VisPacem Samba Member
Joined: July 15, 2007 Posts: 1143 Location: Las Vegas
Posted: Fri Apr 09, 2010 11:09 pm Post subject: Fuel pump? or ? |
A few months ago I had difficulties starting the van in the morning. I am not certain I did or did not hear the pump spin.
Anyway, three days ago, I am moseying along on the expressway at or about 55 PMH, slow down for the coming red light, engine dies. Just like out of fuel and I have a full tank. Will not re-start, therefore AAA.
OK. Next day very hard start. Had to turn key on /off could hear the pump spinning, 3, 4 5 times before the engine started.
To be exact, key to ignition on 4 times in a row w/o trying to start, then go for it and try to start.
After 4 or 5 repeats of this comedy the engine finally started. It has started ever since though I do not dare take the van anywhere until I know what the problem is.
Ignition switch is new, 6 months old
Battery is new 2 months old Optima
Fuel filter replaced less than three months ago
Fuel lines REPLACED
so.....
Pump dying ?
Pump relay agonizing?
or ...
thanks _________________ LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons) |
Posted: Sat Apr 10, 2010 7:25 am Post subject: |
If the pump is running it should be pumping fuel. Get yourself a pressure gauge and put it on the test port on the fuel rail and see what it reads. While its running I would shake all the wiring harnesses around and pull on all the plugs and see if doing so caused it to stall.
Have you checked your codes? |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10370 Location: Sunshine Coast B.C.
Posted: Sat Apr 10, 2010 8:46 am Post subject: |
With a Suby swap is there a procedure similar/same as WBX for bypassing (testing purposes only) the FP relay? If so.....
If it were me, I'd be prepared to bypass FP relay if a no start happened in the drive way. I'd stop trying, insert the jumper wire, listen if pump spinning, then try starting it. If need be, I'd also try a spare known good ignition switch.
1988 West DIY 50º ABA
VE7TBN |
Posted: Sat Apr 10, 2010 10:23 am Post subject: |
Thanks guys
I am working on it _________________ LG aka VisPacemPB, *The* party Pooper
Posted: Tue Apr 20, 2010 7:10 pm Post subject: Fuel pump 2. Go to end of post to skip poetry. |
Ok now.......
Nobody laugh .....
So then, as the fuel pump pumps I decided to change the relay as being the cheapest link in the chain and see from there.
So after a trip to NAPA, here I come back optimistically getting a Spatenbrau out of the fridge KNOWING that it will never have a chance to get warm before I was done with this basic, elementary childlike replacement.
Ah! Ah ! Ah!
Despite searching the Bentley, searching the whole engine compartment, under the seats I COULD NOT FIND THE DEVILISH LITTLE DEVICE
Naively I had assumed that said relay was located inside the approx. 6x4 inches black box on the port side of the firewall.
I did not look in the port side where the A/C wiring and relays are located, under that vertical cover.
No ! nope! Not in there
Not anywhere else that I could tell.
So as I could have said in a few words
Where in the HAIL (sic) is the fuel pump relay
My Spaten got warm
Thanks _________________ LG aka VisPacemPB, *The* party Pooper
914 mike Samba Member
Posted: Tue Apr 20, 2010 8:21 pm Post subject: |
Go back and look in that little black box on left side of motor compartment...the one that says "DANGER - HIGH VOLTAGE"
Its in there on 99.9% of vans....
Its the one on the right. _________________ Mike
84 Westy
2.2 Suby
In a world full of ponies it's a thoroughbred horse....
Can ≠ Should |
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Tue Apr 20, 2010 10:10 pm Post subject: |
On my Suby conversion, I believe the FP relay is next to the ECU. You may want to email Tom Shiels - tom @ tomshiels . com He may be able to help on locating it. Or post on the SubaruVanagon Yahoo Forum. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
Posted: Wed Apr 21, 2010 7:33 am Post subject: |
Ahhh....I see. You have a suby. Mine is located next to my ECU which I have mounted in an ammo box in my drivers side rear wheel well.
Most mount it under the bench seat in the 86+ factory location.
Find your ECU and I bet you find your relay.....
Good luck. _________________ Mike
84 Westy
2.2 Suby
Can ≠ Should |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Wed Apr 21, 2010 7:58 am Post subject: Re: Fuel pump 2. Go to end of post to skip poetry. |
VisPacem wrote: |
Ok now.......
Who did your conversion?
Sounds like a phone call is in order. _________________ -- 1987 Westfalia automatic (Captain Vino) |
Posted: Sat May 01, 2010 12:17 pm Post subject: Re: Fuel pump 2. Go to end of post to skip poetry. |
Perales wrote: |
VisPacem wrote: |
Ok now.......
Sounds like a phone call is in order. |
Unfortunately, I do not know who did the conversion. I did again search and enrolled a professional to also search (visually)
I took pictures of the engine compartment with the intention to post them here, however I get a message picture too large (though I reduced them 50%) or file corrupted. To not add further complication I just gave up posting and those which anyway show NOTHING, by this this I mean no FP relay.
Not on the firewall anywhere, not under the pillars not on the sides, not on the back between or around the tail lights. Not in the black box on the port side of the firewall.
Therefore, I have to bend the knee and seek assistance of my lieges and other wizards of the domain.
Could a charitable soul post a picture of this elusive (to me) fuel pump relay **in situ**
thank you very much _________________ LG aka VisPacemPB, *The* party Pooper
Dogpilot Samba Member
Posted: Sat May 01, 2010 1:07 pm Post subject: |
Well this is not really going to be helpful, but since your working with a custom install, your stuffed unless the original converter rocks up (this is applicable to all conversions, unless they followed a published guide to the 'T'). Your going to have to play follow the wire from your fuel pump to where it may lead. However, my vote is it is located in your arm rest. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
