shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3800 Location: VA/TN
Posted: Tue Jan 22, 2019 12:13 pm Post subject: Re: CLK wheels |
mikemtnbike wrote: |
ok, just making sure, as most of the other merc wheels have to have the center hole bored for hub clearance. Good hunting!
Tips that are posted earlier in the thread- make sure you search for Mercedes wheels without the CLK filter (how I found mine) and whole wrecked cars, that's where I've seen them locally since. |
Also tip, you can 'pipe' and 'exclude' searches too. For example, this is what I search in craigslist
mercedes wheels | mercedes rims | clk | amg -Financing
I had to add the -financing part because there is a ridiculous amount of "New wholesale" rims ads on craigslist. _________________ Brandon
Instagram @joannthevan |
Vnyd Dog Samba Member
Posted: Wed Jan 23, 2019 9:58 am Post subject: Re: CLK wheels and need to Drill |
I ran some searches and haven't seen it in this thread. I recently did a stud conversion on my MB. My question that was nagging is why drill the CLK wheels? If they were designed as 12x1.5 studs, and the Van (like my current MB) run 14x1.5 lug bolts, I took a shot at an adapter stud conversion and sure enough:
https://motorsporthardware.com/product/adapter-stu...-5-12x1-5/
These are the guys that the Bimmer and MB folks use for conversions.
Soooo...rather than drill out wheels, is there any reason using this conversion stepped down to 12x1.5 wouldn't work?? Putting aside the cost difference
And this adapter kit seems fairly available, stepping down from 14x1.5 to the hub and into 12x1.5 for the wheel. _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
https://www.thesamba.com/vw/forum/viewtopic.php?t=713391&highlight=life |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Jan 23, 2019 10:21 am Post subject: Re: CLK wheels |
Are you not wanting to drill the lug holes because you want to keep them stock to go back on a Mercedes later? I don't see what angle you are getting at with not getting the right drill bit from T3Technique, and the other (suggested) proper hardware from him too. Keep in mind that the Vanagon is a heavy rig, built to haul an extra Ton on top of its curb weight... Seems like a good safety margin keeping the 14's _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
elizer Samba Member
Joined: May 02, 2016 Posts: 1464 Location: Northern Virginia
Posted: Wed Jan 23, 2019 10:46 am Post subject: Re: CLK wheels |
I just drilled. the bit was like 15 bucks shipped. Compared to the 100-114... |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Jan 23, 2019 11:40 am Post subject: Re: CLK wheels |
Drill, baby, drill!
Not that I've done it yet, but I'm cheap, so...yeah.
Still looking for a cheap clean set of CLK's on clearance...
- Dave
PS: Do what you want...it's your van... <shrug> _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Wed Jan 23, 2019 12:14 pm Post subject: Re: CLK wheels |
bobbyblack wrote: |
Are you not wanting to drill the lug holes because you want to keep them stock to go back on a Mercedes later? I don't see what angle you are getting at with not getting the right drill bit from T3Technique, and the other (suggested) proper hardware from him too. Keep in mind that the Vanagon is a heavy rig, built to haul an extra Ton on top of its curb weight... Seems like a good safety margin keeping the 14's |
Woah there, nothing about T3. I love T3. I just placed an order with him this morning. I am merely exploring other options. And to raise a point that it may be possible to run the CLKs without drilling, and yes, to preserve potential resale options back to an MB crowd. My bad if it came across any other way. Sometimes we get so committed to one way of doing things that alternatives may get overlooked. Anyways... _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
elizer Samba Member
Posted: Wed Jan 23, 2019 12:27 pm Post subject: Re: CLK wheels |
Just a heads up... The market for clk wheels is larger here than the MB community. |
Posted: Wed Jan 23, 2019 12:37 pm Post subject: Re: CLK wheels |
elizer wrote: |
This is funny, yes, many MB folks consider the '98-'00 CLK rims downright ugly. I've heard stories where someone offered an owner/driver of one of these CLKs to trade him for another set, no $'s required. Just put his rubber on the trade rims, and off he went with the Vanagon's new rims... _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
toomanyveedubs Samba Member
Joined: November 26, 2007 Posts: 596 Location: Great White North
Posted: Wed Jan 23, 2019 1:33 pm Post subject: Re: CLK wheels and need to Drill |
Vnyd Dog wrote: |
And this adapter kit seems fairly available, stepping down from 14x1.5 to the hub and into 12x1.5 for the wheel. |
This solution also doesn't work because Syncros have pressed studs and so does the Vanagon in rear drums. |
Posted: Thu Jan 24, 2019 10:59 am Post subject: Re: CLK wheels |
$350: set of CLK rims, plus a free BMW in Spartanburg, SC.
1985 Mercedes-Benz 190 E 2.3 Sedan 4D with CLK rims.
Runs and Drives. Automatic. 162,000+ miles. Includes CLK Rims. Has Heat/AC. Interior/Exterior needs cleaning. Battery needs recharging. NO TITLE. (Serious Buyers Only). No Trades. AS IS. Cash only
https://www.facebook.com/marketplace/item/2316037971762308?surface=product_details
If I was closer I would buy this. Go get em boys. _________________ Brandon
Posted: Thu Jan 24, 2019 11:02 am Post subject: Re: CLK wheels |
Nice, buy the car, swap the wheels, donate the car, take a charitable tax deduction= Free CLK wheels! _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Fri Jan 25, 2019 6:35 pm Post subject: Re: CLK wheels |
Those are in really poor shape. |
Posted: Fri Jan 25, 2019 7:23 pm Post subject: Re: CLK wheels |
syncrodoka wrote: |
Yeah I traded emails with that joker. His customer service leaves much to be desired and yes when he finally did send the pics I asked for the wheels are really chewed up. He only had two so I’m holding for now. _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
Posted: Sat Jan 26, 2019 3:06 pm Post subject: Re: CLK wheels |
While we are discussing CLK forged wheels, what have others found to be the best way to restore them? Tank strip? Paint remover? Blast and polish? Thoughts? Looking for an original finish not prep for paint or powder coating. |
Posted: Sat Jan 26, 2019 4:41 pm Post subject: Re: CLK wheels |
toomanyveedubs wrote: |
Blasting would roughen up the finish too much. You would need to strip off the clear coat, repolish then reclear. |
