ZwitterND Samba Member
Joined: September 08, 2005 Posts: 1451 Location: Fargo, ND
Posted: Mon Apr 19, 2010 1:02 pm Post subject: Battery cover fit. |
I went to Interstate battery to purchase a 6V battery U19L for my zwitter. They had one in stock so I was able to check the fit of the cover. Width was fine but length of battery was about ¼" too long. In an earlier thread it was stated that U19L was the one to get. Anyone have another source for a correct size? Width & length of the battery would have to be no larger than 7" x 7 3/8". If I recall correctly the cover should fit snug on top of the battery with the lip of the cover hanging over. _________________ Bill |
Viande Samba Member
Posted: Tue Apr 20, 2010 12:48 am Post subject: |
Not intimately familiar with this but I do know my supplier in Germany lists these in two models. 66Ah and 77Ah and the factory cover only fits the 66Ah unit according to their description. Perhaps Interstate is based on the longer Ah rating?
_________________ Bobby
New Items In Stock, NOS & OEM Seals,Parts and Terminals
My Feedback Here
The bitter taste of poor quality lingers long after the joy of the cheap price fades away. |
bwaz Samba Member
Posted: Tue Apr 20, 2010 7:59 am Post subject: |
I read back in some old posts on the samba and saw a discussion about a 17L battery being correct for Oct '52 - July '55 and '56-'66 were 19L. It never said if it was a listing for bug or bus. I googled it and found http://www.antiqueautobattery.com/17l.htm has a listing for one. |
vintage fiberglass Samba Member
Joined: January 23, 2006 Posts: 485 Location: Reading, Pa
Posted: Sat Aug 24, 2013 6:41 pm Post subject: 6 volt battery for a split beetle |
I am frustrated. I just fried a 6 volt battery with the seat in place touching the terminals I guess. I am reading thru these forums and still do not have a firm answer in my head. I had a 19L interstate battery and it was a bit big for the battery cover. Then I realized I had two battery covers and one is even smaller than the 19L one. That one came with my split. Is there any battery anywhere that will fit on the floor, fit a stock VW battery cover and clamp in with the stock spring like clips?? I know people are using Optima 6 volts. Looking for more of a stock fit. Tim |
Posted: Sat Aug 24, 2013 6:48 pm Post subject: |
An earlier split must have had a smaller battery than an oval did. The 19L is too big for the small split battery cover I have but maybe 1/2"?? It seems like that is pretty much all that is out there unless you go to a British battery for like an old MG? Unless someone knows something different. Tim |
Posted: Wed Oct 17, 2018 4:26 am Post subject: Re: Battery cover fit. |
Does anyone have any new information on where to get a proper battery for a split beetle. I need one for my 1950 split. I was going to buy one of the German vintage Bosch ones but it was 175mm x 215mm and I think that is too big? Maybe for an oval? Tim |
Suboval Samba Member
Posted: Wed Oct 17, 2018 6:46 am Post subject: Re: Battery cover fit. |
Here is some information that might help:
https://www.thesamba.com/vw/forum/viewtopic.php?t=573744 _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
pastellgreen Samba Member
Joined: January 06, 2012 Posts: 1049 Location: Germany
Posted: Wed Oct 17, 2018 11:46 pm Post subject: Re: Battery cover fit. |
The 84 Ah battery is correct and has the right measures. There are several provider in Germany, I would not go with Bosch, as they are too expensive. You also get these Bosch stickers somewhere in Internet (Ebay) and could stick them on your battery to make them look correct.
Last edited by pastellgreen on Sat Oct 20, 2018 12:47 am; edited 1 time in total |
coolparts Samba Member
Posted: Sat Oct 20, 2018 12:07 am Post subject: Re: Battery cover fit. |
Tracktor supply has them . That’s where I got mine |
lzamora Samba Member
Joined: October 24, 2009 Posts: 109 Location: Torrance CA
Posted: Mon Oct 22, 2018 11:58 am Post subject: Re: Battery cover fit. |
What would be the code for the correct 6 volt battery at Tractors Supply?
Thank you, Louie |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Mon Oct 22, 2018 2:50 pm Post subject: Re: Battery cover fit. |
Look for a 19L or a 19L40 battery. Advance Auto parts near me can usually order them, as well as O'Reilly Auto parts. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Oct 23, 2018 1:35 pm Post subject: Re: Battery cover fit. |
Thanks John. I tried tractor supply website but it seems like the only 6 volt battery they have is for golf carts. Louie |
DDub Samba Member
Joined: January 06, 2005 Posts: 307 Location: central pa.
Posted: Tue Oct 23, 2018 4:11 pm Post subject: Re: Battery cover fit. |
I think Interstate still makes them. |
