sepulvedac Samba Member
Joined: December 10, 2005 Posts: 145 Location: San Antonio, TX
Posted: Wed Mar 31, 2010 2:45 pm Post subject: before I keep breaking things up |
A little background.
Last Friday the cross shaft broke, it was replaced but not the T/O bearing. On Saturday afternoon coming from town the TO bearing gave up and it bent the new cross shaft on it's way out. I made the cross shaft worst by trying to push the clutch to see if I could engage third gear so I could get home at least. I was able to get home but the damage was done.
I installed a Bugpacl racing cross shaft withtheir bushing and everything is within tolerances as far as movement goes, also installed an engine (and here is where the problem begins now), everything is hooked up, except the fan belt. When I started to tight the alternator pulley nut I was expecting to see the crankshaft pulley rotate with the belt as usual, but the engine did not rotate. I tried to rotate the engine using an adjustable wrench on the crankshaft pulley and nothing moved. I checked the clutch cable for tension and to be on the safe side, it is completely loose. All this time transaxle was in neutral and e-brake disengaged. This engine was running before I took it out to installed yesterday on my Ghia. What do I need to check before taking it out again? I am going to hate it if it is the main shaft on the transaxle. Open for suggestions, start sending them. |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2147 Location: Salt Lake City
Posted: Wed Mar 31, 2010 3:43 pm Post subject: |
Was the pressure plate messed up when you took it out the second time? It seems like the busted TO shaft would do a lot of damage. Maybe your clutch is jamming everything. |
Posted: Wed Mar 31, 2010 4:27 pm Post subject: |
PP was checked twice.
Well, other things came up so forget about this, I am going to have to take the engine down anyways and start all over again...
thansk for looking into this. |
slingblade Samba Member
Joined: December 18, 2009 Posts: 107 Location: conyers ga.
Posted: Wed Mar 31, 2010 5:14 pm Post subject: |
once i ha one of the throwout clips come off and lodge between the ring gear and the bellhousing,,it was locked just like yours |
