66 speedo in 67 beetle, different fuel gauges, will it work?
airkooledchris
Location: Where the pacific ocean meets the redwood forest
airkooledchris is offline
PostPosted: Fri Apr 16, 2010 7:22 am    Post subject: 66 speedo in 67 beetle, different fuel gauges, will it work? Reply with quote
id like to pick up a speedo from a 66 beetle, where it has the fuel gauge built into the speedo itself.
my 67 does not have this, it has the gauge on that pod to the right of the speedo currently, but id like to put other gauges there instead and since my original speedo is shot...
can I swap in one from a 66 and connect my existing sender to it's fuel gauge and have it work?
thanks!
metahacker wrote:
... i would say that, if it's an option, (edited) not listen to any forum pessimism..
ssmalibu2
ssmalibu2 is offline
PostPosted: Fri Apr 16, 2010 7:26 am    Post subject: Reply with quote
You will need a 68 and up speedo and you will also need to change the sender.
Jeckler
Jeckler is offline
PostPosted: Fri Apr 16, 2010 9:42 am    Post subject: Reply with quote
And if you get the '68-only speedo with the integrated gauge, the face is the same style as the earlier models. The font, color and style changed in '69.
Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote:
I am the crabby old guy.
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad.
gt1953
gt1953 is offline
PostPosted: Fri Apr 16, 2010 1:05 pm    Post subject: Reply with quote
Heck even get a newer one you will have the tenths digit on it.
72 type 1
73 type 1
72 Squareback
({59 Euro bug, 62, 63, 67, 68, 69 type ones 68 & 69 type two, 68 Ghia all sold})
airkooledchris
PostPosted: Mon Apr 19, 2010 2:23 pm    Post subject: Reply with quote
thanks for the replies. I like the idea of it matching the original style, just with the integrated fuel gauge in it.
it just has a 'softer' look than the 69+ style, even though those have the tenth's.
Gipeto
Gipeto is offline
PostPosted: Sun Jan 01, 2017 8:23 am    Post subject: Re: 66 speedo in 67 beetle, different fuel gauges, will it work? Reply with quote
Hi,
I've a similar dilemma. My 67 has the mechanical sender and gauge which don't work to well (1/4 tank means you've already run out!). I'd like to add oil temp/pressure gauges and bolt gauge as well as a new electric gauge for fuel level. All matching. Oh, and a tach as well. I'm wondering if I can use an electric sender from a newer bug for this purpose. Will a newer one fit the 67 tank? And is it compatible with the gauges available to me. Obviously I'm not using a vw product. Anyone done this before??
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Sun Jan 01, 2017 9:17 am    Post subject: Re: 66 speedo in 67 beetle, different fuel gauges, will it work? Reply with quote
Gipeto wrote:
I'm wondering if I can use an electric sender from a newer bug for this purpose. Will a newer one fit the 67 tank? And is it compatible with the gauges =
Yes.. 68-77 BEETLE (not Super) electric fuel sending units fit right in the 1967 and older tanks.
Compatibility of a fuel sender to a particular gauge .. all depends on the resistance of the sender vs the gauge resistance range.
Your simplest solution is to use a stock 68 up gauge with the integral fuel gauge. Since you are removing the stock fuel gauge and adding more.. making it match a 67 year look... probably isnt an issue.
Many speedo design change looks from 68 up.. and they all fit the older Beetles.
A STOCK fuel sending unit resistance is about
10 ohms FULL
75 ohms EMPTY..
The gauge and unit must match to be fairly accurate
http://www.thesamba.com/vw/forum/viewtopic.php?t=364560
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Gipeto
Gipeto is offline
PostPosted: Mon Jan 02, 2017 9:08 am    Post subject: Re: 66 speedo in 67 beetle, different fuel gauges, will it work? Reply with quote
Thanks, that helps. I had hoped to not replace the spedo but that would be the easy route. I have both new dash panels. The right having 2 holes, both 2 1/8" I think. The left has 2 small and 1 large (for the tach). 3 holes were for oil temp, oil pres., and volt meter. The other was hoping to mount a matching fuel gauge. Not really a big deal though to just buy one new dash panel for single gauge, and Finding a good spedo should be easy. The 68 also uses the vibrator unit as well, correct?
KTPhil
KTPhil is offline
PostPosted: Mon Jan 02, 2017 11:40 am    Post subject: Re: 66 speedo in 67 beetle, different fuel gauges, will it work? Reply with quote
Here is a vintage look option for a small round fuel gauge if you want to keep your current speedo. I'm not sure which sender it used; you can ask ISPwest.
http://www.vwispwest.com/113018031BG.html?p=
Gipeto
Gipeto is offline
PostPosted: Tue Jan 03, 2017 6:32 am    Post subject: Re: 66 speedo in 67 beetle, different fuel gauges, will it work? Reply with quote
Thanks, this is exactly the look I'm after and they accually sell the entire tree and lt clusters as a package. I will check the details on compatibility with the senders but this looks like what I want
