titan Samba Member
Joined: August 19, 2007 Posts: 53 Location: pittsburgh,pa
Posted: Thu Mar 11, 2010 9:34 am Post subject: wire identification please |
My thing is back from media blast. I want to plug in my windshield wiper motor but I cant remember which wire goes to which plug. can anyone help me or post a picture so I can plug it in correctly?
thanks
marc |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
tallman206 Samba Member
Joined: January 06, 2006 Posts: 316 Location: St.Petersburg Florida USA
Posted: Thu Mar 11, 2010 10:15 am Post subject: |
Please be careful!
The picture above is labelled incorrectly!
The correct wiring can be found in the Technical section under wiring, Thing current flow diagram.
Terminal 53 = Black Wire = Motor Low Speed
Terminal 53b = Black Yellow Wire = Motor High Speed
Terminal 53a = Black Grey Wire = Motor constant power from fusebox 15
Terminal 53e = Green Wire = Park Circuit to switch
Terminal 31 = Brown Wire = Ground or Earth
The pictures in the archive need to be updated or stricken, as they provide incorrect information.
Jerry |
titan Samba Member
Posted: Thu Mar 11, 2010 2:02 pm Post subject: |
thank you for ur help.
Ok, the picture diagram has incorrect labels, but are the wires attached correctly to the motor in the picture. If so, I think I can copy the picture when pluging my wires in.
For what it is worth, I do try and use the search function before I post, but I rarely find the correct posts which answer my questions. I don't know if I do it wrong or what, but it seems like I always get tons of posts from my search which don't help much. I do appreciate ur help though! |
Posted: Thu Mar 11, 2010 3:29 pm Post subject: |
tallman206 wrote: |
The picture above is labelled incorrectly! |
That sucks. There are two other version of that pic with different labels, the one I posted was the latest.
Here are the other two:
tallman206 wrote: |
Jerry |
The first one I posted is not that inaccurate, one terminal is listed with the wrong number (31b instead of 53e) otherwise the wires, positions and functions are correct. _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
