VWhead Samba Member
Joined: September 27, 2009 Posts: 337 Location: Pacific Grove,CA
Posted: Sun Apr 18, 2010 12:22 am Post subject: Tachometer signal converter? |
Need help or advise on installing a tach signal converter on a Vanagon with a MK4 harness and motor.The problem is the Vanagon is analog and the MK4 is digital. _________________ 81' Single Cab Syncro 1.8T GMW
88' 2wd Westy 1.8T GMW
www.gmwerks.com
Beetsport Samba Member
Joined: January 08, 2005 Posts: 475 Location: Sacramento, CA
jpwerks Samba Member
Joined: July 16, 2009 Posts: 56 Location: Pacific Grove,Ca
Posted: Wed Apr 21, 2010 12:13 pm Post subject: |
Cool,thanks Stephan for the tip.I ordered the adapter today from Summit.Looks like I'm probably going to mount it in the treasure chest along side the ECU and fuse panel.From what I researched it looks like you can get the tach signal from the T-10 black connector-pin#9(white wire)?Is this correct?
Really working hard on this swap to get it ready for SdM.That would be great if you could bring the mustache bar with you.I guess you know we made our own custom engine bars.I think Ed sent you some pics of them.
Thanks for your help.
Paul _________________ 81' single cab 1.8T Syncro (converted)
85 Vanagon 1.8T
55 chevy
2008 330i BMW
2000 jetta 1.8T
2004 Golf 2.0 |
Posted: Wed Apr 21, 2010 12:52 pm Post subject: |
Sure thing Paul. Glad I could help.
I was going to mention bringing it up too. And yes, I did see the pictures. Nice job!..
Let me know if your going to make it or I will just mail the bar back to you.
Thanks ! _________________ '90 Syncro Westy 1.8T with 180hp 174 torque, CA safe!
http://H2oVanagon.com
http://www.thesamba.com/vw/forum/viewtopic.php?t=217285 |
VWhead Samba Member
Posted: Wed Apr 21, 2010 1:16 pm Post subject: |
Yep I'm for sure going to SdM. Look forward to meeting you.
Thanks
Paul _________________ 81' Single Cab Syncro 1.8T GMW
www.gmwerks.com
