donmurray Samba Member
Joined: December 30, 2008 Posts: 841 Location: Frisco Texas
Posted: Sun Mar 21, 2010 10:49 am Post subject: Stronger than stock trans mount for 74 |
Need HD transmission mounts for a 74 (Ghia). I believe the standard ones are 3 bolt mounts, and probably the same as 73-74 Beetle. It looks like the online stores only have HD mounts for earlier 2 bolt setups. One of the vendors suggested I convert to use the earlier 2 bolt mount. What's involved in making this converstion? If one of the special braces (Berg?) is an easier solution than a mount conversion, I would like to hear about it. Seeing some stories about the polyurethane mounts breaking, or too noisy for street. If there are some proven, 3 bolt, poly mounts avaiable then would like to know about those also.
This is a street car with a 2110 engine, but no drag race starts or speed shifts. Still, I would like to have some confidence that the trans will stay put and shift OK. _________________ 74 Ghia, with 2110 engine |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sun Mar 21, 2010 10:57 am Post subject: |
I have urethane motor mounts , a stock 2 bolt front mount, and i use a nose cone strap..on a baja and has worked fine for years. I wouldn't convert the mount just get a front tranny strap. easy install |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sun Mar 21, 2010 11:00 am Post subject: |
You can convert the rear mounts to the earlier style but the front you can not convert.
Berg HD rear mounts
Berg mid mount
_________________ Glenn
Member #1009
#BlueSquare |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Mar 22, 2010 12:02 am Post subject: |
i swapped out mine
the late model design is absolutely hopeless
blatantly obvious cost cutting on VWs part thats for sure
its a straight swap if you have the cradel and the mounts
the later one at the top is so much thinner and prone to bending as you can see by my old one, rubber mounts are crap too
_________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Mon Mar 22, 2010 12:12 am Post subject: |
Did the swap on A friends 74 baja, it was A straight swap just got the early type from A parts car went and got some polyurethane bushings and it was all good.. |
chiprodriguez Samba Member
Posted: Mon Mar 22, 2010 12:41 am Post subject: |
The later model trans mount set up is far from cost cutting on VW's part. VW has done nothing but improve year after year from the split window era. The late model/super beetle years being the best from the quiet .93 4th gear, long soft torsions and spongy trans mounts giving the car a ride that is smoother than most new cars built today. However, when extra horsepower and built transmissions are added which VW never anticipated, these stock components may come up short. A stock early two bolt nosecone mount or a Berg padded midmount would be much stronger without sacrificing ride or cabin noise/vibration as well as the earlier cradle mount bell house setup. |
Joel Samba Member
Posted: Mon Mar 22, 2010 1:00 am Post subject: |
i can find plenty of examples of cost cutting on late bugs
just look at all the stuff that was metal originally and was made from plastic towards the end like inside door handles and surrounds, window winder handles, hood and decklid handles, rear numberplate light housing, steering column housing etc etc
and late model front tranny mounts, those are just nasty
but i do agree with you though they maintained quality where they could
especially compared with other manufactureres at the time _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Posted: Mon Mar 22, 2010 8:26 am Post subject: |
Some helpful stuff coming up here. My Ghia is not on stands right now, so can't look to see what I have. Are the front mount piece and the rear cradle just bolt in, or will some cutting and welding be needed? If bolt in, that sounds like the way to go. Then I can buy some HD or Rhino mounts.
What about the down load stress at the rear of the frame horns? With the above mods, and easy street use can I leave this stock? If some bracing is advisable, then what's the easiest method for a little help at the horns? The Berg traction bar looks like an easy install. Will it clear the A-1 sidewinder type exhaust? _________________ 74 Ghia, with 2110 engine |
Posted: Wed Mar 24, 2010 6:53 pm Post subject: |
Looks like limited solutions available for a 74 Ghia. No one is making a bolt in mid mount. Strap kits are available that have a front and rear strap, but I hear opinions from "worthless" to "they are better than nothing".
So, here's the configuration I'm now thinking about.
1. A new stock, 3 bolt, front mount. HD if available. Think Berg has them.
2. Front strap to secure the nose. There are doubts about how effective these straps are, but surely it would help as long as there was some tension maintained on the cushioned top strap. CIP1 also sells a front brace that bolts in under the nose, but not sure it will fit the 74. I've asked CIP1 about that.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C26-311-204
3. Convert to the earlier (pre 73) version metal cradle and use early version HD (Rhino?) mounts. CIP1 sells this cradle with a strap, although I don't see how a strap at that point does much to keep the tranny from rotating down in the rear.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D9543
4. Kafer brace for the horns. Bugpack has one. About $160 I think.
http://www.bugpack.com/content.php?id=561
I'm thinking that bracing those rear mount points so they are less prone to bending down will also provide some resistance to lifting at the nose. It will move the rotation point aft which should require more torque to lift the nose. Any opinions on this theory/speculation/conjecture? Think I will avoid the Berg type traction bar under the rear of the engine. Afraid of interferrence with a Sidewinder exhaust, and possibly other pieces.
Then, if we're going that far, may as well take the trans somewhere and get 3rd & 4th gears welded. Anything else I should do to make a 74 transmission street durable? _________________ 74 Ghia, with 2110 engine
Joel Samba Member
Posted: Wed Mar 24, 2010 7:01 pm Post subject: |
you should be able to run a berg style mid mount like this
and either leave the stock front mount or remove it all together
thats all most of the guys here with 200hp+ WRX engines use with a kafer brace
ive only got 150hp but with stock early rear cradel and mounts and a stock mount with a 5 bar kafer brace its tight as _________________ Quick little bug, you got a Porsche motor in that?
