DrDarby Samba Member
Joined: May 12, 2004 Posts: 6534 Location: Northern Illinois
Posted: Mon Mar 15, 2010 9:35 pm Post subject: Help me identify oddball distributor |
This one has me stumped. This is a centrifical advance distributor, at 1st glance the housing is similar to a Bosch 009 but has early 2pc bolt together points, early condenser, early cap with notch over the points connector and external cap indexing tab. I had a tune up kit for the 383 distributor from my split window..Cap, Points, Condender and all fit perfectly. I don't have a proper new rotor however, an 009 rotor is about the same size but the shaft is slightly smaller so the 009 rotor falls right off.
There are absolutely no markings on it. There was a nearly destroyed small silver decal but all I could make out was "made in the USA"
_________________ Midwest Autosavers, Inc. Woodstock, IL |
a.wilson Samba Member
Joined: January 11, 2007 Posts: 2033 Location: Georgia
Posted: Tue Mar 16, 2010 4:31 pm Post subject: |
Well.. I can't tell. Is the distributor body made of aluminum?
Only guessing that maybe it is something from EMPI or one of their competitors from long ago. Almost looks like for industrial use rather than for a VW. _________________ Be kind to all critters. America's "H8TERZ" can drink sludgy used Motor Oil!
oemwolf |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Tue Mar 16, 2010 4:33 pm Post subject: |
I think "Resolit" made an 010 copy that was alum body... |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Mar 20, 2010 7:31 pm Post subject: |
True keifernet. I sold one recently. It did not have that old style wire lead bolt though. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Migit Banned
Joined: July 09, 2004 Posts: 831 Location: Central Illinois
Posted: Sun Mar 21, 2010 1:15 pm Post subject: |
Could be an 019 too.... need Glenn to ring in here with some specifics on weights to tell for sure _________________ Looking for a 58 euro hardtop! |
Posted: Sun Mar 21, 2010 8:29 pm Post subject: |
Glenn's not the only one around who can tell the difference between an 010 and and 019... _________________ Roads Scholar &
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Mar 22, 2010 3:50 am Post subject: |
Looks like a Brazilian knockoff but can't tell from here if it's a 010 or 019 copy from these pictures.
I've taken a few of them apart and their quality is not even close to the Bosch. _________________ Glenn
Member #1009
#BlueSquare |
