zuk Samba Member
Joined: April 08, 2017 Posts: 20 Location: Winchester, va
Posted: Mon Sep 24, 2018 6:00 pm Post subject: Re: Replacing chrome moldings on shaved body |
Im putting the smaller trim on my 66 which has had the holes welded up at some point, thinking about trim the plastic clip down so they are flat when you slide them in the trim, using more than normal and gluing them in place, then using the 3m trim tape. Has anyone done similar and how did it work out? |
laffytaffy206 Samba Member
Posted: Sat Sep 29, 2018 2:16 pm Post subject: Re: Replacing chrome moldings on shaved body |
can anyone shed some light on what the chrome is called on the door of this bug? cant find any info on it any place, do i need to make it all myself outta some chrome hood pieces?
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Oct 01, 2018 6:21 am Post subject: Re: Replacing chrome moldings on shaved body |
In all technicality this (white/red example) is a homemade knock off version of the Australian Flash Trim. (still looks good IMO)
Rolled double sided plastic chrome molding works very well too.
Good Flash Trim information from here. https://www.thesamba.com/vw/forum/viewtopic.php?t=203130
There were several versions offered.
This is the real deal MV12 or VW20 version which seems to be the most popular.
VOLKSWAGNUT wrote: |
MV12 VW20
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Joined: August 31, 2013 Posts: 12860 Location: North Carolina
Posted: Mon Oct 01, 2018 12:58 pm Post subject: Re: Replacing chrome moldings on shaved body |
Or, run a bead of urethane windshield adhesive down the center of the trim & press the trim to the side of the car & tape it in place for a few hours. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
swapchunk Samba Member
Joined: May 29, 2017 Posts: 3 Location: Washingtonville NY
Posted: Sun Dec 09, 2018 3:34 pm Post subject: Re: Replacing chrome moldings on shaved body |
So has anyone done the 3M tape with success? Shaving the clips down then adding a touch of glue so they dont move then adding double sided tape sounds like a good idea but wont there be spaces in the areas that dont have clips? Meaning only the areas with tape touch the body??? |
aRandomAggie Samba Member
Joined: January 24, 2018 Posts: 18 Location: Houston, TX
Posted: Sun Dec 09, 2018 9:29 pm Post subject: Re: Replacing chrome moldings on shaved body |
swapchunk wrote: |
I just did this a couple weeks ago with great results. PO had Cal-looked the car, so there were no clip holes in hood or doors. I used the tape below, ran 2 strips along entire length each piece of stock trim. Looks great and holds strong.
https://www.3m.com/3M/en_US/company-us/all-3m-prod...amp;rt=rud |