Posted: Wed Mar 24, 2010 7:08 pm Post subject: |
Joel,
I asked Berg about a bolt in mid mount and they said it was not available for my model. Said there was one that required some welding. I'm a little confused about this, as it looks like the one pictured would fit. Is the nose cone bolt pattern different from 73 on?
So you don't have the pictured mid mount, or anything but a stock mount on the nose? _________________ 74 Ghia, with 2110 engine |
Joel Samba Member
Posted: Wed Mar 24, 2010 9:34 pm Post subject: |
the nose cone bolt pattern is the same and so are the chassis forks etc, thats why i cant understand why they're saying it wont fit
yep thats right, my earlier rear cradle pictured above that i fitted actually came from an early 60s splitty and i just use OEM german rubber mounts
tried the pretty red poly ones and dont like them
i want to fit a mid mount but i'll probably just make my own
i havent at this stage as my coolant lines run where the tabs weld to the forks but i need to rework that so my swaybar fits as well
i also have one of the aussie made 5 bar kafer braces
Bruce Samba Member
Posted: Sat Mar 27, 2010 6:58 pm Post subject: |
Buggin_74 wrote: |
The late bracket is only prone to bending when some MORON puts his floor jack under it and lifts the whole car. Put the jack in the correct location and the stock rear mounting system works just fine.
Buggin_74 wrote: |
You will still need the stock front mount with that setup. Otherwise there's nothing to stop the engine from moving front to rear. _________________
Joel Samba Member
Posted: Sun Mar 28, 2010 12:36 am Post subject: |
actually they're perfectly fine without the front mount
i can show you plenty of bugs where the stock mount has been removed and just a berg style mid mount run, and been fine for years with more than 200hp at the wheels _________________ Quick little bug, you got a Porsche motor in that?
gooser Samba Member
Joined: February 21, 2008 Posts: 766 Location: danville virginia
Posted: Sun Mar 28, 2010 4:46 am Post subject: |
Bruce wrote: |
Buggin_74 wrote: |
oops, i'm a moron.
Buggin_74 wrote: |
You will still need the stock front mount with that setup. Otherwise there's nothing to stop the engine from moving front to rear. |
dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Sun Mar 28, 2010 4:55 am Post subject: |
Bruce wrote: |
Buggin_74 wrote: |
Buggin_74 wrote: |
I have to agree, in the top picture,showing 2 rear trans mounts.{the lower mount} is commonly sold as a HD design.This is a misconception. As you can see the one on the left has started separating the rubber from the steel. This is a bonded joint and subjected to a lot of shearing forces as the engine torques. The mount shown in the upper part of the picture is by far one of the strongest mounts VW offered. It is for the 73-79 Beetle/ 73/74 Ghia but will work on any VW 12 V Beetle/Ghia. The rubber is much wider giving a larger surface are to bond the rubber to the steel components.
Also if you look at the way the steel portions of the mount are constructed you will notice that it is designed to be interlocking. What this does is greatly limit the amount of travel within the mount and should the rubber separate from the steel you still have a physical connection between the trans and the frame. The steel used is more than twice the thickness of the earlier design mounts.
Also the 73 and up front mount is the strongest VW offered and can be adapted to fit most frames.
If you need more strength in the front mount {high HP engine or like dumping the clutch} you should use the Berg style mid mount as seen in the lower picture, or something similar. Keep in mind that all forces generated to move the car forward are sent through this mount. When you see a car lifting the front wheels, it is the front mount that is supporting that weight. _________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone |
Posted: Sun Mar 28, 2010 8:36 am Post subject: My transmission mount solution |
After much forum reading and some vendor feedback:
This is for a 74 Ghia with 2110 engine. Easy on the clutch driving, but do like some hard acceleration in 2nd and up. No big increase in noise or vibration.
1. Good quality standard front mount. $30 est.
2. EMPI 9531 padded front strap kit. Like this strap because it's has a more direct tension load on the top strap and bracket. Some other straps look like they would give more. $55
3. EMPI 9541 cradle and padded strap kit. Uses earlier mounts. The strap should keep some HD mounts together, and snub the transmission up a little more. $60 This cradle is supposed to be a mounting point for the Bugpack Kafer style truss which I may add later.
So far we're at less than $200, and I think there's a good chance that this will be all that needed for me.
The Bugpack truss is a lighter version of a Kafer setup, and if I see signs of too much movement back there, I'll add it for $160.
Don't give me any noise about EMPI quality. All their stuff can't be bad, so let's don't fall victim to pattern thinking and miss out on a resonably priced appropriate solution. _________________ 74 Ghia, with 2110 engine |
vwsteve Samba Member
Joined: March 18, 2004 Posts: 1047 Location: Virginia
Posted: Sat Aug 24, 2019 3:19 pm Post subject: Re: Stronger than stock trans mount for 74 |
On the newer style, do you even need the cross piece? I am replacing an older style setup but I don't have the cross piece. I could find one but just wondering what the purpose even is. |
Glenn Mr. 010
Posted: Sat Aug 24, 2019 5:12 pm Post subject: Re: Stronger than stock trans mount for 74 |
Yes, it ties the frame horns together. _________________ Glenn
Member #1009
#BlueSquare |
