Tunnel trans into early bus: center mount option?
Page: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
happyhippo
Segapone Wanna-B
happyhippo is offline
PostPosted: Mon Apr 19, 2010 10:05 am    Post subject: Tunnel trans into early bus: center mount option? Reply with quote
Hey folks,
I've been searching the age-old topic of putting a newer style big-nut tunnel transmission (64-67) into an older bus (1957). The classic question is which method of adaptation to use on the front mount.
You can go solid mount--no hacking of bus, but all transmission vibration and noise is transferred directly to the bus and makes it VERY noisy.
You can HACK your bus's transmission mount so you can use a newer mount with rubber in it. Makes for a much quieter ride, but the hack is nasty to make and nastier to reverse.
I REALLY want a quiet ride on this bus with a later transmission, but I HATE the idea of hacking the tranny mount.
One of the previous responses to this type of question was "use a center Berg style mount", runs quiet, no hack needed. There was no follow-up to this response and no pictures.
Can someone elaborate on this "best of both worlds" solution?
Thanks!
-- Jeff--happyhippo
Look, I'll do whatever you want...Just get that death-weiner away from me! -- Principal Skinner
Never let a stripper clog dance near your dangle. -- Bob Oblong
hugheseum
hugheseum is offline
PostPosted: Mon Apr 19, 2010 11:00 am    Post subject: Reply with quote
contact nate at wagenswest,i gave him a original early housing and he was supposed to make a urathane mount which would mean no hacks and no vibration.......
worthy of noting is my 56 sc solid mount,had it for many yrs and honestly i dont have insane noise and ive never had a problem with it
Have a great day!
joescoolcustoms
joescoolcustoms is offline
PostPosted: Mon Apr 19, 2010 11:08 am    Post subject: Reply with quote
My '59 SC had the solid mount conversion and it was noisy. Kept coming loose because the front was solid and the rear was mounted in rubber which allowed the trans to move slightly like stock and wallored (hillbilly slang) out the mounting holes into the nose cone.
I performed the hack and soooooo much better mounted in stock front rubber.
UnKlear Racing TAT 2020
Bad News Racing 2018 NORRA 1000 3rd in class, 120/270 overall
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
oldeskooloval
oldeskooloval is offline
PostPosted: Mon Apr 19, 2010 8:35 pm    Post subject: Reply with quote
Timely topic……..looking to do the same for my early bus and would like to see options. Samba Nation…………..thoughts……….????
so fresh and so clean
richardab1967
richardab1967 is offline
PostPosted: Tue Apr 20, 2010 5:40 am    Post subject: Re: Tunnel trans into early bus: center mount option? Reply with quote
happyhippo wrote:
Hey folks,
Thanks!
Hi, yes I did this to my 57, I used a UK supplied centre mount and no front mount at all.
http://www.ssvc.org.uk/phpbb/viewtopic.php?f=4&t=34164&hilit=intermediate&start=150
It required welding two small plates onto the underside of the frame horns. It hangs down about the same amount as the big U frame crossmember.
It runs smooth (I can't understand the logic in having soft rear mounts and solid front...something is gonna break!), but I only run a stockish 1500 so no great stress on the mount.
Sorry no pics.
Regards
Richard
happyhippo
Segapone Wanna-B
PostPosted: Tue Apr 20, 2010 8:49 am    Post subject: Re: Tunnel trans into early bus: center mount option? Reply with quote
richardab1967 wrote:
happyhippo wrote:
Hey folks,
Thanks!
Sorry no pics.
Regards
Richard
Thanks for the pointer, Richard! At least now I know what I'm looking for. Anyone have pics of this setup?
-- Jeff--happyhippo
cdennisg
cdennisg is offline
PostPosted: Tue Apr 20, 2010 9:09 am    Post subject: Reply with quote
That mount looks great. Does anyone have pics of it installed? I may just copy it from the pics in that thread.
Stupidity should be a two minute penalty.
