sepulvedac Samba Member
Joined: December 10, 2005 Posts: 145 Location: San Antonio, TX
Posted: Sun Mar 21, 2010 11:14 am Post subject: fuel injected engine hesitation |
I got a 79 Super Beetle fuel injected. Engine was rebuilt less than a month ago. It was g\running great. On the way home my lady filled the tank up and lost the tank cap. We installed a cheapo gas tank that it looks like a bus one. Now the car hesitates while driving and it is getting worst by the minute. Does the fuel tank has to be pressurized? Any way to find out if it is the cap doing this? I checked everything electric and all check out fine. What else to check? |
Randy in Maine Samba Member
Jaygyver Samba Member
Joined: March 29, 2008 Posts: 124 Location: The Loooongview area
Posted: Sun Mar 21, 2010 1:04 pm Post subject: |
Your tank needs to be VENTED. Not pressurized.
Quote: |
We installed a cheapo gas tank |
Do you mean CAP?
Do you know if the new gas cap is Vented? Try leaving the cap un-screwed a few turns and then try a short drive and see.
IF that doesn't work then try what randyinmaine mentioned. |
zeroman Samba Member
Joined: February 05, 2010 Posts: 891 Location: Cane field
Posted: Sun Mar 21, 2010 11:02 pm Post subject: |
the stock super gas cap on the FI engine doesn't have a vented cap does it?
I had horrible hesitation when I knocked a hose off the junction that's attached to the engine compartment on the drivers side hinge. The hose still was hanging like it was attached.. but it wasn't. It would barely run. Maybe if one is cracking would do that? |
Posted: Tue Mar 23, 2010 7:35 pm Post subject: |
new cap did the trick. No more hesitation. she drove from Pipe Creek,TX to Galveston,TX (302 miles) without any problems at all.
Thanks. |
