RONIN10 Samba Member
Joined: April 30, 2007 Posts: 594 Location: Seattle, WA
Posted: Tue Apr 13, 2010 11:32 am Post subject: Torque on Trailing Arm Pivot Bolts |
I've looked all over the forums, Bentley, and Idiot guide and can't seem to find a reference value for the torque on the pivot bolts for the trailing arms. You know, the bolts which pass through the small end of trailing arm with the bonded rubber bushing and large spacers. This is for a 1969 IRS Beetle.
Any tribal knowledge out there?
Thanks in advance. _________________ Andrew
Oscar: 1976 Westfalia Deluxe Camper, 2.0L FI, Manual Transaxle |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Tue Apr 13, 2010 11:43 am Post subject: |
late bentley sez: "tighten the bolt to 120Nm (87 ft. lbs). lock the bolt by peening it to the shoulder of the bracket. note- to prevent tension in the bonded rubber mounting, tighten the fitted bolt with the diagonal arm extended." _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Tue Apr 13, 2010 12:19 pm Post subject: |
it's not listed in the 66-69 bentley, it is listed in the 70-79 bentley. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Detroit73super Samba Member
Joined: October 03, 2009 Posts: 611 Location: Detroit
Posted: Tue Apr 13, 2010 3:11 pm Post subject: |
hazetguy wrote: |
late bentley sez: "tighten the bolt to 120Nm (87 ft. lbs). lock the bolt by peening it to the shoulder of the bracket. note- to prevent tension in the bonded rubber mounting, tighten the fitted bolt with the diagonal arm extended." |
Good info. I just came upon the same situation. Torque wrench doesn't fit in this area w/ the adapter for the diagonal arm bolt ????. I just tightened it "very well" . Please elaborate on locking the bolt in place... Thanks _________________ Choptop 73 Super Build Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=395375 |