- The Hockey Guy
richardab1967
PostPosted: Tue Apr 20, 2010 9:16 am    Post subject: Reply with quote
I'll have a look at my photo collection later and see if it crops up in any underside shots.
You could contact the seller (Butty) on the ssvc thread, I think he still sells them, it wasn't that expensive and I'm sure he'd ship to the states.....if the planes ever start flying again!
Regards
Richard
richardab1967
PostPosted: Tue Apr 20, 2010 11:53 am    Post subject: Reply with quote
Found one pic, bit fuzzy, hope it helps
Lind
Lind is offline
PostPosted: Tue Apr 20, 2010 12:02 pm    Post subject: Reply with quote
someone should start manufacturing these. I PM'd the poster of the photo, but he never responded. looks like a good idea. all the modifications are done to the tunnel nose cone, and the bus gets out unscathed. it uses the stock split case mounting setup.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=498388
and then you just go there
happyhippo
Segapone Wanna-B
PostPosted: Tue Apr 20, 2010 12:40 pm    Post subject: Reply with quote
Lind,
I think I'm missing something re: your post. The nose cone you pictured is an early nosecone. The nose cone on a tunnel tranny looks completely different. I need to get this tranny mounted up with the newer nose cone and the older forward transmission mount without hacking the bus in any way...I'll hack a nose cone to bits, however, if it will help solve this problem.
-- Jeff--happyhippo
EmpiGT
EmpiGT is offline
PostPosted: Tue Apr 20, 2010 12:52 pm    Post subject: Reply with quote
Look at Linds post again, That is a tunnel nose cone modified with a slip on adapter to fit in the split case frame mount.
happyhippo
Segapone Wanna-B
PostPosted: Tue Apr 20, 2010 1:30 pm    Post subject: Reply with quote
Thanks for the clarification. I get it now! Smile
-- Jeff--happyhippo
EmpiGT
EmpiGT is offline
PostPosted: Tue Apr 20, 2010 1:35 pm    Post subject: Reply with quote
I wonder how it worked out? With all that ginding on the nose cone to fit that adapter piece looks like it would make the nose cone weak. with all the torque on the nose it seems like it could break pretty easily?
richardab1967
PostPosted: Tue Apr 20, 2010 2:03 pm    Post subject: Reply with quote
Actually I had to do the same filing of the top rib of the nosecone in my centre mount version, it was to clear the chassis mount. I concluded because the gearbox was not supported by the nosecone in my solution, weakening it would not be detrimental. Not sure how it would fare when load was put though it.
Regards
Richard
crusty67t2
Trailer Park King
crusty67t2 is offline
PostPosted: Tue Apr 20, 2010 2:15 pm    Post subject: Reply with quote
old speed sells a mid mount set up that welds to the cross member, It eliminates the front mount. The one that I seen installed looks to be easily reversible/removable. May not be exactly what some people are looking for? It worked very well In the bus I seen it in.
62 original paint Turkis double cab
59' rag top
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Tue Apr 20, 2010 3:10 pm    Post subject: Reply with quote
Find a 60 only beetle front trans mount and weld a couple studs on for it
I do my own front mount hacks, but are reversable with a little cutting and grinding
"no more hacking my sig line"
oldeskooloval
PostPosted: Tue Apr 20, 2010 8:25 pm    Post subject: Reply with quote
Lind,
Spoke to that guy,,,It worked good but, it did not sound like he wanted to make anymore……I will ask him again, would be a good ‘side business’ for him if nothing else and keep the samba nation updated.
GDOG57
GDOG57 is offline
PostPosted: Tue Apr 20, 2010 10:50 pm    Post subject: Reply with quote
Do you have to cut the circle area on the bus at all? Can you provide some pics of this setup?
'57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red)
cdennisg
cdennisg is offline
PostPosted: Wed Apr 21, 2010 11:39 am    Post subject: Reply with quote
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4785
Could something like this be used? Just the front strap would be necessary.
- The Hockey Guy
Page 1 of 10
