dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Thu Mar 25, 2010 6:53 pm Post subject: Type 3 carb bellcrank pic needed |
I have used the search with no luck.
Like the title says I am looking for a picture that shows how and where the bellcrank for the dual carb linkage is mounted on the block. I am thinking of adding the stock dual carbs{32pdsit 2 and 3} from a type 3 to my 1500 sp Ghia.
Any help is appreciated.
Thanks _________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone |
Posted: Fri Mar 26, 2010 4:24 am Post subject: |
Does anyone have a camera that can take a picture for me? _________________ Licensed Automotive Service Technician
Current projects:
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Fri Mar 26, 2010 8:10 am Post subject: |
Thanks Max. It helps. I am tying to see exactly where the bellcrank attaches to the block before I tear into my 1500 type 1 style engine. _________________ Licensed Automotive Service Technician
Current projects:
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri Mar 26, 2010 10:13 am Post subject: |
It uses 2 of the top case 8mm studs.
There is also another piece that goes on the forward stud and the bolt, that stabilizes the cross over balance pipe, and supports the center of the air cleaner, to all of the weight of the air cleaner is not carried by the tops of the carbs. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Houstonr Samba Member
Joined: February 01, 2009 Posts: 399 Location: Frisco Texas
Posted: Fri Mar 26, 2010 1:15 pm Post subject: |
**hijack warning**
Max what is the deal with the terminal connections on your Generator? looks much cleaner than the standard posts/poles on mine. |
Bobnotch Samba Member
Posted: Fri Mar 26, 2010 1:19 pm Post subject: |
Houstonr wrote: |
**hijack warning**
That's the earlier style 12 volt generator. It used push on spade terminals, rather than the screw post style of the later types. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Mar 26, 2010 3:25 pm Post subject: |
Bobnotch wrote: |
Houstonr wrote: |
**hijack warning**
That's the earlier style 12 volt generator. It used push on spade terminals, rather than the screw post style of the later types. |
And do not use them if it can be avoided. They were a high resistance joint, and had problems with the connections overheating.
VW used that one year only. 1967. On Type 3 and Type 1. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Fri Mar 26, 2010 3:47 pm Post subject: |
They have gone into early 68 with them.
Are the wire connectors on that connection, original, or replacements? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sat Mar 27, 2010 5:14 am Post subject: |
Thanks to those who helped with my request.
Out of 10 responses two were helpful and two were my own responses.
Six were about Generator wiring. Come on, show a little courtesy and start your own thread. No wonder searching this site is a pain. _________________ Licensed Automotive Service Technician
Current projects:
Posted: Sat Mar 27, 2010 5:19 am Post subject: |
dan macmillan wrote: |
Six were about Generator wiring. Come on, show a little courtesy and start your own thread. No wonder searching this site is a pain. |
You are going to get that in an open forum, that is read by 100's of people.
You did get your answer, before the thread got hi-jacked. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sat Mar 27, 2010 5:36 am Post subject: |
Russ Wolfe wrote: |
You did get your answer, before the thread got hi-jacked. |
True, but I spend my time in many of the other forums here, and with over 1400 posts I have never seen it as bad or quick. The original hijacker knew what he was doing and could easily have started a new thread and linked to the picture. It makes it easier for future reference and searching. _________________ Licensed Automotive Service Technician
Current projects:
Posted: Sat Mar 27, 2010 6:42 am Post subject: |
As a moderator, I see this all the time, in other threads.
Not just the T-3 forum.
You got your answer in the first 2 posts. And someone noticed the difference in Max's generator and asked about it.
The biggest problem with searching and finding stuff on The Samba, is the way people title their posts. "I have a question about my car?" Does not search well.
And, you yourself have hi-jacked this thread even farther, by complaining about the hi-jack. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
