syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
targis58 Samba Member
Joined: July 11, 2006 Posts: 539 Location: sunnyvale,ca
Posted: Wed Apr 07, 2010 10:14 pm Post subject: |
ah! thanks.
and the switch from kirkmeeks.com is "not in stock" _________________ 90 westy 2wd w/ TBD |
Posted: Wed Apr 07, 2010 10:23 pm Post subject: |
Quote: |
"not in stock" |
Oops, didn't notice that |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Wed Apr 07, 2010 11:10 pm Post subject: |
Hey Targis58:
If you are only installing one diff lock (really all you can do with a 2WD), then consider raiding the local pick-a-part. The Audi Quattro cars from '86 to '91 all had locking centre and rear diffs which used what looks to me to be the same vacuum actuator (albeit a different mounting frame) and they used a rotary-dial vacuum switch/valve with a nice console which also had an indicator light to tell you if the lock is engaged or not. The console is on the dash in these cars.
From '92 on, the centre diff was Torsen and only the rear diff was manually lockable. On these cars, there was a push-button toggle-on toggle-off electric switch that controlled an electric vacuum valve that you can put very close to your diff lock actuator (shorter vacuum lines!). In these Audis, the push button is next to the shifter and the electric vacuum valve is under the back seat. The switch has a light in it to tell you when the locker is engaged.
One other option, really a "ghetto" approach, is to use a vacuum valve from any car using vacuum controls for the A/C system and use a separate LED light for monitoring locker engagement. |
Orbitald Samba Member
Joined: August 12, 2004 Posts: 320 Location: Oakland, CA
Posted: Wed Apr 07, 2010 11:19 pm Post subject: |
Quote: |
The Audi Quattro cars from '86 to '91 all had locking centre and rear diffs which used what looks to me to be the same vacuum actuator (albeit a different mounting frame) and they used a rotary-dial vacuum switch/valve with a nice console which also had an indicator light to tell you if the lock is engaged or not. The console is on the dash in these cars |
Is this it?
[/quote] _________________ '87 Syncro Westfakia, 1.9TD ADE (AAZish), 068 Injection Pump, K03 turbo, 2.5" exhaust, Mercedes nozzles, SAAB Blackstone charge-cooler w/ 800cfm fan, Micro-1000 EGT sensor pre-turbo, boost at about 13psi, 235/70/16 with stock gearing |
tencentlife Samba Member
Posted: Thu Apr 08, 2010 9:15 am Post subject: |
Quote: |
On these cars, there was a push-button toggle-on toggle-off electric switch that controlled an electric vacuum valve that you can put very close to your diff lock actuator (shorter vacuum lines!). |
Yeah that's exactly what I'm all about. IF I use vacuum as a power source I'd still like to control it remotely by electrics and keep all the vac stuff short. I'm envisioning a switch setup that mounts right on the gearshift stalk, so I can work the difflock with my hand on the shifter. Then maybe double up this switch if and when I add a decoupler.
Indicator lights are a whole seprate system independent of how you do the actual locking, you can wire lights to the position switches on the diff, decoupler, or front diff, they're all there, and put your lights wherever you would like them.
Quote: |
10cent has no engine? The cobbler's barefoot! The butcher's a vegetarian!... |
Well I can always throw something tegether, but I'm thinking this is my opportunity to build the prototype 2.4, so as far as that goes I don't have an engine. Yet.
My favorite variant on the old cobbler's children thing was a friend of mine, a psychiatrist, adding "and the shrink has the meanest kid on the block". _________________ Shop for unique Vanagon accessories at the Vanistan shop:
onwardtothestars Samba Member
Joined: April 04, 2007 Posts: 225 Location: Hazenville Pass Wyoming
Posted: Thu Apr 08, 2010 9:54 am Post subject: |
Orbitald wrote: |
Is this it?
[i |
[/quote]
Actually I think we'd be saying it's Quattro's from '82.
Pre-'85 Audis (also all years UrQuattro) had a pull knob kinda like a the vanagon syncro's but it was two step, first step was to lock the center diff and the second step to lock the rear diff. The Quantam Syncro's also used a knob similar to the early Audis, with the two step lock.
Orbitald - that first picture looks like the interior of a Sport Quattro. _________________ lots of VW's |
Posted: Thu Apr 08, 2010 10:41 am Post subject: |
targis58 wrote: |
So.. what s missing from van-cafe's switch is just the plastic handle?
Can hose be purchased from a hardware store? one of those clear air hose? What are those three legs for? |
Is there anything to go wrong with the switch unit itself due to the age?
If yes, is it easily repairable? _________________ 90 westy 2wd w/ TBD |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Posted: Thu Apr 08, 2010 11:08 am Post subject: |
targis58 wrote: |
Ok, did search but...
Can someone post a photo where locker panel is mounted on dash? I would like to see how it looks. thanks |
Just snapped that with my phone, not the best quality.
FWIW, the black plastic knob part of the switch is the same as the knobs used on late 60's -70's bugs and buses for the headlight switch, among other things....
in fact, if you can keep a secret, the left position knob on mine in the above pic is the entire headlight switch of a '70's bus. its wired to a little circuit that flashes the light for a few seconds and then turns it on solid...poor mans front locker
I only did that because the previous owner cut an unsightly hole there to install an aftermarket gauge that just flopped out of the little hole.
In real life they look exactly the same, but the picture they look different because of the angle. _________________ 1987 Syncro Westfalia powered by Subaru
'65 Westfalia |
