shift rod (bushing) ...What the Hell!
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Mon Aug 17, 2009 3:34 pm    Post subject: shift rod (bushing) ...What the Hell! Reply with quote
do i have to take the damn shift rod Out to put the bushing on
I must be stooopid or ???
i cant get the damn thing on
"special trick"??
Im hands deep in grease
74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote:
Extremity is relative to how far your willing to jump
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS4 "NKOGNEATO"
BSQUARE
BSQUARE is offline
PostPosted: Mon Aug 17, 2009 4:09 pm    Post subject: Reply with quote
You have to slide the shift rod most of the way out of the tunnel.
Remove the disc in the front apron and the front tunnel plate on the pan.
Disconnect the shift rod coupler and shifter plate.
Slide the rod forward until the end is in the shifter hole in the cockpit.
Replace the bushing on the shifter plate (don't forget the wire clip), slide the rod back and reassemble.
Yes.
It's almost the same as a Bug:
http://www.thesamba.com/vw/forum/viewtopic.php?t=157519
sharkskinman
Lateral Lunatic
PostPosted: Mon Aug 17, 2009 4:20 pm    Post subject: Reply with quote
Thank you
ill tackle that tomorrow then
when i have more time
..........Just got back in from doing it Half in the dark
BUT
i slid it out
put the ring on and in the mount
and pushed from the front
Used the handle of a 26oz hammer(long)
to push it in the rest of the way
Now theres No Slop in the shifter
Awesome! Very Happy
PS4 "NKOGNEATO"
yellow73
yellow73 is offline
PostPosted: Wed Apr 28, 2010 3:24 pm    Post subject: Reply with quote
Is it the same bushing as a Type 1?
Russ Wolfe
Russ Wolfe is offline
PostPosted: Wed Apr 28, 2010 5:03 pm    Post subject: Reply with quote
Yes Sir.
Gary: OK. Ima poop.
yellow73
yellow73 is offline
PostPosted: Thu Apr 29, 2010 8:14 am    Post subject: Reply with quote
Thank you very much.
DASLWST
DASLWST is offline
PostPosted: Fri Apr 30, 2010 3:48 pm    Post subject: Reply with quote
i really need to replace mine!!! it shifts like crap Sad
#daslwst
yellow73
yellow73 is offline
PostPosted: Sun May 02, 2010 1:32 pm    Post subject: Reply with quote
I thought I would share with you what I found when I replaced mine this weekend: -
Apparently one of the previous owner or their mechanics thought that there was a different way to quiet the rattling coming from the shifter....
I dug out over half a tub full of grease and a shop rag from the tunnel that I can only guess was put there in hopes of stopping the noise - it did not by the way!!!!
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Sun May 02, 2010 4:38 pm    Post subject: Reply with quote
I wonder how long that poor SOAB sat there with a grease gun pumping the tunnel full of grease Laughing Laughing
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
