue for the fridge will provide enough heat to get hot water. I size heat exchangers for a living. You might get 1-2 degrees of rise under those conditions if you're VERY lucky, not the 60 degrees you'll need to make hot water.
Robbing heat from your flue will also cause the flue gasses to cool and condense moisture inside the vent. Not something you want to be doing.
Don't waste your effort. Look for a propane solution.
89 Westy 2.1 Auto
Californio
PostPosted: Tue Mar 02, 2010 1:37 pm    Post subject: Reply with quote
Good advice from an expert. Thanks. It does seem the idea of wrapping a coolant hose with copper tube would work, though, no? Cost-wise the whole thing would be cheap too.
PDXWesty
PDXWesty is offline
PostPosted: Tue Mar 02, 2010 1:56 pm    Post subject: Reply with quote
You could make a copper coil heat exchanger to sit on the stove and use the burner as a heat source, but by then you might as well just heat a pot of water. The Fridge burner just doesn't have a big enough flame to produce enough heat.
89 Westy 2.1 Auto
