Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Oct 03, 2010 11:10 am Post subject: |
Tim MacDonald wrote: |
I shorted the solenoid and it sounded like it spun but did not engage the starter. |
Solenoids do not sound like they "spun". The starter motor does spin. Solenoids are a magnetic pulling device, which give off a clunk when engaged.
So it sounds like you jumpered across the solenoid and spun the starter motor.
Except for the voltage to the coil with engine not running it sounds good. _________________ In Stereo, Where Available! |
Tim MacDonald Samba Member
Joined: October 11, 2004 Posts: 1346 Location: Edmonton alberta
Posted: Sun Oct 03, 2010 2:09 pm Post subject: |
Eric&Barb wrote: |
Except for the voltage to the coil with engine not running it sounds good. |
Should the starter ingage and turn the engine over with the key in run position when I jump the solonide or just spin like it does?and what should the voltage be at the coil when it is not running?Does it sound like the starter is bad to you? _________________ 61 so34 flip seat
78 automatic champagne Westfalia
84 mint original paint westfalia
57 oval project barn find
88 cabriolet |
Posted: Sun Oct 03, 2010 6:35 pm Post subject: |
Starter will engage with ignition off, or in run position, or even if you took out the switch, if you jumper from the terminal on the solenoid that is connected to the battery positive terminal to the smaller red wire on the solenoid.
Right now sounds like bad solenoid, or bad ignition, or bad connections between the two. _________________ In Stereo, Where Available! |
Posted: Tue Oct 05, 2010 7:05 pm Post subject: |
Here is an image stolen from the gallery:
The cable on the left is from the battery and to the ignition switch. Lots of other wires there due to being late bus.
On right you can see that terminal is connected to the starter motor itself.
Top is the solenoid terminal, that is where the voltage from the ignition switch goes when you turn it to "Start" position.
Lower terminal is due to late bus, and not on earlier starters.
So if you remove the top terminal wire and check voltage with helper turning ignition switch to "Start" position. What voltage do you get?? _________________ In Stereo, Where Available! |
Posted: Sat May 11, 2013 1:13 pm Post subject: |
So what voltage did you find there or did you even get your VW running? _________________ In Stereo, Where Available! |
quartermilecamel Samba Member
Posted: Sat May 11, 2013 2:56 pm Post subject: |
12.7 volts at coil means voltage drops all the way back to charging system and or charging system NOT up to snuff. 13.5 at coil is where it should be assuming you are running an alternator at idle. Generator at idle is less. Cant remember exact gen idle charging specs. I soldered my fuse box, headlight switch, and cleaned up grounds, which got much better charging voltage at battery. To an untrained auto electricial tech, just load testing the battery would reveal a weak battery. That was what I was getting, poor voltage. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Sat May 11, 2013 3:54 pm Post subject: |
i solved that problem some times by using a new starter. the ones that spin faster, the bosch with reduction gears. not the special ones, the modern standard replacement. they have more torque in difficult situations like that. try it.
these ones. cheap and really good!
