holey carburetor batman (67)
airkooledchris
Location: Where the pacific ocean meets the redwood forest
airkooledchris is offline
PostPosted: Fri Mar 05, 2010 11:20 am    Post subject: holey carburetor batman (67) Reply with quote
so I pulled my oil bath filter off for the first time, and it looks like someone wrenched the thing on so hard that the screw to tighten it to the carb actually punctured a hole into this thing.
can I just JB weld the thing up, or does it even matter that it's there so long as I put the screw right back where it was, or?
I have another carb for this motor, it's exactly the same model/etc, but im guessing it needs a rebuild (or why would it have been sitting in one of the old boxes of parts I got with this project) - should I be sending this in somewhere to get rebuilt to swap out?
metahacker wrote:
... i would say that, if it's an option, (edited) not listen to any forum pessimism..
Itawayoflife
Itawayoflife is offline
PostPosted: Fri Mar 05, 2010 11:29 am    Post subject: Reply with quote
Just JB Weld it. That is the housing for the electric choke. The worst case scenario would be gas getting in there. Could start a fire.
You can rebuild the carb yourself, but, take your time and research how to do it right. Rebuild kits are cheap.
The quest continues...
old_n_slo
old_n_slo is offline
PostPosted: Fri Mar 05, 2010 11:45 am    Post subject: Reply with quote
You might want to research putting a hose clamp on that fuel line while your in there.
63beryl
63beryl is offline
PostPosted: Fri Mar 05, 2010 11:49 am    Post subject: Reply with quote
If the throttle shaft needs rebushed, which most do, send it to someone with the tools/experience to fix it correctly. I just got my carb back from keifernet and he did an amazing job.
MODIFIER
MODIFIER is offline
PostPosted: Fri Mar 05, 2010 12:06 pm    Post subject: Reply with quote
I know how that hole got there.
anybody else?
currently residing in northern merde creek with no means of propulsion
USC USMC DAD OORAH!
ASE MASTER TECH BODY/PAINT and MECHANICAL
62 Beetle
63 Vert
64 Beetle
https://www.facebook.com/SmartFarmServices
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Fri Mar 05, 2010 12:41 pm    Post subject: Reply with quote
anybody else?
I always attributed it to the air cleaner being "loose" and vibrating and rubbing on that spot. I have seen it quite a few times.
And yes it's no big deal to just take the choke out and clean the oils off the area with some brake or carb cleaner, put a piece of tape on the OUTSIDE of the choke housing and a thin dab of JB KWIK from the inside of the housing... ten minutes later peel the tape off and you a smooth almost unnoticable repair.
my seller feedback
rebuilt carb info = for sale
"STFU Polly and go eat a cracker!" 12-21-2012.... can't wait!
lanceevox
lanceevox is offline
PostPosted: Fri Mar 05, 2010 1:01 pm    Post subject: Reply with quote
serious? those braided hoses are hard enough to get off...
-Nikolai
1963 1200cc rag top bug
1970 1600cc SP bug. sold
1970 1600cc DP bug. sold
KTPhil
KTPhil is offline
PostPosted: Fri Mar 05, 2010 1:05 pm    Post subject: Reply with quote
keifernet wrote:
anybody else?
Bingo.
airkooledchris
PostPosted: Fri Mar 05, 2010 1:06 pm    Post subject: Reply with quote
yea, I couldn't get the old fuel hose off without cutting it, at least when its pushed all the way on nice and snug.
anyway, for this one the PO didn't have it loose - it was on amazingly tight - to the point that when you first backed it out you could feel the screw unscrewing out of this hole. it was screwed in so tight they drove it straight into that thing.
thanks for the words of advise, ill pull it off and JB it up later tonight.
KTPhil
KTPhil is offline
PostPosted: Fri Mar 05, 2010 1:07 pm    Post subject: Reply with quote
I have seen a suggestion to use a plastic zip tie, as tight as you can get it. Metal clamps tend to absorb engine bay heat and cook the hose, cracking it. This works best if the carb pipe has a bulge at the end, but most don't. So second best idea is a FI hose clamp (not a worm clamp), safety wired to a tab under a carb top screw. And, of course, no plastic fuel filter in that line.
airkooledchris
PostPosted: Fri Mar 05, 2010 1:16 pm    Post subject: Reply with quote
the PO had no less than two of them in the engine compartment, both since removed.
