EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Mon Jul 12, 2010 5:07 pm Post subject: |
Not sure if this applies here but from what I have seen, studs were used in locations where you would not want to be removing and installing a bolt, possibly multiple times, as it would fatigue the metal used.
Install a stud once and put the pressure on just pulling on the stud rather than both turning and applying torque at the same time. _________________ How to Post Photos
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Mon Jul 12, 2010 6:23 pm Post subject: |
Sounds reasonable to me. Thanks Everett.
Anybody know the torque value of the RGB to springplate bolts of the top of their head? I have things bolted in loosely right now, and I will be doing the brakes and rear axle seals in a few minutes. Then I will methodically go around and tighten and inspect things to make sure all is well. I installed a valve cover vent system today, too, mounted to the top of the trans with some home made brackets. I need to find the thread that shows the modification to the early parking brake cables to fit the later brakes. _________________ nothing |
Posted: Mon Jul 12, 2010 11:08 pm Post subject: |
Thanks again Everett.
Trans is in. Bolts are tight, everything is adjusted. Brakes and cables will be dealt with tomorrow, then it's engine install time. I'll report back with any findings, discoveries, crashes, or maiming. _________________ nothing |
Sancho Samba Member
Joined: March 02, 2004 Posts: 190 Location: Belgium, Mechelen
Posted: Tue Jul 13, 2010 1:46 am Post subject: |
EverettB wrote: |
Install a stud once and put the pressure on just pulling on the stud rather than both turning and applying torque at the same time. |
Correct,
when installing the stud you put no stress on the aluminium/magnesium case.
when then installing a nut the case itself gets only pulling force.
With a bolt you pull and turn on the case, which will destroy the tread.
(unless you use a helicoil offcourse)
(I think in Englisch that is called shear pressure) |
Posted: Tue Jul 13, 2010 9:06 am Post subject: |
I got the mount installed yesterday, and I swapped out the studs for four longer ones. Thanks for all the help on that one folks. _________________ nothing |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2537 Location: Ocean Beach in Beautiful BLUE California
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Tue Nov 16, 2010 8:12 am Post subject: |
krusher wrote: |
happyhippo wrote: |
cdennisg wrote: |
Not sure what that mount costs from GB, but I may try to fab one and not worry about the front mount on my future project. Worth a try anyway. |
This pic looks like there is still a front mount with this whole setup. Is that still necessary? Also, this is a tunnel tranny into a tunnel tranny bus. Will this setup work for a tunnel tranny into an early split-tranny bus? |
Is this gold one Berg, those welds are awful |
it is a modified Gene Berg mount. the 2 verticle sides were cut at 90 degrees to pipe and was rewelded which do not match berg welds. i believe the guy lives here in san diego,ca-usa _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Thu Aug 11, 2011 1:08 pm Post subject: |
Andrew wrote: |
chrisflstf wrote: |
If you are worried about parts obsolescense, you should buy your spare parts now, rather than wait 20 years |
I'm just saying I like planning for the future. Same reason I like disc brake kits that use off the shelf parts rather than custom made parts. If the (one) company that makes the parts goes out of business, what are you going to do when you need a new rotor? Parts are never lifetime parts... |
of course you realize you can get Berg Rubbers from 1978 bus upper mount for trans?? used longer than the pad mounts that were replaced by mounts that do not use the cradle like 67 and older in old speed design. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
Posted: Thu Aug 11, 2011 1:13 pm Post subject: |
mightymouse wrote: |
chrisflstf wrote: |
Quote: |
Yeah, the nose of the trans goes DOWN. The trans thinks you are backing up all the time. The reductions then convert that to forward motion. The pinion is trying to climb DOWN the side of the ring, not UP as in a Beetle based setup. Why do you think the rear end raises? or when you wheelhop offroad your apron seal ends up UNDER the rear tin? Because the engine goes UP.
OK... is that clear enough? (without being a super dickhead)
Movement in the nose cone is not limited to only 1 direction. In a design such as ours, the motor is cantilevered off the trans. The nose cone wants to see/saw up and down when you are on and off the gas. I'll stick with my Berg modified rubber center mount - I know it works as I drive it |
Yes BUT 90% of its force is applied down ( if your redux). as you drive forward most of the time dont you? lol. |
the only problem i see is the stupid front nmounts keep breaking. that is why i recommend using a berg type mount.
the quality of front mounts availible is not the same as was factory install in 1964 when my 65 bus was built. panels are the hotrod in vw buses while 21/23/windows & westies are the edsels of vw world. _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Thu Aug 11, 2011 1:53 pm Post subject: |
bill may wrote: |
Andrew wrote: |
chrisflstf wrote: |
of course you realize you can get Berg Rubbers from 1978 bus upper mount for trans?? used longer than the pad mounts that were replaced by mounts that do not use the cradle like 67 and older in old speed design. |
I didn't realize it at the time, but somebody told me that afterward. Very good thinking on Berg's part. _________________ -Andrew |
Posted: Thu Aug 11, 2011 10:00 pm Post subject: |
OB Bus wrote: |
I was just reading this entire thread and enjoying every page. Then it stops dead on July 13th? What happened? How did it end? |
Somehow I missed this post. I used that mount in my 57 bus, backed by a nicely tuned 1776, for many thousands of miles, with no issues. No bent tranny horns, no broken studs, no fatigued bolts. It worked very well. I did have to re-tighten a few of the nut/stud combos on the nose cone after a few hundred miles, and I constantly checked the tightness of all fasteners. That bus is no longer in my stable, but the new owner drives the bus regularly and has had no issues that I know of.
I will be building another one soon, but it will be for a straight axle setup. There are a few design changes that I will incorporate. If I can remember to do it, I will post some pics in here. _________________ nothing |
SixVolt Samba Member
Joined: January 04, 2004 Posts: 1136 Location: Cleveland, Ohio
Posted: Fri Mar 30, 2012 5:19 am Post subject: |
Has there been another version since the last post? Any other options based on using or incorporating the original big donut mount? Just wondering. If I keep my '59 I'd like a nice non-hack option. Great thread by the way. |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Sat Jun 23, 2012 8:35 am Post subject: |
has anyone used the wagenswest lollypop adapter yet? it looks like it would work very well. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Sat Jun 23, 2012 9:42 am Post subject: |
http://www.wagenswest.com/partstore/index.php/root...r-kit.html
That's pretty cool. I was just in Nate's shop back in March, I wish I would have know about these so I could have seen it first hand. I would consider this over the style that I made. _________________ nothing |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Sat Jun 23, 2012 9:58 am Post subject: |
It appears so. But that's how VW did it with split case trannies. _________________ nothing |
mightymouse Samba Member
Posted: Sat Jun 23, 2012 11:56 am Post subject: |
My only question is... how much noise does the urethane part transmit to the body?
Anyone experienced this part/has run this yet?
I like this and kens version both. Debating now which one to use.
Ill be putting a tunnel in my bus by years end and need to decide. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1065 Location: Gilbert,Arizona
Posted: Sat Jun 23, 2012 2:37 pm Post subject: |
The problem i have with it is, it seems to only work with RGB's were the nose of the trans will want to dip down,whereas with straight axle kit the nose will want to raise up, were there is no rubber isolating it.
EDIT: I see the stock later model bolts hold it. It might be an alternative to the pricey Concept1 kit,which works well, i have that kit in my '57. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red)
Posted: Sat Jun 23, 2012 2:49 pm Post subject: |
i don't think it will work on my bus someone try to put a tunnel trans in before and did a bad hack job at it
but i really don't like this stupid bus boys mount either _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
