Desertbusman Samba Member
Posted: Thu Apr 15, 2010 6:34 pm Post subject: |
Raul, Just heard from Gary and he said he had talked with you and it looks like you've got truck buds with you that can get you home with a dolly. That's cool
So when you're busted down do you kick back with your entertainment center, microwave meals and enjoy the hot tub?
What's that quote in your sig line? _________________ 71 Superbug
71 Westy |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Thu Apr 15, 2010 6:45 pm Post subject: |
I was getting ready to move two vw's and a type 1 engine I'm re-sealing in order to get his bus in here. looks like he's got it handled. I would have been happy to help. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Randy in Maine Samba Member
Posted: Thu Apr 15, 2010 7:12 pm Post subject: |
Makes a broken clutch cable look like not a big thing. |
Posted: Thu Apr 15, 2010 8:25 pm Post subject: |
Desertbusman wrote: |
What's that quote in your sig line? |
I had chuckled at that myself. |
vw76westy Samba Member
Posted: Fri Apr 16, 2010 11:41 am Post subject: |
it means that i have put 16k miles on the eng in the last year
& during those 16k
the bus is either going 70-85 mph
or hualing a heavy load with a trailer at 60mph
without a problem
last year the load i was hualling was so heavy the tranny gave out before
the type-4 engine
with the fuel injection & hydrollic lifters its practically
maintance free compared to ......
after taking a closer look at the engine today
it looks like the cork gasket on oil breather got blown out
hopefully that is what spread the oil all over the eng compartment
& causing the white smoke _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor, |
nathansnathan Samba Member
Posted: Fri Apr 16, 2010 12:05 pm Post subject: |
I'm kinda vague on what's going on, but ...
oil from the breather tower would have a hard time getting on the really hot stuff below the tin to make smoke.
Usually the only thing that makes a considerable amount of smoke, oil leak related is improperly put on head covers leaking onto the heater boxes.
More likely you've burned a valve. Someone said that if you (first adjust the valves right) drive it for 100 miles or so, it can re-seat itself. -just a guess though about that |
Posted: Fri Apr 16, 2010 12:33 pm Post subject: |
If the seal blew out it might have because of higher than normal breather pressure. Not sure what could cause that except internal engine wear/damage like a bad ring maybe... _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Apr 16, 2010 12:40 pm Post subject: |
here is the thread on oil troubles
http://www.thesamba.com/vw/forum/viewtopic.php?t=409556&highlight=
Desertbusman
as a matter of fact i do
only im close enough to just go to the beach insted of the hottub
(ill worry about getting home later...)
& out here in sd if i have to...
ill walk 10 miles to get to phill's bbQ (by the sports arena) _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
Posted: Fri Apr 16, 2010 12:49 pm Post subject: |
"out here in sd if i have to...
ill walk 10 miles to get to phill's bbQ (by the sports arena)"
shishhh, the lines already out the door. We don't need everyone to know about Phil's. Hahahaha
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Apr 16, 2010 7:00 pm Post subject: |
haha
i dont wait in that 1-2 hour line that wraps around the resturant
we go strait to the bar & order from there
and im sure youll agree
that the onion rings are even better than the bbq
Posted: Fri Apr 16, 2010 9:01 pm Post subject: |
You figured that out too _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