83_WabbitGTI
83_WabbitGTI is offline
PostPosted: Fri Mar 05, 2010 1:49 pm    Post subject: Reply with quote
If you have another carb of the same exact model like you said... Why not just swap the tops around, replace the needle valve, gasket, diaphragm and be done with it? Problem solved.
2013-2014 Vice President of SOVW www.sovw.org
"No matter how a VW breaks down.... You can always make it home on Zipties, Ducktape, and JB Weld...."
-Doug Christen, VW Owner
83 Rabbit GTI - 83 Rabbit LS Custom - 63 Westy - 65 Bug - 64 Baja (Herbie's Studly Cousin) - 91 Audi 90 Quattro 20v - 85 Vw Cabby - 84 VW Scirocco - 69 Beetle (Phantasm Bug) - 78 Cabriolet
Need a VW website built? PM me.
airkooledchris
PostPosted: Fri Mar 05, 2010 2:57 pm    Post subject: Reply with quote
this is the 'spare' carb I found in one of the boxes I got with this beetle:
Ive never taken one of these apart before (always had FI) - but the electric choke looks a little different, though I think (and maybe incorrectly) that I can just swap out that little round cap on the end and pop that into the spare one yea?
here is what the electric choke looks like on the current carb still mounted:
keifernet
PostPosted: Fri Mar 05, 2010 3:05 pm    Post subject: Reply with quote
That is a different designation of 30 pict -1 so swapping the top won't cut it.
I bet that carb says "47-1" on the back of the bowl and it's a 1300 cc carb from a 66.
It does not have the provision for the return spring and also does not have the "power enrichment circuit" so... forget swapping that top to your other carb.
my seller feedback
airkooledchris
PostPosted: Fri Mar 05, 2010 3:11 pm    Post subject: Reply with quote
there's a reason you always hear the word' keifernet' in the same sentence as 'carburetor'.
back to the JB weld for now then.
83_WabbitGTI
PostPosted: Fri Mar 05, 2010 3:15 pm    Post subject: Reply with quote
airkooledchris wrote:
From the looks of your carb at the base where the 13mm nut is... Your leaking fuel . It might be a good idea just to rebuild it anyway before you have a built in campfire.
Viande
Viande is offline
PostPosted: Sat Mar 06, 2010 1:51 am    Post subject: Reply with quote
Ding Ding Ding! You are exactly correct. Keith is one of the people out there truly trying to help people get the best out of there VW's.
Bobby
New Items In Stock, NOS & OEM Seals,Parts and Terminals
My Feedback Here
The bitter taste of poor quality lingers long after the joy of the cheap price fades away.
BUGTHUG
Samba's Rented Mule
BUGTHUG is offline
PostPosted: Sat Mar 06, 2010 3:00 am    Post subject: Reply with quote
If you are planning on keeping your car for a long time, just buy a rebuilt one, or one from the calssifieds? I don't think they are real expensive, might give you a peace of mind and maybe help cut down on a engine fire.
I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1966 VW bug
1966 21 window micro bus
1969 Dune Buggy
1965 VW bug
1974 VW bug
1972 Kelmark, VW drive line
1948 Chevrolet Hearse
BWD
Samba Mailman
BWD is offline
PostPosted: Sat Mar 06, 2010 11:47 am    Post subject: Reply with quote
Check my sig line! Very Happy
BWD
JHC
member #2850
1966 Beetle
_____________________________
candymustang65
Banned
candymustang65 is offline
PostPosted: Sat Mar 06, 2010 9:21 pm    Post subject: Reply with quote
Slitt the braided fuel line .
No zip tie needed !
Spitt on it ! Wont come loose I promise .
Plastic fuel filter between carb and pump allow's monitoring of fuel pump pressure .
If proper plastic tear drop fuel filter is used and installed correctly ( wear cant rubb bounce etc. )
No more dangerous than the fuel line itself .
No clamp's should be used on fuel filter when cloth braided fuel line is used .
Excessive fuel pump pressure over ride's pump inlett valve needle .
This causes rich or fatt Condition or even flooded condition .
Indicative by surgeing and even stalling out at stop sign's .
Excessive Pump pressure is most often prevalent during cold weather condition's .
Early morning's etc. but symptom's can often cure themselves by noon or as day warm's up .
Take gas washing and fatt condition and add lack of thermostat wich most of us dont runn .
That's a lott of start up engine wear .
Metal or glass fuel filters should not ever be used inside engine compartment . Generally speaking .
Sean
