Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Sun Mar 07, 2010 1:35 pm Post subject: Camber compensator |
Anyone have any feedback/knowelge about the camber compensator for split bus with rgbs? I have seen them around and see how in theory they would be a good thing, I need some real input .Thank you all. _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Mar 07, 2010 5:20 pm Post subject: |
Would first invest in the right tires, shocks, and then anti-sway bar on the front axle. After that if you still need more would try the rear camber compensator.
Big problem with the RCCs is most are designed to bolt onto the transaxle where the side plate studs all too often get pulled out. Have found one vintage RCC that clamped onto the transaxle frame horns. Much nicer design!!
http://www.thesamba.com/vw/forum/viewtopic.php?t=358596&highlight=camber+compensator
Plus lots more info through the "Search" feature for "Camber Compensator". _________________ In Stereo, Where Available! |
58deluxerag Samba Member
Posted: Sun Mar 07, 2010 5:35 pm Post subject: |
Have one on my Monster 15 window, works great. _________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
Leo1 Samba Member
Posted: Wed Mar 17, 2010 12:53 am Post subject: |
Bought one a couple years ago from Bus Boys. The first time I drove up a circular highway onramp, it was clearly money well spent!
Leo _________________ '66 Westfalia
2007cc Type 1 (90.5x78) |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Mar 17, 2010 7:28 am Post subject: |
58deluxerag wrote: |
Have one on my Monster 15 window, works great. |
X2 _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
SkooobaSteve Samba Member
Joined: March 23, 2005 Posts: 3152 Location: Dothan Alabama
Posted: Wed Mar 17, 2010 8:09 am Post subject: |
YOUBUGME2 wrote: |
crofty wrote: |
X2 |
You have a monster 15 as well.. |
I have one on my 65 _________________ Your Vanagon sucks, Stop waving at me.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Wed Mar 17, 2010 8:56 am Post subject: |
I would engineer a way to mount it to the tranny horns rather than the trans. I have seen the bolts get boogered (as has been said) but they also put undo stress on the tranny mounts, as all of that force goes straight into the mounts when making a hard turn.
They do work well, though. _________________ nothing |
tomflies1 Samba Member
Joined: October 23, 2005 Posts: 15 Location: West Hills, Ca.
Posted: Sun May 23, 2010 11:15 am Post subject: Confused about the rear camber problem on the split buses |
I've been reading here that the positive camber on early buses is a common problem, but it seems some say to use an add-on camber compensator and others to adjust the torsion bars. I have a stock 65 21W, just finishing it up, but it looks pretty odd from behind. \ / Feels kinda squirrely, doesn't seem to track as straight as it should. New steering box, all new steering etc. Stock wheels and size tires. What should I try first? Ideas/suggestions? |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Sun May 23, 2010 12:06 pm Post subject: Re: Confused about the rear camber problem on the split buse |
tomflies1 wrote: |
4 wheel alignment check _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
RobzKombi Samba Member
Posted: Tue Nov 09, 2010 8:13 pm Post subject: |
Just purchased an Empi CC which will soon be installed on my DC and while searching for pictures of CC installed I ran into this photo,
Didn't realize it was possible to install a rear swaybar on our buses. What are your thoughts on this set up, good idea or overkill? |
blackdog1999 Samba Member
Joined: October 17, 2004 Posts: 1203 Location: Rancho Cordova, CA 95670
Posted: Tue Nov 09, 2010 8:20 pm Post subject: |
RobzKombi wrote: |
I would love to see pics of the (2nd) swaybar off of the Bus. I would run that setup on my Kemperink. _________________ Home of the one true split Bus Motorhome |
Clara Samba Member
Posted: Tue Nov 09, 2010 10:31 pm Post subject: |
I have an old EMPI camber compensator on my '61 and it works great.
I easily drove 10mph faster on a certain windy road without even realising it. I was pleasantly surprised.
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
natnmike58 Samba Member
Joined: December 23, 2005 Posts: 16 Location: Arizona
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Sun Oct 23, 2011 11:47 am Post subject: |
I love my cc _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Sniperx Samba Member
Posted: Sun Oct 23, 2011 12:09 pm Post subject: |
So what exactly do these do? I don't want to affect my ride height to much...I like it as tall as I can get.
I understand they make handling "better", but what is the process they are working on. They look like they keep the axles down...which is what they kinda want to do anyway. Is it just adding another spring basically? |
Busryder Samba SuperHero
Joined: September 17, 2007 Posts: 1663 Location: In Your Face...
Posted: Sun Oct 23, 2011 12:10 pm Post subject: |
slow36hp wrote: |
i believe they are all the same as the relationship between the parts and attachments are the same. |
Please correct me if I am wrong.... but I do not believe this to be true.
Have a look at the differences between the CC's in the first two links the OP provided...
So Cal Imports' CC:
And, the ridiculously overpriced ($205 ), BugPack CC from Fisher Buggies:
In both images, you can see that the 'compensation bar' is bent/angled at an upward slant. From my understanding/experience, this angle produces an upward force on the axle tubes that will work in a bus that has a straight-axle trans. Notice the red urethane 'pads' that contact the tubes... I have this set-up on my Westy.
But in an RGB equipped bus, like Clara's awesome bus, The opposite forces are needed... as Clara's example illustrates, there are straps that hold the RGB tubes down, and the 'compensation bar' is not bent, but is straight instead:
In the OP's last link, the CB Camber Compensator has these same spec's, save for the mount at the transmission, (and is reasonably priced too.):
CB images are protected by copyright and I cannot post the example image, so just click this Link:
http://www.cbperformance.com/catalog.asp?ProductID=463
This is the one that I think would work for your application.... but again, I could be wrong on this whole thing. I am not an expert... so take this with a grain of salt.
But I too, love my CC. _________________
Lind wrote: |
Apparently I was just the lucky asshole that showed up at the right time. |
I am a Dick, hear me roar-
Me, an OVP Lifer... |
