69busboy Samba Member
Joined: December 22, 2009 Posts: 47 Location: beaver pa
Posted: Sun Mar 14, 2010 3:12 pm Post subject: sliding door track repair... |
has anyone ever replaced the lower track for the sliding door???i'm looking for advise or a good thread on this ...i have never done body work before so i am currently taking a welding class...hoping to fix it myself... _________________ 1973 rusty westy......73 transporter (westerner package)...79 transporter auto/ac.....gone but not forgotten.......... |
1971BUS Samba Member
Joined: December 02, 2009 Posts: 19 Location: Brandon, MB. Canada
Posted: Sun Mar 14, 2010 3:42 pm Post subject: spooky |
Check out this guys website, he replaced lots of rust and has lots of pictures and step by step instructions as to what he did...
http://www.specialpatrolgroup.co.uk/spooky/ |
HunchyHillBilly Samba Member
Joined: February 14, 2008 Posts: 11 Location: Sunshine Coast Australia
Posted: Sun Mar 14, 2010 4:11 pm Post subject: Re: sliding door track repair... |
69busboy wrote: |
has anyone ever replaced the lower track for the sliding door???i'm looking for advise or a good thread on this ...i have never done body work before so i am currently taking a welding class...hoping to fix it myself... |
Here is a very good article on the subject:
http://www.specialpatrolgroup.co.uk/spooky/sills/ns/ns.html
Cheers. |
Bradgt74 Samba Member
Joined: May 04, 2009 Posts: 251 Location: Minneapolis
blatzer Samba Member
Joined: June 27, 2007 Posts: 358 Location: Austintatious- aka ATX
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Tue Jan 31, 2023 9:43 am Post subject: Re: sliding door track repair... |
You have to use the Wayback Machine:
http://archive.org/
Websites are temporary things. It is always a good idea to create a local copy of especially useful ones, because sooner or later they will disappear. _________________ '67 bug: seized by the authorities
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1196 Location: Vancouver, BC
Posted: Tue Jan 31, 2023 10:15 am Post subject: Re: sliding door track repair... |
69busboy wrote: |
I replaced all 4 jack points and a few crossmembers as well as the door track on my 76 a few years ago but I'm sure that there are some better threads on "how to". The key thing for me was using straps to hold the sliding door in place (closed) and tacking the rocker and rail in place then removing the door and doing a few welds and refitting the door to test fit. It took a few trial and error test fits and rewelds to get it close. I'm not a proficient welder so it took me a while to fit it as I was working by myself most of the time.
_________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Tue Jan 31, 2023 10:26 am Post subject: Re: sliding door track repair... |
I did this repair over 20 years ago using the instructions from the site mentioned. The only difference is, I used a complete piece, which made the job easier. The welding itself is not difficult, but fitting the track so that the door opens and closes properly AND lines up with the surrounding body work is a real pain. I bolted and clamped the track on so I could get it as close as possible before welding. I must have opened and closed that door hundreds of times, adjusted the door, realigned the track etc before I started welding. I welded a little at a time, checking the door fit every so often to make sure nothing had shifted.
Depending on how rusty the track is, you might be able to just replace some of the pieces. It may be easier, but hard to tell without picks. |
typ914 Samba Member
Joined: October 19, 2012 Posts: 231 Location: Atlanta, Ga
Posted: Tue Jan 31, 2023 6:08 pm Post subject: Re: sliding door track repair... |
I need to replace about 12” to 18” of bottom track and weatherstripping channel on my 78 Westfalia. I hope to do it in the next few weeks. I purchased a used rocker and plan on cutting out what I need for the repair. I plan to post pic. |
Vangabonders Samba Member
Joined: January 15, 2013 Posts: 174 Location: Chattanooga TN
Posted: Sun Apr 30, 2023 3:15 pm Post subject: Re: sliding door track repair... |
the spooky way is definitely the way to do it!
_________________ 73 tintop to poptop westfalia (Frankenbus) |
