Tcash Samba Member
Posted: Mon Jun 18, 2018 11:17 am Post subject: Re: brake booster problems 71 vw bus |
As posted there are two pushrods.
Brake Pedal Push bar
Brake Booster master cylinder pushrod #4
The booster pushrod is adjustable on some replacement boosters. Replacement boosters have been causing the front brakes to drag, because the pushrod is too long.
https://www.thesamba.com/vw/forum/viewtopic.php?p=6059745#6059745
Good luck
Tcash |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Mon Jun 18, 2018 2:56 pm Post subject: Re: brake booster problems 71 vw bus |
Tcash wrote: |
Good luck
Tcash |
The last entry in that post is in 2012. Airtec makes a new booster that I don’t believe has that spacer washer. All I did when I installed mine was measure how far the pushrod protruded from the face of my old booster and adjusted the actuator on the new one to protrude the same amount. As I recall 7mm and 8mm wrenches are needed. Works fine. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
