iceneweb Samba Member
Joined: April 03, 2009 Posts: 145 Location: Vancouver (White Rock)
Posted: Sat Apr 03, 2010 12:34 pm Post subject: What 12v battery do I ask for to fit into my 1964 bus? |
My 1964 bus has a worn out, undersized 12v battery in it that i need to replace with something bigger and newer. What size do i ask for, or can i just ask for what would fit in say a '68 bay window?
(yes, i did a search and looked through the FAQ's) _________________ Thanks,
Mark
1959 Volkswagen Panel |
quartermilecamel Samba Member
Posted: Sat Apr 03, 2010 1:55 pm Post subject: |
when you say under sized, how is it undersized? most any battery will work if it will fit the battery compartment. You cant go wrong with too much cold cranking amps. Whats your battery rated at? Oh y eah I forgot, is it a 6 or 12 volt system? _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sat Apr 03, 2010 2:50 pm Post subject: |
bill may wrote: |
get a battery for a pt cruiser. |
Exactly what I wanted to know. Thanks, guys
And, the existing batt looks way undersized as it does not fill the battery 'tray' at all.
Btw: the motor is a 1200 somethingorother. Not had a chance to investigate further as it runs fine and I've been getting the rest of the van ready for the Out Of Province Inspection. _________________ Thanks,
Mark
suebug Samba Member
Joined: April 13, 2006 Posts: 1151 Location: The OC, SoCal, with my olympic cats
Posted: Sun Apr 04, 2010 12:17 pm Post subject: Re: What 12v battery do I ask for to fit into my 1964 bus? |
iceneweb wrote: |
(yes, i did a search and looked through the FAQ's) |
Here is my setup in my '66 Sundial that was converted to 12 volt.
This Interstate 12 volt battery utilizes the 6 volt battery-sized tray and strap and modified cover. Hope this helps!
_________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
'70 Bitchen 3-speed Schwinn |
Nitty Samba Member
Joined: July 07, 2003 Posts: 488 Location: Farthest South
Posted: Sun Apr 04, 2010 12:27 pm Post subject: |
If you're not using a cover, you'll need a slightly taller one. |
Posted: Mon Apr 05, 2010 8:30 am Post subject: |
Hi all, thanks for all the great info _________________ Thanks,
Mark
KamperKitJay BDM Hit Man
Joined: May 13, 2003 Posts: 404 Location: San Diego CA.
Posted: Mon Apr 05, 2010 5:41 pm Post subject: |
Try an optima red top |
Posted: Mon Apr 05, 2010 10:03 pm Post subject: |
KamperKitJay wrote: |
Thanks, but the info I am after is the size of battery not the type.
BTW: My bus did not come with a 6v battery cover or clamp.
Thanks again, all! _________________ Thanks,
Mark
big bus mike Samba Member
Posted: Mon Apr 05, 2010 10:16 pm Post subject: |
I run a "group 42" series battery. The brand is up to you. All battery places and most parts stores will know what this means. It's in reference to the dimensions of the battery. |
Posted: Mon Apr 05, 2010 10:19 pm Post subject: |
big bus mike wrote: |
That, is what I needed to know. Thanks Mike
As an update on the initial request. I changed my ground strap, put a new end on the positive lead, cleaned and resoldered some of the connections and wires on the regulator and charged up the battery. All appears to be well so far with the old battery, but it's over four years old, and so will need to be changed soon I am sure. _________________ Thanks,
Mark
