Can you use a 58-59 pedal cluster with a 57 Oval?
ricky.santillan
ricky.santillan is offline
PostPosted: Mon Apr 05, 2010 1:44 am    Post subject: Can you use a 58-59 pedal cluster with a 57 Oval? Reply with quote
We are confused here in the Philippines where we don't see to many Ovals and we have a pedal cluster that appears to have come off either a 58-59 which we were looking to replace a cluster on a 57 Oval but yet it didn't seem correct. We are encountering a problem wherein the Brake refuses to return when it is stepped on simultaneously with the clutch.
Schwing
Schwing is offline
PostPosted: Mon Apr 05, 2010 5:29 am    Post subject: Reply with quote
I think there is a difference with the gas pedal. 57 the last year for the roller pedal?
Bruce
Bruce is offline
PostPosted: Mon Apr 05, 2010 12:11 pm    Post subject: Reply with quote
The only way you can use the 58 and later pedal assembly in an oval is if the oval is on a 58 and later pan.
The position of the clutch tube in an oval is about 2" further to the right compared to the later pan.
ricky.santillan
PostPosted: Mon Apr 05, 2010 6:35 pm    Post subject: Reply with quote
Thanks. We just discovered that they are really different so will need to get a proper assembly.
PedalWerks
PedalWerks is offline
PostPosted: Mon Apr 12, 2010 7:49 pm    Post subject: Reply with quote
If you have anymore Questions and I can help let me know.
Scott
Nothing Exceeds Like Excess!!!
www.pedalwerks.com
@pedalwerksdotcom
909-289-9655
12' Golf 2.5
07' Rabbit 2.5
59' Single Cab
57' Oval hard top
55' Oval hardtop
