Bustalgic Samba Member
Joined: March 30, 2010 Posts: 7 Location: Hamilton, Montana
Posted: Tue Mar 30, 2010 4:10 pm Post subject: Turn signal housing loose on a 1969 |
The cup-like "retainer for turn signal switch" is loose enough that it slips down the support bracket to the point that the canceling ring is not engaged. It also revolves too much when trying to operate the turn signal lever. I have to hold the whole housing when I operate the lever so it does not revolve. It often has revolved enough that it is not properly aligned for the canceling ring to work. I've disassembled it enough to see it appears to be just a friction fit against the insulating washer on the bracket. Is there a proper fix? I've seen someone place a radiator hose clamp around the retainer, but would rather not. HELP! |
busdaddy Samba Member
Posted: Tue Mar 30, 2010 4:35 pm Post subject: |
Welcome, the first thing you need to do is remove everything and straighten out the C shaped piece of steel that goes in the non switch side of the housing slightly, it's always bent too much, careful though, just a little squish in a vice or it won't go back into the housing. Now get yourself 3-4" of emory cloth and fold it in half lengthwise (gritty side out), wrap it around the column where the switch and the clamp you just straightened touches. You'll want to use locktite on the screws that hold the switch into the housing and give the switch a lube inside too, now put everything back together and gently tighten the screws holding the housing together, you may want to leave a tiny gap between the two and retighten it later if it starts to get loose. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Mar 30, 2010 7:50 pm Post subject: |
It is all back together and working well. Thanks for your prompt help. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Wed Mar 31, 2010 1:47 pm Post subject: canceling ring and turn signal repairs |
canceling ring?
Is there such a thing as a canceling ring on a '69?
My camper's turn signal has never canceled in the thirty years that I've owned it. I've always canceled the turn signal manually. I always thought it was something you had to do yourself, like oil changes and valve adjustments.
Aloha
tp |
Posted: Wed Mar 31, 2010 3:00 pm Post subject: |
Now that's some impressive zip tie work there!
Yes, all busses have self cancelling signals, if your switch was 2mm (or whatever dimension Bentley states) away from the bottom of the steering wheel it likely would cancel too. Follow the same procedure I just described for Bustalgic and see what magically happens, bet you could ditch the zip ties as well _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Wed Mar 31, 2010 3:46 pm Post subject: |
I kind-a like the ball of wire's in the photo. the steering wheel is as busdaddy said to far from the turn switch for them to cancel. I think them zip ties will be in the way. I have seen as far as the housing not clamping enuff to the steering colum I have found where those C shaped piece's go in the housing thay have pushed into the housing and can't clamp anymore. I have tryed to fix them but found the only good way was to get another housing. Say busdaddy I like that repair idea I will have to try that sometime. _________________ where its cold and snowy |
Bisbeetle Samba Member
Joined: August 20, 2010 Posts: 131 Location: Bisbee by the Sea
Posted: Sun Sep 12, 2010 12:12 pm Post subject: |
Great instructions; thank you. I couldn't find any emory cloth locally, but I have some 4" adhesive sanding disks, so I cut a 4" strip out of the middle of one and wrapped it around the steering column (wipe off the grease, first) where the switch clamps into place, and put it all back together. Snug as a bug. Er...bus. |
cheftaylor74 Samba Member
Joined: November 18, 2007 Posts: 45 Location: Encinitas, Ca
Posted: Sun Jul 10, 2016 6:41 pm Post subject: Re: Turn signal housing loose on a 1969 |
Quote: |
Welcome, the first thing you need to do is remove everything and straighten out the C shaped piece of steel that goes in the non switch side of the housing slightly, it's always bent too much, careful though, just a little squish in a vice or it won't go back into the housing. Now get yourself 3-4" of emory cloth and fold it in half lengthwise (gritty side out), wrap it around the column where the switch and the clamp you just straightened touches. You'll want to use locktite on the screws that hold the switch into the housing and give the switch a lube inside too, now put everything back together and gently tighten the screws holding the housing together, you may want to leave a tiny gap between the two and retighten it later if it starts to get loose. |
@busdaddy - when you do this on a 74 do you need to pull the steering wheel or can it be done leaving it on? |
Posted: Sun Jul 10, 2016 6:53 pm Post subject: Re: Turn signal housing loose on a 1969 |
Leave it on. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Sun Jul 10, 2016 6:59 pm Post subject: Re: Turn signal housing loose on a 1969 |
Tcash wrote: |
1974 is completely different than the early housing. |
Depends on the 74, early ones had signal and wiper switches like a 73, mid year they changed to the later column and housing. I assume since it's spinning it's the early one since the later one can't spin even if the bolt falls out. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Sun Jul 10, 2016 7:59 pm Post subject: Turn signal housing |
busdaddy wrote: |
Tcash wrote: |
Depends on the 74, early ones had signal and wiper switches like a 73, mid year they changed to the later column and housing. I assume since it's spinning it's the early one since the later one can't spin even if the bolt falls out. |
Thanks again for keeping me honest BD.
