damicotile Samba Member
Joined: September 16, 2004 Posts: 1069 Location: WOODLAND CA.
Posted: Wed Mar 03, 2010 1:37 pm Post subject: Small head tin bits |
Last night I had been reading about head tins and noticed that the small tin pieces on my heads are missing and trying to find these pieces are impossible.
So while I was making pasta for dinner last night it came to me.
What?
BTW,,, the pasta was great.
Guido _________________ '73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________ |
tcgmark Samba Member
Joined: August 07, 2008 Posts: 55 Location: Fullerton, CA
Posted: Wed Mar 03, 2010 3:46 pm Post subject: |
I got a set of those from a guy at Rimco who pulled them off a set of junk heads. They are not that difficult to make either. I have read here about guys who just cut their own out of sheet metal. Funny how a silly little piece of metal has importance on these motors. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Wed Mar 03, 2010 3:59 pm Post subject: |
Damicotile
I make them where I work, I make them out of stainless steel. Do you want them with or with out the slots, They are $6.00 a pair
the under cylinder air deflectors are $12.00 flat or $15.00 If I brake them to shape
Send me a message
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Thu Mar 04, 2010 7:59 am Post subject: |
earthquake wrote: |
Damicotile
Send me a message
Casey |
You know Casey, those are great tins but yesterday I was busy working on cleaning my tins and finishing up on putting the long block together that I didn't get to the computer until this morning to see your post and now the whole long block is complete.
I will keep you in mind for my next one though. I'm gonna build me a back up engine for my bug.
Now, if only you could CNC manifolds for my Webers to clear my tins.
There would be a market for that work. Just take the one that come with the kit and shave off just enough to clear so we don't have to butcher up the tins. _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
kme9418 Samba Member
Joined: January 30, 2003 Posts: 277 Location: San Antonio, TX
Posted: Sun Mar 25, 2012 7:17 am Post subject: |
earthquake wrote: |
Casey |
Earthquake, you still make these? I need the 2 little squares. _________________ KME9418
1969 VW Beetle |
Posted: Sun Mar 25, 2012 10:04 am Post subject: |
kme9418
The water jet is currently down untill we can find a new building but I think I have a couple of sets left, do you want them with or with-out the slots? [for thermostat rod] I will check and see what I have and PM you.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Sun Mar 25, 2012 11:31 am Post subject: |
Not to take anything away from Earthquake but here's another option:
http://www.zwerks.ca/ _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Sun Mar 25, 2012 11:46 am Post subject: |
EQ,
Good to know you make these. I would like to order 3 pairs of the non thermostat clippy doos. Whats your paypal address? Thanks-Jon _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Posted: Sun Mar 25, 2012 11:58 am Post subject: |
JFatts
Hit me up in a couple of months and hopefully the machine will be back up and running, I am also going to be making "Industrial tins" in stainless as well.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Chris659 Samba Member
Joined: June 14, 2011 Posts: 654 Location: Central Florida
Posted: Sun Mar 25, 2012 3:30 pm Post subject: |
I'm pretty sure Clark at Awesome Powdercoat has them for sale too |
67Callooker Samba Member
Joined: January 24, 2008 Posts: 158 Location: las vegas
Posted: Mon Mar 26, 2012 5:41 am Post subject: |
earthquake pm! _________________ "dumbass" red foreman if you paint an engine case you probably forgot the tin |
