old_n_slo Samba Member
Joined: August 08, 2009 Posts: 269 Location: Air-id-zona
Posted: Wed Mar 24, 2010 4:25 pm Post subject: Headlamp switch removal - homemade tool |
This fabricated washer will remove your headlamp and washer controls from your dash without damage. Sure, go ahead and continue to use your needle nose pliers......or...
1. Grab a 9/16" washer from your bucket 'o fasteners.
2. With the edge of a file (or hacksaw) open up a gap.
3. File or Dremel a small relief where the pencil is pointed so it follows the curvature of the circular dash control nut.
Twist and shout!
The details:
a) Carefully pick your washer to ensure the correct "width"
b) Use a 15/64" drill to "gauge" your opening. That will be the size of the headlight switch shaft.
You know about using a nail to hold the shaft still, while twisting the knob to remove...right?
Enjoy!
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Wed Mar 24, 2010 4:35 pm Post subject: |
Nice tip, beats the hell out of $20 something! _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
&Dan Samba Member
Posted: Wed Mar 24, 2010 4:51 pm Post subject: |
Pretty frickin' great!
How many other homemade VW-specific tools are out there? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31268 Location: Hot Arizona
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Thu Mar 25, 2010 2:57 am Post subject: |
I like this - I had seen coupling bolts ground to have the 2 nubs - but nut driver idea is good too. Aren't we freakin geniuses? LOL. Good post - thanks _________________ D-Dubya Manx clone - 63 Short pan,1914.
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Thu Mar 25, 2010 6:47 am Post subject: |
Quote: |
but nut driver idea is good too |
X2, wonder about the 'inside' hole of the driver being large enough for the 'shaft'? _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Raul_MX Samba Member
Joined: May 10, 2007 Posts: 255 Location: Reynosa, MEXICO
Posted: Thu Mar 25, 2010 6:51 am Post subject: |
Can you please post a picture of the finished tool and while in use?
Regards. _________________ Click Here for a clicking sound... |
BajaCapt Samba Member
Joined: October 26, 2009 Posts: 150 Location: San Diego
Posted: Fri Mar 26, 2010 9:15 pm Post subject: |
Hey! thanks for this post, I doing a search for headlight switch removal and ran into it, gave me a good idea to go about it.
I made my own tool out of a butter knife, I used a dremmel with a cut off wheel and a sanding bit for finishing it off, works like a charm!
The tool and the things need it to make it ( about 20 minutes as well)
glutamodo The Android
Joined: July 13, 2004 Posts: 26297 Location: Douglas, WY
Posted: Fri Mar 26, 2010 10:39 pm Post subject: |
Here's my home-made tool, made from a piece of stainless pipe:
kolt10 Samba Member
Joined: March 18, 2010 Posts: 327 Location: Alamogordo, NM
Posted: Fri Mar 26, 2010 11:16 pm Post subject: |
this is great. i was able to twist two of my mine off with my thumbs but i have one that i cant get. I will use this tomorrow. |
kolt10 Samba Member
Posted: Fri Mar 26, 2010 11:21 pm Post subject: |
actually...im not now gonna make the tool. just used snap ring type pliers and they worked to fit in the slots |
Posted: Sat Mar 27, 2010 10:40 am Post subject: |
Made the washer tool yesterday since I was installing a light switch - worked great - and if I lose it, not biggy. Thanks _________________ D-Dubya Manx clone - 63 Short pan,1914.
Buck Naked Samba Member
Joined: March 11, 2009 Posts: 400 Location: El Dorado County,CA
Posted: Sat Mar 27, 2010 11:09 am Post subject: |
I think I hear the theme to `MacGyver` in the back ground. Seriously these are some great ideas thanks for info. _________________ Be unique, like everyone else.
'63 Beetle Ragtop |
Posted: Sat Mar 27, 2010 1:27 pm Post subject: |
If you need some more "gription" on the washer for torque, avoid the temptation to use pliers. They could slip and....well, I won't be responsible for scratches.
Vice grips. |
grandpa pete Samba Member
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1314 Location: Beaverton, Oregon
Posted: Sat Sep 20, 2014 11:11 pm Post subject: |
Know how those little nuts that hold down the single port intake pipes are a bitch to get on and off due to the limited room and the lip on the bracket? Well I picked these nuts up at ACE and you can use a rachet on 'em, removal and installation is a snap.
AlohaFlyer Samba Member
Joined: June 05, 2011 Posts: 79 Location: Kamuela, HI
Posted: Fri Dec 05, 2014 2:47 am Post subject: |
I made that tool and I am still having trouble getting those nuts to move... the previous owner painted the car without removing them, so I think that is partly why they won't move. I am afraid of stripping them... any ideas on how to get these to come off?
Thanks _________________ 1967 VW Bug - Savannah Beige, 1600cc
1971 VW Campmobile - Neptune Blue, 2180cc
1982 VW Vanagon Westfalia - White
2005 VW Passat TDI - Silver |
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 469 Location: Illinois
Posted: Fri Dec 05, 2014 5:36 am Post subject: |
Could you get some more torque if you used a tool like this?http://www.thesamba.com/vw/classifieds/detail.php?id=841285 instead of a small washer? _________________ 1966 Java Greens |
Posted: Mon Dec 08, 2014 7:05 pm Post subject: |
diablosandwich wrote: |
Could you get some more torque if you used a tool like this?http://www.thesamba.com/vw/classifieds/detail.php?id=841285 instead of a small washer? |
I just ordered that tool... thanks for the idea. I will let you know how it goes.
Mahalo,
RP _________________ 1967 VW Bug - Savannah Beige, 1600cc
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Dec 08, 2014 7:48 pm Post subject: |
I always just used needlenose pliers (the small 2-1/2" kind from cheap tool sales at gun shows). It moves the gripping surface out where an adult hand can hold it. I still have to be careful though. _________________
EverettB wrote: |
FU#5 |