1968-72 style, two piece clamp is circled in red.
211 953 509 H VW Bus turn signal switch 73-74
From 2132 000 001 to 2142 164 059
211 953 513 K SWF T2 Turn Signal Switch 1974-79
Split housing with anti tamper bolt.
From chassis 2142 164 060
Tcash |
Posted: Sat Jul 16, 2016 7:26 pm Post subject: Re: Turn signal housing loose on a 1969 |
Thanks guys. Mine appears to be like the 73. Will tackle tomorrow. |
plywoodkid Samba Member
Joined: April 17, 2018 Posts: 217 Location: Ventura County, CA
Posted: Sat Apr 17, 2021 4:32 pm Post subject: Re: Turn signal housing loose on a 1969 |
Bus Daddy,
Should the C clamp sit on the left side of the wheel when the wheel is installed straight? |
Posted: Sat Apr 17, 2021 4:50 pm Post subject: Re: Turn signal housing |
It should be on the left regardless of where the steering wheel is.
Слава Україні! |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Mon Aug 29, 2022 1:14 pm Post subject: Re: Turn signal housing |
That screw is slipping on my '78 DC. I tighten it, but the whole turn signal housing keeps slipping down the steering column, and it does not have to go far before the turn signals no longer self-cancel. I'm thinking I need to replace the screw...
I am wondering if the screw I removed is original. It certainly is odd. It looks to be a self-tapping M8 with a sort of shoulder on it, and head that is hex head with a large slot through it. Is that what the original looked like, and should I replace it? Or is the problem somewhere else, like the interfacial surface between the "clamp" and the steering column? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Mon Aug 29, 2022 2:34 pm Post subject: Re: Turn signal housing |
jtauxe wrote: |
I am wondering if the screw I removed is original. It certainly is odd. It looks to be a self-tapping M8 with a sort of shoulder on it, and head that is hex head with a large slot through it. Is that what the original looked like, and should I replace it? Or is the problem somewhere else, like the interfacial surface between the "clamp" and the steering column? |
The OG screw has a cone shaped head with a hole in it, before it was installed at the factory it had more of a head with something for a wrench to grab, when torqued up that part broke off leaving the "anti theft" cone head on it. The common fix when they get loose is to saw a slot into it, but to enable serious torque replace it with a new hex drive bolt.
If it's still slipping you may have to add some shim stock between the layers of the clamp, if it's been loose alot it may have worn things down, a bit of beer can would likely be enough. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jtauxe Samba Member
Posted: Tue Aug 30, 2022 12:36 pm Post subject: Re: Turn signal housing loose on a 1969 |
That's right, now that you remind me -- it was a sheared off bolt originally. So the one that was in there, odd as it was, was not original.
I got a nice allen head M8 x 1.25 25 mm bolt that fit nicely. We'll see if it stops slipping now! _________________ John
http://vw.tauxe.net
