Daddybus Samba Member
Posted: Sun Mar 21, 2010 9:24 am Post subject: 911 gauges in a 356? |
Will 911 speedo, tach, and combo gauge (oil temp and pressure) fit into the 356 dash? What sizes are the 911 stuff. |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Sun Mar 21, 2010 12:40 pm Post subject: |
Hack for tach only. |
Posted: Mon Mar 22, 2010 10:01 am Post subject: |
So the tach is larger than 100mm. |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Mon Mar 22, 2010 10:11 am Post subject: |
What year 911 gauges?
'65-69 is 110mm
'70-85 is 115mm
Plus you'll need a resistor to compensate for fact that they read pulses for a 6 cylinder and not a 4 cyl. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Posted: Mon Mar 22, 2010 3:13 pm Post subject: |
I'll check out a 914 tach then. Anyone know the size of a 914 tach? |
Jacks Samba Member
Posted: Mon Mar 22, 2010 11:23 pm Post subject: |
hack again |
Posted: Tue Mar 23, 2010 1:30 pm Post subject: |
What gauges can I use in a '65 356 (currently gaugeless). I need a speedo and a tach. |
TC/TeamEvil Samba Member
Posted: Tue Mar 23, 2010 2:29 pm Post subject: |
For the speedo, use one from a Porsche 914, they register 140 mph so there's some cool factor built right in. The early-style bezels are the nicest in that they look like those from the 356, but painted black. They were originally took the signal from the transaxle, but work perfectly hooked up to the VW driver's side wheel and accept the stock early-style threaded collar VW speedo cable. I used one from a '71 Ghia. Perfect ! !
For the tach, I used one from a Porsche 944:
http://cgi.ebay.com/ebaymotors/1987-PORSCHE-944-Ta...ccessories
I just replaced the conical plastic lens with a flat one and DONE ! ! It's a basic electric four cylinder VDO tack with the basic negative side of coil hook up. Easy Peasy.
Both gauges are white letters on black, the bezels match and they're both VDO for a nice clean look. Use the 2 1/6 VDO oil pressure, oil temp, volt gauges from the center console of a Rabbit, Fox, Saab, etc. and everything will match up beautifully and you can get them on Ebay or at a junk yard for nearly zip ! ! ! !
Luck— |
Posted: Wed Mar 24, 2010 12:58 pm Post subject: |
Thanks man |
