bjeles Samba Member
Joined: September 13, 2005 Posts: 139 Location: Davison Michigan
Posted: Thu Feb 23, 2012 12:41 pm Post subject: |
I sold a RHD pedal pan a couple years ago on here, the cutout was different but the pan was the same stamping. I can't seem to pull up the picture but here is the add ID if you can pull up the pictures EV.
1014310 _________________ My cars
1961 rag
1962 convertible
1965 double cab
1965 SO-42 http://www.thesamba.com/vw/forum/viewtopic.php?t=470425&highlight=survivor+westy
1974 thing |
EverettB Administrator
Joined: April 11, 2000 Posts: 69696 Location: Phoenix Metro
Buba Samba Member
Joined: February 23, 2003 Posts: 383 Location: Argentina
Posted: Mon May 21, 2012 12:32 pm Post subject: |
Here in Argentina is very difficult to get a pedal pan, and I would like to know if a later 63-66 pedal pan can be placed on a 57 and 60 without modifications.
Regards
Marcos _________________ 52 Ambulance
57 SC
57 Oval
60 SO23
60 Bug |
Buba Samba Member
VW Addict Samba Salesman
Posted: Tue May 07, 2013 8:33 pm Post subject: |
Everett,
Great post. Thanks. You are a wrath of great information! |
KombiMarc Samba Member
Joined: January 29, 2010 Posts: 431 Location: Phoenix, Az
Posted: Mon Oct 28, 2013 4:44 pm Post subject: |
VW Addict wrote: |
Everett,
Agreed!!!
One follow-up question:
Based on the info provided, the early style pans cover 55-60. Within that group, 55-57 and 58-60 are pretty much the same with the only notable exception being that on the 55-57 the front lip is "flat" at the mounting holes and on the 58-60 the mounting holes are recessed or pressed a bit??? Is that the only way to tell the difference on the early ones?
Thanks! _________________ ________________
Thanks Marc
________________
'65 Type I
'65 Type II Kombi Rebuild Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=459009 |
Stocknazi Samba Member
Posted: Mon Oct 28, 2013 5:16 pm Post subject: |
KombiMarc wrote: |
VW Addict wrote: |
Everett,
Agreed!!!
Thanks! |
the earlier pans also have a spotwelded tab on the side; later pans have the tab as part of the stamping; someone might chime in with the approx. date of that change _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Mon Oct 28, 2013 5:17 pm Post subject: |
KombiMarc wrote: |
VW Addict wrote: |
Everett,
Agreed!!!
Thanks! |
the earlier pans also have a spotwelded tab on the side; later pans have the tab as part of the stamping; someone might chime in with the approx. date of that change; there is a good splash pan thread somewhere that has lots of pics of the various pans _________________ WANTED:
Thomas Jefferson |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3775 Location: Twin Cities, MN
Posted: Sun Nov 10, 2013 7:37 pm Post subject: |
Can someone clarify the difference between a pedal pan for a 1957 versus one for a 1958?
Are they the same? |
Posted: Sun Nov 10, 2013 7:55 pm Post subject: |
nlorntson wrote: |
the pans changed sometime in 57 corresponding to the recessed bumps on the backside of the inner valance
the earlier 57 pan would have been smooth across the front lip
some info can be found on page 1 of this thread _________________ WANTED:
Thomas Jefferson |
Posted: Sun Nov 10, 2013 8:04 pm Post subject: |
StockNazi wrote: |
some info can be found on page 1 of this thread |
Are you referring to the recessed holes where it bolts to the front of the bus?
So 57 has a flat lip and the 58 has the recesses? |
Posted: Sun Nov 10, 2013 8:14 pm Post subject: |
nlorntson wrote: |
StockNazi wrote: |
yes
no, the change occured sometime in 57, not sure of the exact date; maybee someone will chime in that knows _________________ WANTED:
Thomas Jefferson |
ritchiet002 Samba Member
Joined: January 27, 2003 Posts: 1676 Location: Kaneohe, HI
Posted: Fri May 23, 2014 6:35 pm Post subject: |
I assume that the tabs with the holes that are "turned up" attach to the back of the rear valance? Do the repo rear valances have the corresponding holes and nut plates? _________________ Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________ |
schnidlee Samba Member
Posted: Tue Jan 19, 2016 3:04 am Post subject: Re: Pedal pan / Front splash pan |
Can anyone shed some light on the hardware used to hold the pan in place? i looked at the pics and there seems to be some running screws and some running hex heads. What size and pitch thread do I need? Thanks |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24643 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jan 19, 2016 8:03 am Post subject: Re: Pedal pan / Front splash pan |
See page 2.
If you do not have the time to read thru a post...
At top of each page is a search box you can locate info like this in a single forum. Then it will show you any entries with that word you are searching for. We entered "Hardware" and got this:
http://www.thesamba.com/vw/forum/search.php?search...ults=posts
Then just clicked on the highlighted subject of that to be taken to that result.
Also a great resource for figuring out part is the parts manual here:
http://oacdp.org/5867part.html
Tis a must to go thru over and over. Doing so will result in finding parts you did not even know existed and probably need. _________________ In Stereo, Where Available! |
Posted: Tue Jan 19, 2016 9:06 am Post subject: Re: Pedal pan / Front splash pan |
In this case, just look at page 1.
There is a summary in the first post of this thread.
Hardware is included there.
I am not sure what the size for the sheet metal screws are.
I went to my local Ace hardware and found some that worked fine.
On the last Bus I did, some spots had welded-on nuts for the M6 (10mm head) hex head bolts.
Some spots had nothing there so I used the sheet metal aka self-tapping screws. _________________ How to Post Photos
RHD Notch Samba Member
Joined: April 06, 2007 Posts: 1412 Location: Joshua Tree, CA
Posted: Tue Jan 19, 2016 10:03 pm Post subject: Re: Pedal pan / Front splash pan |
#28 & #29 on my Type 2 Parts List. _________________
Lind wrote: |
I am at the point where I hardly want to own anything that isn't original paint. |
campingbox wrote: |
I have some other projects I'd like to finish first and I want to drive this bus while I'm working on those to help stay motivated. |
Posted: Tue Jan 19, 2016 11:30 pm Post subject: Re: Pedal pan / Front splash pan |
Thanks guys, I was looking at pictures and not reading. |
