Holset Samba Member
Joined: April 21, 2008 Posts: 193 Location: Memphis, TN
Posted: Fri Jun 18, 2010 8:36 am Post subject: Fuel tank pressure build up |
I have a 1969 bus, that when I open the gas cap I get a rush of air. I have replaced the usual fuel lines, but just havent seen this before with my other bus(s). Ideas??? _________________ '72 Sunroof Deluxe "Hippie" the bus
'75 FI 1600 Std Bug "Bob" the bug (sold)
'69 Campmobile "Otter bus"
GySgt U.S.M.C. (Ret) |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Jun 18, 2010 8:43 am Post subject: |
Do you mean positive pressure or negative pressure? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Holset Samba Member
Posted: Fri Jun 18, 2010 9:05 am Post subject: pressure |
Positive pressure. As if the tank is not venting. _________________ '72 Sunroof Deluxe "Hippie" the bus
Posted: Fri Jun 18, 2010 9:13 am Post subject: |
So, just like the fuel tank for my outboard motor, your tank builds pressure because of being exposed to warm temperatures. I'd say your vent system isn't working. Didn't you say you worked on that? You must have got it wrong somehow. I'm not being much help here, I know. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Holset Samba Member
Posted: Fri Jun 18, 2010 9:41 am Post subject: pressure |
Ran all the lines, and did not encounter any blockages. _________________ '72 Sunroof Deluxe "Hippie" the bus
Posted: Fri Jun 18, 2010 10:25 am Post subject: |
This tank is out of a 1968 bus
you can see the vent towards the top front of the tank. If that's clear there is no way for the tank to build up pressure. If I remember right the line runs up to the filler door.
you can see it in this pic
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Posted: Mon Sep 03, 2018 2:58 pm Post subject: Re: Fuel tank pressure build up |
Anyone else getting this? Stock 1970 crew cab. I filled the tank and drove about 75 miles. The outside temperature was about 75 degrees F. I did not park it anywhere and it was overcast. When I got home I heard a strange noise and figured out that pressure (a lot) had built up in the tank. I replaced all the fuel, vent and charcoal canister hoses when I restored the bus. I believe the gas cap is original; I assume that the stock 1970 cap isn’t vented in any way, correct? _________________ 1970 Crew Cab |
70Crew Samba Member
Posted: Mon Sep 03, 2018 3:01 pm Post subject: Re: Fuel tank pressure build up |
As I think through this without access to the bus, does the tank vent through the charcoal canister? If so, I wonder if that could be plugged up? _________________ 1970 Crew Cab |
SGKent Samba Member
Posted: Mon Sep 03, 2018 4:48 pm Post subject: Re: Fuel tank pressure build up |
I think this is an early bay. Maybe a bug plugged the vent with mud. do you have a vented cap?
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
70Crew Samba Member
Posted: Mon Sep 03, 2018 4:52 pm Post subject: Re: Fuel tank pressure build up |
Definitely not a vented cap. _________________ 1970 Crew Cab |
busdaddy Samba Member
Posted: Mon Sep 03, 2018 5:01 pm Post subject: Re: Fuel tank pressure build up |
If you have a charcoal canister the tank vents though that (or should), try blowing into the little nipple on it as well as the hose that connects to it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Mon Sep 03, 2018 5:18 pm Post subject: Re: Fuel tank pressure build up |
70Crew wrote: |
As I think through this without access to the bus, does the tank vent through the charcoal canister? If so, I wonder if that could be plugged up? |
Yes, 1970 does not have a vented cap. You can blow through all of the lines in question to test.
a) remove 12mm hose from fan housing nipple and blow through it and the charcoal tank, you should feel air at the hose from the tank that goes into the air cleaner.
b) remove small hose from charcoal tank and blow firmly into tank. See if there is a difference with cap on vs off.
Colin
(NaranjaWesty has a restrictor in the fuel vapor line to charcoal tank, a little white plastic restrictor that I can imagine plugging up rather easily) _________________ www.itinerant-air-cooled.com |
70Crew Samba Member
Posted: Tue Sep 04, 2018 5:51 am Post subject: Re: Fuel tank pressure build up |
It may take a day or two but I am on it.... thanks gentlemen! I will report back with my findings. _________________ 1970 Crew Cab |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Tue Sep 04, 2018 6:06 am Post subject: Re: Fuel tank pressure build up |
Check to make sure none of those vent hoses are pinched or kinked too. I'd think that would be a likely culprit. My 1970 does not do this. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
